My Black 219C arrived the other day.
Thanks to all that participated in the making of this light.
The 219C I got is pretty White, good clean white.
Wasn’t long till I swapped the optic for a Frosty 10623 Carclo Lens - 4-UP Quad Frosted Medium Spot Optic from Richard.
Also have a bad habit of holding lights in my mouth…. added an adhesive lined heatshrink to the tailcap.
Um, unless my Lee Filters sample is not actually the optional HT (high heat) version, I’m not going to be able to filter the light. It kinda starts smoking and melts within mere seconds. Oops! So if I want high output green, it’s gotta be the Luminus $87 emitter. :confounded:
(Edit: This was on my Titanium/Cu Quad run by an 18500)
Thinking of getting one of these as a EDC + showoff light, was wondering which emitter would appear the brightest on a fully charged Aspire 18350?
I personally prefer the 6500k to 5000k tint, but at $18 more, if the Nichias are brighter (due to a lower VF and higher sag of the 18350s), that might be enough to sway me towards the 5k tint.
Is there any way for me to decrease the current drawn by the light when the FET is engaged? I’d like to maybe limit the light to 1500 lumens on turbo and increase the efficiency of the medium modes.
If you carry this light in the high pepper configurations, LOCK IT OUT. A friend of mine I bought one for lit his pocket on fire yesterday. Burned a hole through it. He’s not injured, just an idiot for leaving the memory on turbo and not using the pocket clip or lockout.
We check all of the lights we sell; individually, not one out a batch. With something like this, however, it is possible that the light worked when we had it, but then over time the wire pinched more and started to give the fault.
We did respond with a return shipping label and offer to fix/replace the light.
Made some interesting graphs for FET+1 efficiency (based on numbers from the Emisar D4 w/ 219C D240 LEDs). Thought you guys might enjoy them. All these are based on calculations and not empirical data, so please take everything with a grain of salt, but this should give you a rough idea of how the light behaves and how the efficiency differs between an 18350 (with a lower max output) and an 18650 cell.
Some interesting (albeit, expected) results. Efficiency is constant in the lower modes because it’s just PWM on the 7135. Efficiency is greater on the 18350 light since it draws less current when using the FET. This applies to any given brightness. What this means is that using a battery with less current handling capabilities will result in more efficient medium modes (as long as the battery is still able to handle turbo).
Notice how the Aspire had much greater output after 30 seconds. You can see how the temp sensor circuit kicked in a lot quicker on the 18650 cells to reduce output and might have overdone it.
I don’t think the D4 has it, but one nice feature might be to have the temp sensor step the light back up in output once temp goes down.
