Thanks for your responses. Now I get it. I think ToyKeeper is absolutely brilliant and I felt she wouldn’t include this feature unless there was some practical purpose that I didn’t understand. Now I understand. Thanks again….
Does anyone know if there’s plans to make a similar light in a larger body with bigger reflector? Hopefully with added heat sinking people with delicate baby soft hands like me can use it without welding gloves on.
There is indeed a thrower with a bigger reflector coming up next, from what I recall. Someone with a better memory will probably give more info and the name.
It’s most likely going to be a lot different in function though. Nothing like a floody quad.
have you tried lowering the Thermal Configuration to match your hands preference?
So many people are complaining about how hot the light gets, and it has a user configurable thermal sensor…
Why doesn’t anybody use it to make it not burn your hand?
I really like the 100% regulated output level. At around 150 lumens it’s approximately between levels 3(80 lumens) and 4(240 lumens) on my E2L, S2, and BLF A6 which are my most used modes. I have 7 modes enabled on all of them counting moonlight the S2 and E2L using Bistro.
I have a question about perceived brightness that came to me in my sleep. I understand that to double what the human eye perceives you need an exponential increase in light, but when using floody optics where the output is less dense, thus less bright to the human eye, does that even out the correlation between perceived brightness and lumens?
I hear there’s an Emisar D1S coming up soon. Hank estimated it has 120 kcd / 692 m of throw.
You mean like this?
Black Magic
(And there you go, Zanflare F1 is off the to buy list.)
… Do we get to see some pictures of the D7 as well…?
Shoot! Just take my money Hank! Looks like Emisar is going to be a staple in our collections gentlemen.
I sense a large drop in my rainy days fund in the next couple of months
I’m quite interested in hearing more about the D7 too.
Wow! I was going to order a Convoy C8 but now I’m going to wait for this!
I’m trying to build a callous and toughen up!
Dang Wang! Another must have.
That’s such a great development Hank. I would also love to see the body with screw on pocket clip if possible.
A wild Hank Wang appears outside the great firewall !
Is that D7?
And are the tubes of those lights interchangable?
It’s D1. From memory, 40 kcd. It seems to use XP-L HI. Can’t wait.
ADDED:
Confirmed, around 40 kcd. Will be available
Man count me in for 1 and for D7 too
You’d better find more skilled designer
