Made some interesting graphs for FET+1 efficiency (based on numbers from the Emisar D4 w/ 219C D240 LEDs). Thought you guys might enjoy them. All these are based on calculations and not empirical data, so please take everything with a grain of salt, but this should give you a rough idea of how the light behaves and how the efficiency differs between an 18350 (with a lower max output) and an 18650 cell.
Some interesting (albeit, expected) results. Efficiency is constant in the lower modes because it’s just PWM on the 7135. Efficiency is greater on the 18350 light since it draws less current when using the FET. This applies to any given brightness. What this means is that using a battery with less current handling capabilities will result in more efficient medium modes (as long as the battery is still able to handle turbo).
Notice how the Aspire had much greater output after 30 seconds. You can see how the temp sensor circuit kicked in a lot quicker on the 18650 cells to reduce output and might have overdone it.
I don’t think the D4 has it, but one nice feature might be to have the temp sensor step the light back up in output once temp goes down.
I’m very impressed with the Aspire 18350. Blows away the Efest purple in performance and capacity. Even seems to beat the Efest 18500 1000 mAh.
It makes 18500s feel a bit like a 5th wheel. You get less capacity on the best 18500 than you do with Aspire 18350 now while carrying a bigger battery and light.
However, despite this I have been EDC’ing the D4 with Efest 18500. Mainly because the 18500 battery tube is long enough for me to put Talon Grip tape on the battery tube. The light feels much better in the hand with it than the bare aluminum of the 18350 tube.
Any ideas about the numbers being so different from the declared ones? I M also curious of the xp-g2 and xp-l hi values at this time. I've ordered a nichia version in the end hoping it will be overall (lumen wise) on par with my dtt40 (imalent numbers are always... Meh) so it should have been possible with those numbers if legit
Most flashlight companies use a “lumen” value which is somewhat different than the ANSI standard lumen. I’m not sure why, but it happened and it kinda got stuck that way. Maukka uses something pretty close to the official standard, and I’ve been using something pretty close to the flashlight industry’s unit.
This difference also shows up in Zebralight lumens vs EagleTac lumens. EagleTac’s numbers are lower for the same actual brightness. It seems like most companies and most of BLF and CPF are using Zebralight’s scale though, or something very close to it.
The general rule is that published lumen numbers are only comparable to other numbers published by the same person or same company. Measurements by different people use different units, because no two are calibrated quite the same. This does improve somewhat when multiple people use meters created and calibrated by a single person, which has happened occasionally, but for the most part, different people’s numbers aren’t comparable.
I’m not surprised. This thing uses twice as much power as my soldering iron. Starting fires is not a difficult task for it.
Basically the entire top half of the ramp is “turbo”, as in “burst mode only”. There are reasons why it steps down quickly and doesn’t have a way to completely disable thermal regulation.
(if used inside an insulated space like a pocket, though, even a few seconds can be long enough to cause trouble… and it has no way to sense when that’s happening)
Incidentally, I tried checking the driver in one of my D4s.
Unlike the prototype reviewed in this thread my driver was NOT glued in. It was just press-fit. I was able to push it out using the pointy end of a flat toothpick inserted around the LED wires. This means getting to the driver to reflash it should be easy.
It should be renamed “The NutRoaster” or something like that. :smiling_imp:
I carry it in my pocket without any lockout, however I do make sure to only put it in my pocket with it turned off in a low setting. If it does turn on accidentally, hopefully it won’t ramp up to dangerous settings before I notice.
The button protrudes slightly, but does seem flat enough that I haven’t had any accidental activations yet. Keeping fingers crossed it doesn’t happen.
I don’t have anything to add, but I really appreciate the extra info and measurements! Posts like these make me sad that BLF doesn’t have a ‘like’ button.
