So… there happens to be a fairly popular 219B FET quad: the Astrolux S41. I have one, and I notice a distinct shift to a much cooler tint after a second or two on max with a Sony VTC6. I don’t see the shift with an LG HG2 or Samsung 30Q. Output was 2272 lumens at power on with the VTC6 and more like 2000 with other batteries.
The D4 has significantly lower resistance than the S41. That means more current, and the 219B won’t respond in a good way to that. Tint will get cooler, CRI will get worse and the emitters may be damaged. A 219B D4 without adding a resistor to the circuit doesn’t seem like a good idea to me. 219Cs do come in 90 CRI though, and they still have nice tint and CRI when driven crazy hard. Some do prefer the tint of the 219B (I’m one of them), but the 219C is getting tint deviation bins, so it’ll be possible to order more rosy versions.
Yeah that was one thing I did not know about 219b. As you and ToyKeeper have pointed out, it seems for high cri 219c 4500k 90CRI is the best option. But the bad thing is that it is not available. I do not know why they went with 82 cri 219c. Is it because of cost or availability of leds?
For the tint, I think the reason behind 219b’s beautiful rosy tint is its high R9 value. I do not think 219c can achieve this tint without that high R9 value.
219Bs in R9050 are usually a bit on the rosy side, and the R9080 in 4000K is reportedly not nearly as rosy as the 4500K. 219Cs in R9050 that I’ve seen so far aren’t rosy at all, however, Clemence reports that tint deviation binning is coming to the 219C and it will be possible to order bins that are more rosy or at least less green.
I have no insight in to why Hank chose the emitters he did. The 219C is widely available in 4000K R9050, which is used in production lights from Reylight, Kaidomain, Eagletac, Manker and others. It comes in other color temperatures and R9050 too, but the only one I’ve heard of in a production light is 5000K in the Astrolux S41. Clemence sells a number of color temperatures, so it’s not like they’re impossible to come by.
Sadly, neither is easy to remove in the field.
Overall I find D4 somewhat too floody and I don’t want to diffuse anything. But for a camping light, a diffuser would be good.
Nice data! The trend is a bit lower CRI when the leds are overdriven, but that would be too easy of course so with the last measurement it is the other way around :party:
After getting to know the new sphere a little better (adjusting baffle and auxiliary light, trying different input port diffusers etc) my numbers for the D4 got about 8% higher.
Max output is as follows:
VTC6: 3345 lm (480 lm at 30 sec)
18650GA: 2980 lm (895 lm at 30 sec)
Aspire 18350: 2880 lm (1570 lm at 30 sec)
Efest 18350: 2460 lm
Enercig 18350: 2630 lm
Thanks maukka, excellent data, as always. 100% 7135 efficiency is surprisingly low, I thought it is above 100lm/W, maybe I have over estimated the efficiency of 7135.
Am I too greedy to wish for a 1+N+FET driver to be sold in separate / available in new versions, I’ll be happy with N >= 4.
DrJones H17F Driver from MT Electronics seems nice, not sure if it fits.
I have been wondering about this, without giving too much thought. The most commonly known values for efficacy is probably what Cree or Nichia is stating on the spec sheet, meaning light output in lumens per Watt where the power consumption is that of the emitter itself.
Maybe the efficacy Maukka is using is not the power consumption of the led itself, but of the complete flashlight including the cell, where the power value is derived from the runtime? So then you will automatically get a lower efficacy.
Is this the case Maukka?
7135+219C is a pretty inefficient combination. The larger the difference between forward voltage and battery voltage, the more the 7135 just burns off the excess as heat, and the 219C has very low forward voltage. Combined with a buck driver, the 219C’s efficiency is much better.
Yes. Depending on the output level/runtime and approximated current draw, I have capacity data in Wh for most of my batteries. Total Lumen-hours over the runtime divided by battery watt-hours gives the lumens/watt. So the calculation takes into account the possible effects of the battery, leds and driver heating up.
In case anyone is wondering, Richard from Mountain has about 49 or so of these pocket nuclear reactors in stock now. I purchased the last three for my collection (5 so far) last night so if you are in the market for one of these, especially if you live in the US, mountain electronics.com is an excellent place to get them. They tend to sell out extremely fast, so don’t sleep on it if u are planning to buy.
Thanks for the heads up. I have to try the Cree XP-G2 S4 3D ~5000K - Neutral White. The only neutral 5000k and below I have not tried yet and he had them in stock. 1 more left I think.
