Amazing work as usual Tom. That 18 led light with all the wires is incredible. Thanks for all the pictures. :+1:
I did mod the Klarus G35 with the dead driver today with NarsilM driver
further testing showed that the indicator LED as locator does not shut down with low voltage when the battery gets depleeted from it
it draws not too much on my setup with green LED and 4.7kOhms about 85uA at 2.7V
so there is a parasitic drain that can kill unprotected cells if the light gets stored over a longer period of time with the locator on with almost depleeted batteries
BUT
when the light shuts down from LVP it starts to blink for low voltage warning when the light is in standby, but it does not shut down
even worse the blinking means the MCU is not in deep sleep and it draws more current
then it draws 3mA from the battery which can be within a few days lead to a overdischarged battery, as the battery is almost depleeted
By design, when the light is shut down in a low voltage state, it does the blink to indicate low voltage, as you say, but does it only for 6 minutes, then shuts down the MCU. So after 6 minutes, it should go into a "deep sleep" (power savings) mode. After the 6 minutes is up, it should turn off the Indicator LED before going into power savings mode.
So, did you wait the 6 minutes to see that occurs or not?
I'm pretty sure I tested this in the older Narsil version, but not in NarsilM, nothing was changed in this area.
However if your cells are pretty low but not in a low voltage state, and you leave the light with the main LED off and Indicator LED on for several months, or maybe weeks, depending, then yes - there is no smarts in the MCU running to determine low voltage, therefore it cannot shut the LED off, so it will over drain the cell(s). This parasitic drain is pretty low though, depending on what LED and LED resistor value you use. I've left several flashlights in this state with the Indicator LED on for months without noticing much battery voltage drop.
Here's the code:
// Be sure switch is not pressed and light is OFF for at least 5 secs
word wWaitTicks = 310; // 5 secs
if (LowBattState)
wWaitTicks = 22500; // 6 minutes
if (((!ramping && (modeIdx == 0)) || (ramping && outLevel == 0))
!IsPressed() && (wIdleTicks > wWaitTicks))
#ifdef ONBOARD_LED
// If the battery is currently low, then turn OFF the indicator LED before going to sleep
// to help in saving the battery
#ifdef VOLT_MON_R1R2
if (byVoltage < ADC_LOW)
#else
if (byVoltage < BATT_LOW)
#endif
if (locatorLed)
TurnOnBoardLed(0);
#endif
_delay_ms(1); // Need this here, maybe instructions for PWM output not getting executed before shutdown?
SleepUntilSwitchPress(); // Go to sleep
}</code></pre>
OK I didnt wait more than a minute in my Test
If it shuts down after 6 minutes thats OK
As I wrote with a medium resistor and 0603 LED the parasitic drain gets really low when the battery is almost depleeted which takes months to be a problem
I assembled a L6.
TA LDO 30mm PCB
NarsilM V1.0
XHP70.2
I Can not turnoff by E-Switch,like below link veido.
How to check?
It happens sometimes that a AMC7135 does not shut down completely
they are drivern over their voltage specs and their quality varies from different supplies
Solution is to unsolder them and find the damaged one
I reassembled a new driver.
The situation is the same.? :cry:
Remove the single AMC7135
then opposite of the FET
One thing for sure if you remove all 7135s its most likely gone
+1 with Lexel. I think I had the same issue. For 2S, you really have to have the "good" 7135's, and even still, it's risky. The XHP70.2 can be driven at high amps, so maybe it's more likely to fail?
I can not understand that all 7135 are brand new.
How to test the 7135 good or no good?
simple test
LED does not go out, you got at least one bad
LED gets out all good
I got good expirience with this AMC source
I ordered over 1000 there and had only like 15 bad ones on 2S drivers
https://de.aliexpress.com/item/200PCS-AMC7135PKFT-AMC7135-7135-SOT-89/32425181405.html?spm=a2g0s.9042311.0.0.ImdKd5
Is this the problem?
I think the 7135 are only rated up to 6 or so volts and with 2S lights your above/out of spec.
–0.3V to 7V
the problem is there are many cheap AMCs that are not even the original manufactor with different quality
What I can dicover sometimes on drivers if I do thermal calibration when I heat the driver up they start to leak and when cooled down they are fine again
often its way below moonligh level, just a few are that bad like you see it
Yes, they still usually work above that voltage, but every once in a while you get one that seems to stay on. (According to other people that have run into this problem)
Not sure if this has already been mentioned, but I was looking through the code linked in the Google Drive and there seems to be a bug in ModeSets.h
// 6 modes 0.8-2-5-10-50-max ~0.8% ~2% ~5% ~10% ~50% max
PROGMEM const byte mode7135Set6[] = { 20, 110, 255, 255, 0, 0};
PROGMEM const byte mode7135sSet6[] ={ 0, 0, 0, 0, 255, 0};
PROGMEM const byte modeFetSet6[] = { 0, 0, 0, 0, 0, 255};
The 6 mode set does not seem to have the “5 ” output set correctly. Looks like 255, 0, 0 is repeated twice for both 5 and 10%
Yes, looks wrong there. Not sure without looking what table it is.
Line 127 of ModeSets.h
under OUT_CHANNELS == 3
Yea, I didn't know about this one - definite bug, though it's hard to speculate what 5% and 10% mean on a particular light mod or build, since LED's and FET's make such a huge difference. For example in a 7X parallel XPL2 light, maybe you hit 25A is 100% at 10K lumens, so 10% being 0.35A is much lower than 10%...
I'll have to fix this/change this to something reasonable. Think I was using ~1,500 lumens max (typical max single XM-L2 or XPL moderately configured) as a guideline for rating the percentages.
I'm working on NarsilM v1.1 now (GT Buck driver support merging), so will get it in before I forget, so when it's released, it will be there.
Really, all these mode sets should be tweaked build/mod by build/mod since there's so many variations of build/mods. Unfortunately this is what you get when working with fixed amp output (7135's) and variable amp output (FET's) combined in one driver.
It was discussed to not use percentages, but just state what it is: one max 7135, 20% of a 7135, 45% of the FET, etc.
Yup completely understand the percentages are guesstimates. Just wanted to bring this to your attention since it seems obvious that two modes shouldn’t be identical.
