Built another carbon fibre piece, this time it’s a magnetic power bank lantern using a single 60mm warm white COB with a reverse clicky switch on top to go with the set.
I’ll get through that 600mm CF tube eventually
I used a Panasonic 18650 PF in this with a charging board from FT and a 10 ohm resistor giving around 40lm from 110mA. Surprising how 40lm flood does you in the dark.
Again an awesome build!
Side note, how good are the charging board you use? You say cjeeap, so is it good?
Oh and i nominated you to host the OL build comp this year
