I'm pretty sure I got triple channel NarsilM 1.0 working fine with a Ind. LED. I have it installed now, from June 1st or so, in an OTR M3. It's got the delayed dbl-click, all the features of NarsilM 1.0 and uses TA's triple with 3 7135's as the bank:
Hhmm - is the stepdown in mode sets? Is this still a problem? I'm gonna be working on this feature for the BLF GT, at least add the option into NarsilM. Plan on setting a max of like 80-90% for ramping, but still allow the dbl-click turbo to go to 100%.
It looks like you are talking bout mode sets, not ramping. Sounds like you didn't configure it correctly, but not sure. Think I already had a factory set of modes that didn't go to max output and I recall it worked fine.
It’s rather impressive seeing all that in such a small host.
If you were so inclined, you could probably sell those for twice as much as the Olight S1 (S10?) it’s cloned from. Not sure that would be enough to make it worth your time, but it sure would be nice if there was a BLF light with the form factor of a S10/S1/S-Mini.
It was a challenge for sure. Sanding down the driver PCB was the most time consuming part. It is amazing though - same basic driver/design in a 37K lumens 16X XHP50 light, and the tiny OTR M3. I carry the M3 in the little pocket inside the regular jeans right hand pocket - no scratches, feels fine, no accidental ON's, don't have to lock it out.
Hmm? I haven’t noticed any problems with the indicator led either. But maybe I don’t know how it is actually supposed to work and therefor I’m thinking its working. What can I test to see if mine acts as yours or if it is really working?
I have high hopes for this one. I have it on the way. It’s hard to believe it has all the features for the price! And I’m thinking the space inside the head is going to limit the use of custom driver? Just think, add USB charger to that board Tom made :person_facepalming:
My M3 definitely works, been checking it. If all those things don't work, what does work? Does anything work with the Ind. LED?
I'm thinking maybe you got the default config settings set to disable the Ind. LED function, maybe?
These settings should be as follows:
define DEF_LOCATOR_LED 1 // Locator LED feature (ON when light is OFF) - 1=enabled, 0=disabled #define DEF_BVLD_LED_ONLY 0 // BVLD (Battery Voltage Level Display) - 1=BVLD shown only w/onboard LED, 0=both primary and onboard LED's #define DEF_ONBOARD_LED 1 // On Board LED support - 1=enabled, 0=disabled
Ok. Mine works with battery voltage so pretty sure mine is working too. I’m using narsilM though…
The first I tryed the indicator did not work but then I read through setup, .c and all the included files to make sure the settings were right. However I do not recall what setting I changed in fact I don’t think I even knew what I did different. Sorry this doesn’t help you much though…
The only different file from what I’m using is the m3 setup file. I’m just using the main built in setup file. I didn’t know there was an m3setup file. Sorry, I am unable to flash your .hex file right now. That might be helpful. Idk? If your still having trouble I might be able to do that tomorrow. I’ll keep watching. Hope you get it working. Working through these details can be frustrating !
I did mod the Klarus G35 with the dead driver today with NarsilM driver
further testing showed that the indicator LED as locator does not shut down with low voltage when the battery gets depleeted from it
it draws not too much on my setup with green LED and 4.7kOhms about 85uA at 2.7V
so there is a parasitic drain that can kill unprotected cells if the light gets stored over a longer period of time with the locator on with almost depleeted batteries
BUT
when the light shuts down from LVP it starts to blink for low voltage warning when the light is in standby, but it does not shut down
even worse the blinking means the MCU is not in deep sleep and it draws more current
then it draws 3mA from the battery which can be within a few days lead to a overdischarged battery, as the battery is almost depleeted
By design, when the light is shut down in a low voltage state, it does the blink to indicate low voltage, as you say, but does it only for 6 minutes, then shuts down the MCU. So after 6 minutes, it should go into a "deep sleep" (power savings) mode. After the 6 minutes is up, it should turn off the Indicator LED before going into power savings mode.
So, did you wait the 6 minutes to see that occurs or not?
I'm pretty sure I tested this in the older Narsil version, but not in NarsilM, nothing was changed in this area.
However if your cells are pretty low but not in a low voltage state, and you leave the light with the main LED off and Indicator LED on for several months, or maybe weeks, depending, then yes - there is no smarts in the MCU running to determine low voltage, therefore it cannot shut the LED off, so it will over drain the cell(s). This parasitic drain is pretty low though, depending on what LED and LED resistor value you use. I've left several flashlights in this state with the Indicator LED on for months without noticing much battery voltage drop.
Here's the code:
// Be sure switch is not pressed and light is OFF for at least 5 secs
word wWaitTicks = 310; // 5 secs
if (LowBattState)
wWaitTicks = 22500; // 6 minutes
#ifdef ONBOARD_LED
// If the battery is currently low, then turn OFF the indicator LED before going to sleep
// to help in saving the battery #ifdef VOLT_MON_R1R2
if (byVoltage < ADC_LOW) #else
if (byVoltage < BATT_LOW) #endif
if (locatorLed)
TurnOnBoardLed(0); #endif
_delay_ms(1); // Need this here, maybe instructions for PWM output not getting executed before shutdown?
SleepUntilSwitchPress(); // Go to sleep
}</code></pre>
