TK's Emisar D4 review
General note: I find blinking very bright. Even during the day it can hurt the eyes.
I guess you’re right. Idea for future improvement: Do the calibration twice to make sure it starts with a warm light. Or do it with far less than 100% output, so the effective delay is lower.
What’s the recommended way of adding GITD to this light?
Has anyone found a matching GITD o-ring? How about a glow paint?
A word of warning. Just noticed there was a 6.3mm metal shaving peeling off the positive end of my 18350 tube. Gladly noticed it before sticking in a battery. It was sticking inwards a bit so could have possibly shorted the plus and minus, since it was longer than the distance between contacts on the driver end (3mm).
My 18350 tube had that too, maukka, the shaving forms where the threading ends. I did not think much of it, just pulled it off, but you are right, there is a possibility of things going wrong if you are not observative and unlucky.
This killed Lexel’s Klarus G35 driver for the review or not? [Review] Klarus G35 supplied by Banggood, partially review as I killed the driver
Ok, it wasn’t a piece of metal from the Emisar D4, but from the G35 I presume, hehe. :smiley:
Buy a sheet of gitd foil. Then you can cut two stripes around 3mm wide and stick them around the inside of the light. There are two flat walls where you can stick them to.
TK yes he is screwed.
He needs also a soda can light.
Fuzzylogic have checked out the Q8 thread?
Just a pic to compare it to the S42. The D4 is superior in all aspects but one: USB charging.
But that is quite a big one for me though, a future version of the D4 with USB charging (and regulated maximum modes that temper those modern low Vf emitters a bit) certainly would be an improvement for me, even if that adds a few mm of length.
@djozz
it seems the S42 could be as short as the D4. There is a long tripod thread in the tail of the S42
I know, and the driver with USB socket and components probably eats extra mm’s too.
Got a link for the gitd foil?
I used this https://www.ebay.de/itm/141654400313
But I think you can find something similar in your country.
Thanks.
Mine showed up 2 days ago… I can’t put it down since then !
219C and grey, I just added a Convoy clip (slightly re-bended to fit)
How is the tint on the xpl-hi 3a.I got the nicha 219c version and was thinking about getting the xpl-hi mcpcb from international and trying it.I figured for about the same price as and xpl-hi i could have the light and 2 different mcpcb.
Never used or heard of GITD Foil, but I use this Products - Glow-On and it’s pretty impressive!
Th adhesive vinyl works best, it last about 8-12 hrs, at about the out put level of a trit, the paint (water based) not as long but is good for filling in the back ground of the board, but it is a PITA to use, I have bags of the powder too that I mix with petroleum/epoxy based paints, it applies easier if you thin it out.
On these smaller lights I just stick with the vinyl tape. I have a precision shim punch and knock out some different size dot’s to stick dead center of the triple and quad boards, then use a razor and straight edge to make strips, to run around the ID of the head or small strips just at the top or bottom of the LED’s or to make locator strips around the battery tube or head of the lights.
+1
If you’re only going to buy one light ever, this is the one to get.
That’s right. This D4 is very bad for the flashlight industry, and for the Chinese economy. :smiley:
It won’t work unfortunately.
I just measured my Zebralight clip and the “arms” are too wide. They measure about 3.6mm and the groove in the D4 tube is only 2.8mm wide.
It’ll work with a bit of grinding but not fresh out of the box.
