I plan to use 4 of the green XP-E2 when Richard gets the short tubes in, then it’ll be a little green meanie, running on the 18350 Aspire. I personally like blue output better, but the greenout seemed like the way to go and I haven’t done anything like that before lol.
Can anyone comment on the objective/subjective differences between all the NW options? Ideally I like pure white or a little rosy with high CRI. No purple to yellow transitions. Or should I wait til better emitter, probably Nichia, is introduced. Most recent purchases have been Nichia. Or if this has been discussed at length earlier, please point me in right direction. Thanks and Cheers!
No!
You need a sampling frequency 5 to 10 times of 15kHz
Nyquist is only for pure sinus forms and PWM is more rectangular form. With only double, you don’t know what you’re measure
As it stands right now, none of the emitter options is really satisfactory for me. The Nichia is too cool and has too low CRI. Both the XP-G2 3D and 5D has a purple corona and yellow spot.
If I were you I’d buy the 219c and if you don’t like it reflow to high CRI LEDs. Or if you don’t know how, send it to someone who can.
the 219C in the D4 are pretty White. Also under the quad optic the bean pattern remains uniform in color to the edges.
I don’t have an XP-L HI version to comment or compare. But that might be another option as White. Xpl Hi do pretty good under an optic.
The 219B will work but may not really like the heat that this light produces. The Vf is just as low as the 219C so it draws just as much current (15+amps), and with lots of extra heat stress because of the small host. I’d say 219C is the safer bet.
The N319 has a slightly warm tint, nice round beam with few artifacts (kinda have to spin it around looking at a white wall or ceiling to see the standard quad optic stuff)
At lower levels the overall tint is nice, there’s that off color hot spot when cranked up but it’s not much of a big deal when using it especially outdoors. It’s nice to have the cooler running light, 4 219 C’s on a 20700 is pretty intense. It’s noticeable how much longer it takes to really start heating up, so the 319 has merit in the big picture.
Words of Wisdom…
……within a relatively short period of tests with my experimental D4 (with Nichia 219b sw40 9050 - 93 CRI)
one of the leads to the stock MCPCB easily managed to relieve itself.
I assume you are going to buy from Mountain Electronics LLC ? I am sure he can make one for you, either reflow on the Noctigon MCPCB or on his own MTN Quad MCPCB, try and send him a PM he is RMM on this forum.
Yes, the 219B makes exact the same amount of heat as the 219C, so the ’ unsoldering capability’ should not be different.
The difference is that at 4A per led, the 219C is still quite happy (max is at 6.5A) while the 219B is right at its maximum output, and this is measured with the led extremely well heatsinked, which is not happening in the small D4.
Quite worrying btw that you guys managed to get the leads unsoldered. You did nothing to circumvent the thermal management when this happened?
