No, MTN offers different (but similar) drivers with the same UI.
As to UI…People, I warn you, don’t buy D4.
It’s dangerous. Ever since I bought it, whenever I think “Wow, what a nice flashlight, maybe I should get one”, a thought follows: “UI will suck”.
Then I start wondering about getting one modded.
If it’s clicky, I recognise it’s a terminal disease. But then start thinking about crescendo…and since I don’t trust this works as well, I decide not to get the light.
The entire light is excellent. Apart from UI, one of the things I enjoy every time is picking up the light and without looking at it finding the button via the raised section left and right of the button. Once the button is found quickly, pressing it gives such a nice tactile feel and feedback. So before you’re dealing with UI, the experience is already really nice.
I couldn’t agree more! The whole light oozes quality! It’s probably the best light to own, regardless of price. The only thing that I would change is the tint options, but that’s easy enough to do yourself.
Mtn is not selling the bare driver. However, Mtn HAS added the D4 firmware as an option to their line of FET+1 drivers in various sizes. The drivers with the D4 firmware are available now.
The driver is substantially identical in design to the mtn-ddm series with an attiny85. The packaging is slightly different, but that shouldn’t matter in most cases.
I didn’t mean you’ll never need another light. Quite the opposite, different needs call for different lights. But having used this UI, I know I will not enjoy about any light available.
The bar has been raised. Other manufacturers need time to catch up. I surely hope they do it soon.
The way I see it is not that you have a lux meter and a window and a doggie. The doggie is your cousin’s who lives 20 km away.
Anyway it may still be better than the average.
Though I mentioned it before, measuring directly would be another improvement.
However….I see in the simulator that you don’t model body temperature explicitly. I have not looked at D4 sources, so it may be different. Directly, this is the value that you measure during calibration. And this is the temperature that you’d like to limit; not LED temperature really. Is there some accuracy to be gained by adding another latency parameter?
I asked a while ago to clarify which XP-L HI bin did you use in the test. Could you clarify?
