Well, in that case, the Zanflare is probably a better light for you. It takes 2xAA, so it will have better run time than this light. And it’s cheaper than this one by a couple USD. More-for-less! :money_mouth_face:
I was going to say something a couple days ago regarding the use of a 14500 cell, but I forgot. If you want a little more output without burning up the driver, you should try a LiFePO4 14500. Most of these boost drivers are actually rated for either 1S or 2S alkaline. So, the LiFePO4 max charge voltage of ~3.6V is close enough. Most of these boost drivers do happen to survive the 4.2V Li-Ion max charge as well, but that’s way outside the range and could cause problems.
Yep, getting to that conclusion Should’ve tried to compare it to the Thrunite T10 as well (more fitting, as it’s the exact same 1xAA platform), but all is good in the hood.
Not yet, I fear that it would be more slippery but OTOH I prefer a reflector rather than a TIR…
But it doesn’t have a clip…although maybe the convoy clip would screw in the lanyard holes… could you check that ?
Eheh, same reasons I ordered it Using it with a 14500 can be a plus, but 1AA (Ni-MH) will be enough
The quality seems really good! :+1:
Hum, aren’t those a bit harder to find? Never had one of those… And normally I don’t seem them when searching for the 14500! Or maybe I just overlook them
The “funny” thing about this model (i don’t know if it is exactly this light) is that on the Amazon store where I found them, it is mentioned that they can be used with 14500 batteries. Being the Li-Ion the most common, I believe they refer to that type of battery…
I’ll just have to try them when I get them
Thanks for your information about the LiFePO4 14500 :+1:
They are easy enough to find on eBay (at least for me). But, I failed to mention that they don’t hold as much energy, so run-time will suffer, even compared to Alkaline AA. :person_facepalming:
Hum…despite liking the higher outputs, I guess that a longer runtime will may be a more important aspect for my use! Especially because I use these AA lights for longer periods of time, indoor or in places that don’t need to be light-blasted!
So Ni-MH and eventually the Li-Ion will gain some predominance!
Thanks again :+1:
Btw, CRX, that’s a quite nice one!!
I have a SS 3xAAA / 18650 light on the way, and I guess that the clip tip will be a good one to fit that light
I received my flashlights today! I’ve done a small “review”, you can find it here
I can’t give more “numbers” or technical aspects, but here you have a glimpse at a pretty light!
Well, I swapped my Acebeam M10 XP-G3 (6500K) for a much warmer 2700K one and don’t see any tint shifting neither before or after.
I guess Acebeam designed the reflector specifically for this emitter.
That said, TIR are good for EDC (see Olight S series, all equipped with TIR) for close range use.
