Lightbringer, perhaps this one is a “bit” more than 900mW…
As far as the tint questions, remember that in the same power binning a warmer tint makes much less lumens than a cool tint, so it would only be feasible that you would get more reflection from humidity from the brighter light…
As interesting as philosophy of governance is, it’s one of those topics which tends to get out of hand pretty easily.
Instead of responding with data on the effects of various governance strategies (data on this sort of thing tends to be counterproductive when humans are involved), I’m hoping we can stick to less fiery topics… like actually starting fires.
Dale, that is the laser you made for destroying wasp nests from a safe distance, no?
Can anyone tell me how long I can run the C8 at 100% in let’s say 25-30 degrees C ambient temps until the heat buildup is too much. There is a runtime chart floating around which shows a max temp of 66 at about 40 minutes in with an ambient temp of 25(?), is 66 too high?
I can’t say if that’s as hot as one gets, or if those numbers are accurate, but I can say that 66c is not “too high” for the electronics. That heat won’t hurt your light. It may hurt your hand though. How tough are you?
Bottom line — if you can stand to hold it, its not too hot.
If you’re holding your light, it doesn’t get that hot. Your hand draws a lot of heat from the light. I think those run-time temperature graphs are done with the light tail-standing.
Thanks! A grey C8 is calling my name… I see people get around 80,000 cd out of them in stock form - that would make for some impressive pocket thrower. My current go-to thrower is Thorfire VG-10, and that barely clocks in at around 12,000 cd.
You’ll be satisfied for sure. I have a C8 with a domed XM-L2 and an OP reflector, and it’s still easily my longest-reaching torch despite the throw-unfriendly setup. It laughs in the face of a 100m distance!
Yes, I have a stock C8 silver, and it’s a great pocket thrower. Jacket pocket, perhaps. Easily my go-to for an outdoor thrower, since it’s so light. I have the 7A and 3A, and I prefer the 7A tint. Though I might get a 4C, since it’s probably a good compromise.
If all you have now is 12k cd, you’ll notice a huge difference. But bring a flooded as your main light, because a C8 is bad up close.
Unless you’re tail-standing it. Throwers make great lights for tail-standing, since you don’t get much spill to catch your eyes when sitting near the flashlight. And, the C8 seems to have an AR coating, so you don’t get glare off the lens either.
I like the 7A tint on the C8 for indoor tail-standing. Nice incandescent-like light.
