. Disappointing numbers of just under 900 lumens, under 200 kcd, and modes work differently than advertised, manual is in Chinese. Driver is labeled Shadow, light and box labeled Galuxia. It's driven at 2.55A in the highest mode, so if it was driven better at 3.5A or so, it just might achieve the listed specs.
. Disappointing numbers of just under 900 lumens, under 200 kcd, and modes work differently than advertised, manual is in Chinese. Driver is labeled Shadow, light and box labeled Galuxia. It’s driven at 2.55A in the highest mode, so if it was driven better at 3.5A or so, it just might achieve the listed specs.
+1, but mine now runs a xhp35 HI to 1650lm and 280.000cd, it’s a nice host (with some DIY to fit a 24mm driver)
Like that Amutorch. Buy the host for $3x, add dedomed SST-40, add FET+1 driver, improve thermal and electric path and have a 300 kcd light for <$50. Not bad me thinks.
What is the UI like ?i ordered this one bcaue the UI seems usable ad throw numbers were appealing…
Any way of reducing the sense resistor to increase current maybe ?
"-X3-, is there any place in your house without a flashlight ?"
I ordered two, got 2. Each one has a different driver, different UI - dunno which is the "newer" one - think it's the red driver, dunno for sure.
If you get the red Shadow driver, then the power switch is ON/OFF, e-switch is mode changing - 2X is strobe.
If you get the green Shadow driver, you can use the e-switch to turn it ON and OFF, and the 2X click is turbo, which is more amps than the hi/turbo of the red driver.
- what a disaster, but mine are getting a FET+1 or 3 channel driver anyway.
Good catch. Though more like AL35-1.
Comparing with SS35-1 it has a different keys attachment (worse for me). And SMO reflector.
I said it once and will repeat: I’m in for AL35-3.
Hum, those references would be to aluminium construction, right?
As far as I recall the SS35 has a weird looking beam (greenish) and puts only 400lumens from a 18350. Maybe a “3 led” version could be interesting yes, if the output raises accordingly
Thanks for the link freeme! Despite not being able to read Chinese and despite not all the information can be translated to english (therefore not being able to read the specs), it was easy to see the 2nd light you showed!
Looks like the Jaxmnve M3! But the modes H-M-L-Strobe-SOS… Too much old school!
The first one, “AL35”, looks nice despite the beam issue! Thanks for showing these and other less know lights and please keep doing that
I have two of this light! (different brands, same light) One from Amazon and one from Gearbest.
I really like it! I think the best low price budget light I’ve ever got!
Here’s some info on it:
The light is sold almost everywhere under MANY different brands. Ebay, Amazon, Aliexpress, Gearbest, Fasttech, etc. etc.
The one I got from Amazon has a noticeably more neutral tint than the one from Gearbest.
.(Gearbest has two brands of this, a no-brand (one I got) and an HKV brand.
Fasttech version you linked shows Hi > Mid > Lo but most versions of this are stepless dimming/ ramping.
.Could be a misprint on Fasttech, they do that a lot.
The Good:
It’s very bright
Tint is not too cold 5000-6000K
Switch extremely easy to find in the dark (big protruding red bezel ring) Switch is very effortless to click, feels nice.
Always starts on High Simple UI: Single click ON – click again OFF Hidden strobe – double click
Ramping UI 4 seconds from H to L flashes twice at lowest and at highest.
Well defined hotspot, deep reflector has decent throw
Springs on both ends inside fits about any battery I tried
USB charging cover fits flush and snug
Glass lens
The Bad:
Switch is very effortless to click, feels nice, however can easily switch on accidentally.
No way to lock-out, cannot mechanical lockout (non-anodized tail threads)
.Because of these two cons I don’t recommend for pack or carry around, makes an EXCELLENT home utility light though.
The reflector is threaded in and the MCPCB is mounted within the reflector, (I haven’t disassembled further than just enough to see that)
Bangood has a zooming version, also stepless dimming (XANES brand, currently on promo $5.89): https://www.banggood.com/XANES-1302-XM-L-T6-1500Lumens-Stepless-Dimming-USB-Rechargeable-LED-Flashlight-p-1202115.html?rmmds=mywishlist&cur_warehouse=CN
Zooming version also sold everywhere under MANY different brand
Fasttech has a 26650 zooming version (UltraFire branded) comes with free knife. 26650 zooming version also sold everywhere under MANY different brands. https://www.fasttech.com/product/7455401
That light is aka the CFG01. I have one. Not bad for the $6 or so I paid for it, in fact, I like it more than I think I should. I never use it though. I’ll probably end up giving it away to a nephew, or a starving student, or load it with an old laptop pull and stick it in a car plugged in to a USB charger for emergencies.
You will need to login into your TaoBao account first.
@1theDeals
That’s the thing. I don’t have one
Maeerxu X80
http://item.jd.com/17174708135.html
@1theDeals
Light rebrand to AMUTORCH JM70 XHP-70 3500Lumens 5Modes Brightness Searching LED Flashlight
@1theDeals
I got in the XPL HI single cell version of this light, ordered from BG here for $39: https://www.banggood.com/AMUTORCH-JM70-XPL-HI-1200Lumens
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
$22
New M3 clone?
@1theDeals
These are 2 different lights, right? Any other info on those freeme?
EDIT: the first one is the SS35?
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
About the second light, any clue?
freeme, you like to tease us
Where can I buy this!?
If it can be modded would be a great host for single 219C/XP-HI and 15mm driver with narsil.
USB power meter/tester thread
+1
More info please.
Freeme, what a tease!
Not sure if you guys are able to access the store from this link.
https://chaoqianhw.tmall.com/category-1296063674.htm?spm=a1z10.3-b-s.w50...
@1theDeals
pavol77
@1theDeals
WARSUN XHP70
@1theDeals
On swiatelka.pl I’ve seen a recommendation for:
https://www.fasttech.com/products/9634574
According to the owned it charges. Thermally is OK. And in general is said to be good for the price.
I can’t help but note that there’s a similar looking light for less on Ali:
https://www.aliexpress.com/item/Cycling-Accessories-Super-Brigh-Zoom-5-M...LED-USB-Rechargeable/32818185118.html
The Good:
The Bad:
The one I got from Amazon: (2-mode version) description shows H > SOS but is actually ramping with double click strobe not SOS, description also shows zooming but it ‘s not. https://www.amazon.com/gp/product/B076CLT8JY/ref=oh_aui_detailpage_o08_s...
The one I got from Gearbest (un-branded) 5000-6000K: https://www.gearbest.com/led-flashlights/pp_604347.html
Other one at Gearbest (HKV brand) Stepless Dimming, only this one shows CW 6000 – 6500K https://www.gearbest.com/led-flashlights/pp_1295273.html
I have one of these and is the one that I use indoors and have near my bed. Excelent for $8.
Max
New quad flashlight in the work.
@1theDeals
Nightwatch Ni02.
@1theDeals
Ni02 is the black one? https://world.taobao.com/item/557203257383.htm
What is the smaller silver one?
