TK's Emisar D4 review
I sense a large drop in my rainy days fund in the next couple of months
I’m quite interested in hearing more about the D7 too.
Wow! I was going to order a Convoy C8 but now I’m going to wait for this!
I’m trying to build a callous and toughen up!
Dang Wang! Another must have.
That’s such a great development Hank. I would also love to see the body with screw on pocket clip if possible.
A wild Hank Wang appears outside the great firewall ! :smiley:
Is that D7?
And are the tubes of those lights interchangable?
It’s D1. From memory, 40 kcd. It seems to use XP-L HI. Can’t wait. :slight_smile:
ADDED:
Confirmed, around 40 kcd. Will be available
Man count me in for 1 and for D7 too :smiley:
You’d better find more skilled designer :frowning:
Thanks for the info. I am wondering the classification of D1, D1S and D7, correct me if I am wrong,
So D1 is a small sized balanced light, not as much throw as C8,
and D1S is going to have a bit more throw than D1,
and D7 is going to be a flood light like D4, but with 7 emitters.
Are there any plans on other Dx?
Added a little DC FIX to mine and the partial squareness is almost entirely gone and it’s a tad bit floodier. My approximating shoebox doesn’t see any more light loss than whatever 1 of my “calibrated” lumens is worth at 100% 7135. I also tried melting/burning it off with repeated turbo runs with no failures. Now I can hold off from buying more optics for the time being.
I picture the D7 being very reminiscent of the DQG Tiny. As my anticipation heightens I’m hiding my credit card.
Yes, D1 and D4 tubes are interchangable, meaning D1 can also use the 18350 tube to become a tiny thrower.
D1 around 40Kcd, 1*XP-L HI, ultra small body, slightly bigger than D4 as it can be seen above, true all arounder for size and throw
D4 around 120Kcd,1*XP-L HI, excellent throw, small body
D7 is using 7*LED and 3*18650
Same UI on all D series from Emisar
I’d call D1 a pocket thrower. Less throwy than D8, but much smaller.
D1S is 110 kcd, so just a small thrower.
D7 has 7 emitters and 3 18650s, most likely very floody, though if they keep the styling (head significantly larger than body), it could be throwier than D4 (w.r.t. beam profile, not just intensity). I haven’t seen any pictures or written details, so this is a wild guess.
I’m not aware of any other Emisar lights in the pipeline. I’d love to see some zoomies. And 21700 battery tubes…
Added: Hank beat me to it. :slight_smile:
:smiley: D1S?? :wink:
Hank, will D1S be available with 26650 tube?
I posted this recently over at the “What did you mod today” thread. Thought I should also post it here, since this is the D4 thread.
I asked the same question. It seems (did not look above :person_facepalming: ) there is definitely a D7 coming 3x18650. My question is more of a DQG Tiny 26650 III size (but a little bit longer to avoid the issues shortness causes) so maybe with support they will go for a D? like we keep asking about?
Perhaps is the moment for add option for 20700 tube in next models….be prepared for the future….
I like the D1 and perhaps D1S!!
I epoxied a pretty thick and strong magnet to the outside of the tailcap. Not as clean looking as CRX’s magnet inside the tailcap, but it works for me.
