Thanks for the info. I am wondering the classification of D1, D1S and D7, correct me if I am wrong,
So D1 is a small sized balanced light, not as much throw as C8,
and D1S is going to have a bit more throw than D1,
and D7 is going to be a flood light like D4, but with 7 emitters.
Are there any plans on other Dx?
Added a little DC FIX to mine and the partial squareness is almost entirely gone and it’s a tad bit floodier. My approximating shoebox doesn’t see any more light loss than whatever 1 of my “calibrated” lumens is worth at 100% 7135. I also tried melting/burning it off with repeated turbo runs with no failures. Now I can hold off from buying more optics for the time being.
I picture the D7 being very reminiscent of the DQG Tiny. As my anticipation heightens I’m hiding my credit card.
Yes, D1 and D4 tubes are interchangable, meaning D1 can also use the 18350 tube to become a tiny thrower.
D1 around 40Kcd, 1*XP-L HI, ultra small body, slightly bigger than D4 as it can be seen above, true all arounder for size and throw
D4 around 120Kcd,1*XP-L HI, excellent throw, small body
I’d call D1 a pocket thrower. Less throwy than D8, but much smaller.
D1S is 110 kcd, so just a small thrower.
D7 has 7 emitters and 3 18650s, most likely very floody, though if they keep the styling (head significantly larger than body), it could be throwier than D4 (w.r.t. beam profile, not just intensity). I haven’t seen any pictures or written details, so this is a wild guess.
I’m not aware of any other Emisar lights in the pipeline. I’d love to see some zoomies. And 21700 battery tubes…
I asked the same question. It seems (did not look above :person_facepalming: ) there is definitely a D7 coming 3x18650. My question is more of a DQG Tiny 26650 III size (but a little bit longer to avoid the issues shortness causes) so maybe with support they will go for a D? like we keep asking about?
I epoxied a pretty thick and strong magnet to the outside of the tailcap. Not as clean looking as CRX’s magnet inside the tailcap, but it works for me.
I’m not convinced the D7 is a flooder. The DQG has seven emitters from a single 26650, so from a thicker triple 18650 you have significantly more space in the head. I can’t imagine the individual optics just placed further apart.
It would be more interesting to have larger reflectors, so probably metal reflectors instead of optics as losses would be high with the latter? With these larger reflectors, the light would move away from the typical flooder beam we’ve seen from the M43 and D7, and have a much higher lux/lumen ratio. So in terms of beam profile, it would be something between a flooder and a thrower, something comparable to an L6 or Q8?
A pure flooder would make the D7, although perfectly executed no doubt, just “another flooder” in a slightly different form factor. But this light could be a game changer… Just my thought I had for a while… :partying_face:
I really would like to see the introduction of a shortcut to maximum sustainable level in the next release of firmware. Maybe even make it a selflearning function, based upon the max temp setting and real use of the flashlight (with the particular LED:s and cell).
I love my D4:s and will purchase the D1 and the D7 when available.
Lanyard hole and optional real high CRI versions would make my day.
DQG Tiny 26650 3th has 33 mm head diameter. This is enough for a TIR with individual lenses of a size similar to Carclo 10 mm ones, like in D4. I don’t know what the lens size actually is there or what lens is it. I tried to find the manufacturer, without success.
D7 body size is going to be like 42-43 mm in diameter. With a somewhat larger head, it’s going to fit a TIR with 16 mm cups. This is enough for 10 cd/lm with a good lens. I guess with a perfect lens this could be beaten somewhat. Use of a floodier lens wouldn’t surprise me either. Somewhat larger head (and thus lens) is possible too. Anyway, I don’t view D7 as anything but a flooder, though I do expect it to be somewhat throwier than D4.
ADDED:
Forgot to mention, throw figures above assume XP-L HI.
Thanks for the figures Agro. With increasing reflector and head size, so does the lux/lumen ratio. I’m more interested in lux value of the D7 than amount of lumens.
