Either online at onlinemetals.com or I got to a local machine shop. The machine shop is usually cheaper as they don’t have agressive shipping charges, they do charge bases on time to cut the bar to length from a larger rod of stock. I’ve also found that the machine shop generally won’t have copper or tellurium copper, so the choices may be more limited.
If you’re lucky you can get a small shop that has ends that they have on hand but don’t use because they’re too small for many of the projects they get in, then you can just a piece based on the price of it and since they buy larger rods for stock they get lower prices.
hank
(hank)
July 27, 2017, 7:00am
7801
Modern flashlights. Amazing.
hank
(hank)
August 9, 2017, 5:13pm
7802
Driver problem — I’ve just installed a 5x7135 driver (bought months ago) set up with Guppydrv
but it’s got next mode memory on all of its settings.
Any guess what I’ve done wrong here? Could I have grounded something with the retaining ring?
It’s running a PC amber emitter that also came from Mtn.
Oh, and the turbo timer drops down to moonlight, not to 50 percent.
Is there a way to cancel the turbo timer completely?
EDIT nevermind, found how to cancel turbo timer by setting to 4 seconds or less (info is on the page for the larger diameter driver)
And I found a thread about the next mode memory problem at: Help! - MTN-20DD driver with guppydrv always starting in next mode - #12 by hank - Flashlight Modding and DIY Parts - BudgetLightForum.com
John-Galt
(John-Galt)
July 30, 2017, 4:46pm
7803
Hi, RMM. Any idea when you might have Shockli 5500 mAh 26650’s back in stock? Thanks…
Firelight2
(Firelight2)
August 8, 2017, 9:35pm
7804
Richard is now selling e-switch drivers with the Emisar D4 UI v2.
It’s available now on his website in various sizes from 15mm on up.
This is great news for all modders who love the v2 firmware in the D4 and want to put it in their other e-switch lights.
RMM
(RMM)
August 9, 2017, 4:01am
7806
hank:
Driver problem – I’ve just installed a 5x7135 driver (bought months ago) set up with Guppydrv but it’s got next mode memory on all of its settings. Any guess what I’ve done wrong here? Could I have grounded something with the retaining ring? It’s running a PC amber emitter that also came from Mtn. Oh, and the turbo timer drops down to moonlight, not to 50 percent. Is there a way to cancel the turbo timer completely? EDIT nevermind, found how to cancel turbo timer by setting to 4 seconds or less (info is on the page for the larger diameter driver) And I found a thread about the next mode memory problem at: Help! - MTN-20DD driver with guppydrv always starting in next mode - #12 by hank - Flashlight Modding and DIY Parts - BudgetLightForum.com
If turbo timer is stepping down to anything less than 50% there is a problem. To go any lower than 50% the driver thinks the input voltage is low.
Edness
(Edness)
August 9, 2017, 2:39pm
7807
Firelight2:
Richard, is this the same driver that came with the D4 v1? I have a v1 and I’d like to change to v2 if possible. I don’t mind getting the same driver with v2 firmware and replace it.
RMM
(RMM)
August 9, 2017, 2:46pm
7808
No. It is the MTN driver with the same firmware, not the D4 driver. You'd be better off just reflashing the existing driver.
RMM
(RMM)
August 9, 2017, 3:50pm
7809
Regarding the MTN Quad and Emisar D4 flashlight:
You can swap the MCPCBs directly, with NO SPACER required. I had read some comments stating that a spacer is necessary, but doing the measurements and actually building some lights with the MTN Quad MCPCB it works fine without any extra spacer needed.
Could I put 4 XP-E2 Green emitters on your board and run em on the FET or would I have to reduce direct drive through PWM to keep from smoking the emitters like I did the Lee Filter I tried?
Maybe use the 18350 tube and a lesser cell to keep max current in check?
hank
(hank)
August 9, 2017, 5:17pm
7811
The ‘next mode memory’ problem I have is probably a bad capacitor or two, as people described here:
I can't help too much - don't have that particular one and there's no pics here or on the MtnE site. It should have a cap on the board for OFF time memory, and seems like that functionality is not working. If the firmware thinks the cap is always almost fully charged, it will always do the next mode. So, this is a possible cause of this behavior (cap is not functioning correctly due to possible bad solder joint or bad cap).
The OTC (OFF time cap) should be the smaller of the 2 caps - one end of…
and here:
I had this problem once. One of my capacitors (unsure which one) was not charging and discharging properly. I bought replacements for both C1 and the offtime capacitor, installed them, and my problem was solved. Try re-flowing the capacitors, and if that doesn’t work, try replacing them.
Time for me to learn how to solder itty bitty things.
mattlward
(mattlward)
August 9, 2017, 5:49pm
7812
Firelight2:
I must be blind, do not see them under FET or linear drivers…
RMM
(RMM)
August 9, 2017, 5:52pm
7813
It can't be the capacitor. Maybe we flashed it with the wrong firmware or something because there is not OTC on that 15mm 7135 board, so the capacitor will not affect the memory.
RMM
(RMM)
August 9, 2017, 5:53pm
7814
It is a firmware option for the FET+7135 drivers---not a completely separate driver.
mattlward
(mattlward)
August 9, 2017, 6:25pm
7815
Bummer, I need a couple of side e-switch drivers and had hope for a good driver with good firmware to replace a couple of factory drivers.
hank
(hank)
August 9, 2017, 6:44pm
7816
Did I say 15? It’s 17mm
Firelight2
(Firelight2)
August 9, 2017, 6:40pm
7817
And they are available. Just select the correct diameter of driver from the list of FET+7135 drivers, then use the dropdown menu to select D4 v2 UI.
Hi Richard, what turbo timer option should I choose on the 17mm fet +1 driver with the D4 firmware? I wish to have the same configurable temperature step down as the D4.
Thanks
Ford Prefect
Firelight2
(Firelight2)
August 9, 2017, 6:47pm
7819
I don’t think the D4 ui has a turbo stepdown, so you can just ignore that menu. At least that’s what I did with my order.
