Review request for HKJ [Chargers]
364 posts / 0 new
rizky_p
rizky_p's picture
Last seen: 7 months 3 days ago
Shouldn’t they installed RCD/RCCB on the breaker especially for bathroom in the US?
hank wrote:
Got a guess on this one?
http://www.nbcnews.com/news/us-news/feds-looking-teen-s-reported-electro...
I recall some chargers were wired so badly that they could put line voltage on the outside metal frame of cell phones.
Bad thing to take into a bathtub.
And there they are: https://www.google.com/search?q=cell+phone+charger+hot+voltage+outside+h...
HKJ
HKJ's picture
Last seen: 3 hours 49 min ago
Probably only when they change an installation or make a new installation.
rizky_p
rizky_p's picture
have you test this charger seems like an okay price for a 2A charging. Really lacking information, if its charging 2A at all slots that would be good.
AWT C4 charger
HKJ
HKJ's picture
rizky_p wrote:
have you test this charger seems like an okay price for a 2A charging. Really lacking information, if its charging 2A at all slots that would be good. AWT C4 charger
No, but it looks interesting. With the amount of chargers I have in queue just now, I will not order new chargers for test.
At a later day I expect to check this thread for interesting chargers.
start90a
start90a's picture
I remember for that later day also a Nitecore SC4 . Big Smile
HKJ
HKJ's picture
I have made a memo in the second post of the thread.
Pete7874
Pete7874's picture
Last seen: 7 min 38 sec ago
Charger review request: Folomov A4:
http://www.folomov.com/en/content/?125.html
TheBo
TheBo's picture
Pete7874 wrote:
Charger review request: Folomov A4: http://www.folomov.com/en/content/?125.html [/quote]
10 amps....... O_O
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
Pete7874
Pete7874's picture
TheBo wrote:
10 amps……. O_O
It’s 8 Amps max (4×2A), if I’m reading it correctly.
The outer bays can push 3 Amps only when the two inner bays aren’t being used.
The main negative I see is that there is no discharge function and no ability to measure actual battery capacity in mAh.
TheBo
TheBo's picture
Oh yes... I read it again... In my mind I have read ch2 and ch3 can only deliver 2A when 4 slot are used.  My bad, seems time to sleep has arrived. Thank you for the clarification.
tempo
Last seen: 5 hours 41 min ago
Pete7874 wrote:
TheBo wrote:
10 amps……. O_O
This looks like the most powerful charger on the market, 10 amps!!!
Or is there any more powerful, other than MC3000 ?
hank
hank's picture
Last seen: 21 hours 37 min ago
https://www.aliexpress.com/store/product/Multi-Slot-Smart-Charger-For-AA-AAA-NiMH-NiCd-Rechargeable-Battery-8-Bay-Battery-Charger-Batteries/2933049_32807168511.html
8 AA slots, looks like this:
Pete7874
Pete7874's picture
tempo wrote:
Pete7874 wrote:
TheBo wrote:
10 amps……. O_O
This Folomov one can do 8A max, same as MC3000.
TheBo
TheBo's picture
I'm not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and  compensate for that so, should be legit. I repeat, mereley looking at the spec...i could be worng, since i read the review long time ago
Pete7874
Pete7874's picture
TheBo wrote:
I’m not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and  compensate for that so, should be legit. I repeat, mereley looking at the spec…i could be worng, since i read the review long time ago
Yes, I’ve seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
HKJ
HKJ's picture
I do have a 3A discharge curve:
!http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
There was a bug in my table with all chargers, it is fixed (There is probably more bugs in the table and I will fix them as fast as I know about them).
I am not going to fix the broken link.
Pete7874
Pete7874's picture
Thanks, HKJ. There is this table in your review that only shows current values up to 2A, and not even for 18650 batteries, so I wasn’t sure…
HKJ
HKJ's picture
!http://lygte-info.dk/pic/SkyRC/MC3000/supportedBatterySizes.png!
That is the recommended charger current for different cell sizes.
Pete7874
Pete7874's picture
Got it. Thanks for clarification. Looks like MC3000 is still the king. Smile
will34
will34's picture
Last seen: 1 hour 1 min ago
It really is, the more time I spend with it the more I like it. The UI feels so easy to use now… (after a year)
rizky_p
rizky_p's picture
to go beyond 3A i think you’ll need hobby charger + 18650 holder and MC3000 is already expensive, but i dont charge my 18650s beyond 3A anyway, tried on 4A but got rather hot (samsung 30Q got 41C)
Barkuti
Barkuti's picture
Last seen: 2 hours 49 min ago
HKJ wrote:
Pete7874 wrote:
Yes, I've seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
I do have a 3A discharge curve: !http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
Fixed link. Wink
You may want to switch to the advanced post editor, HKJ. Getting used to it may take some time, but the rewards are substantial.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
hank
hank's picture
http://www.illumn.com/catalogsearch/result/?q=Folomov
The email ad I got from illumn says:
Quote:
A4 is a 4 slot smart charger with the capability of charging all 4 slots at 2A per slot. The outer two slots (slot 1 and slot 4) are capable of charging up to 3A when charging fewer than 4 batteries for your larger 26650 capacity batteries. Packed full of features such as LiFePO4 support, NiMh/NiCd charging capabilities, and 0V activation
Pete7874
Pete7874's picture
Adding an official request to test the new Miboxer C4-12, if it’s not on your list already. Sounds like they may be sending you one soon…
http://budgetlightforum.com/node/55757
Trevi_lux
Trevi_lux's picture
Last seen: 2 years 3 months ago
Hello HKJ, is in queue the Zanflare C4?
HKJ
HKJ's picture
No, at least not anymore: http://budgetlightforum.com/node/55835
Trevi_lux
Trevi_lux's picture
Big Smile You are the best, thanks for your reviews!
RapidLux
RapidLux's picture
Last seen: 12 hours 13 min ago
Can LiitoKala Lii-402 charge Keeppower 26650 5200 mAh protected batteries, or not? There is only up to 18650 in it’s specifications. This is strange because Lii-202 can charge 26650. I also see some users are using it to charge other 26650 batteries.
HKJ
HKJ's picture
On the photos it looks like it has two wide slots.
specialk
Last seen: 3 weeks 3 days ago
