Test/review of Efest IMR18350 700mAh (Purple) 2017
Official specifications:
  • Size: 18350 (18.3mm diameter x 34.63mm long)
  • Type: Li-Mn (Rechargeable)
  • Rated Capacity: 700mah
  • Max Discharge Current: 10.5A
  • Voltage: 3.7V
  • Protected: No
  • Style: Flat Top
  • Weight: 28g
  • Initial Impedance: 15mOhm
This is a high current 18350 cell.
The discharge curves looks good with nice tracking up to 7A. At 10A one of the cells has problems and at 15A both cell are serious over loaded.
Conclusion
The cell has good high current capability, the capacity is fine, but it is not a high capacity cell.
Notes and links
The batteries was supplied by Efest for review.
Comparison to other LiIon batteries
what does it mean that it is not a hight capacity cell? Does that refer to the700 mAh? That new cell, the Aspire, is rated at 1100 mAh.
thank you
You can find 18350 cell that can deliver less current, but more capacity. Usual there is some trade off between high current and high capacity. The Aspire is an exception to that.
