need S2+ pills
23 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 2 min 22 sec ago
need S2+ pills
I need some S2+ pills to have extras, kinda like having spare P90s.
FT had (currently “out of stock”) https://www.fasttech.com/products/1583601 which is a mislabelled S2+ pill, but I doubt they’ll be getting it back. Lots of OOS items eventually just become discontinued and that’s that.
Someone in a thread here about an S2 pill mention one from KD, but that’s 404ed. Wouldn’t do me much good, as that’s the longer pill and I need the shorter one from an S2+.
Checked MTN, no joy.
I’ve got whole hosts, but I’d really just rather have extra pills to play with, than have a bunch of declawed S2+ tubes lying around.
Any ideas?
rizky_p
rizky_p's picture
Last seen: 2 weeks 18 hours ago
Have you asked Simon?
Lightbringer
I understand he’ll supply replacement parts like O-rings (probably for free if you ask nicely), but wasn’t sure if he’d sell, say, 5 pills.
Somewhere on AX, I think. I’ll have to find the addy unless someone can supply it first. Big Smile
aL1
aL1's picture
XXX-Man
XXX-Man's picture
Last seen: 9 hours 54 min ago
Simon sent me S2+ pills with my order when I asked him for a small fee.
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
MaleNurse
Last seen: 1 month 1 week ago
Please get back to us on Simons reply. I too would like a few pills for the S2+.
Syndicate
I bought these from kaidomain.com they fit the S2+ but are a bit short for my liking, may be fine for you.
Yokiamy
Yokiamy's picture
Last seen: 12 min 55 sec ago
Tried kiriba-ru his thread?
I bought a copper spacer for my S2+ triple from him, he even sells copper pills with retaining ring
kiriba-ru
kiriba-ru's picture
Last seen: 2 hours 22 min ago
I think ts need stock brass pills.
There are several blf members that modded many S2+ and changed pill with copper one. They should have stock pills that they dont need anymore.
Henk4U2
Henk4U2's picture
Last seen: 11 hours 15 min ago
Sure, but when you look at the size, it’s the same as the OOS from Fasttech.
When you like using a TIR (which is longer than a standard OP S2+ reflector) you need to compensate it with a shorter pill.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
djozz
djozz's picture
Last seen: 11 hours 19 min ago
Did not know about the short KD pill, good for 18500 conversions (sand off the rim, triple mod).
It is rather expensive though…
Edit: no, that pill is still too long for the conversion. Perhaps combined with the Jaxman E2L 18350 tube, that one is a few mm longer than Simon’s 18350 tube.
Lightbringer
aL1 wrote:
Convoy Flashlight Store (Simon)
Kewl, tnx!
Might be missing it entirely, but I didn’t see any “contact me!” link. How do youse contact him?
I’d get a couple of those ZWB filters at the very least, and some forward-clickies if they’d fit C8s (and hopefully others!), but he doesn’t list any S2+ pills at all. I’d be able to bundle all those together in one order if I could order those pills as well.
Lightbringer
Yokiamy wrote:
Tried kiriba-ru his thread? I bought a copper spacer for my S2+ triple from him, he even sells copper pills with retaining ring
Not yet. Big Smile
Lightbringer
kiriba-ru wrote:
I think ts need stock brass pills. There are several blf members that modded many S2+ and changed pill with copper one. They should have stock pills that they dont need anymore.
I wouldn’t sneeze at a copper pill. Big Smile
Even with brass, my S2+ turns into a curling-iron when left on high too long. Anything to shed heat from the chip, and warn me quicker to turn it down… Big Smile
MascaratumB
MascaratumB's picture
Last seen: 6 hours 36 min ago
Lightbringer wrote:
Kewl, tnx!
At AliExpress Store there’s a “Contact Seller” button! (under “Service Center”)
BTW, some measures of Convoy (left) pill and the one mentioned of KDoimain (right) (just received it)!
Inner measures are the same so they take a 16mm plate and a 17 mm driver!
vwpieces
vwpieces's picture
Last seen: 4 months 1 week ago
S2 is the shorter 8.4mm. S2+ is the taller 13mm.
The copper pills Kiriba-ru makes are for triple builds with integrated driver retaining and external threads. Would be too long for single emitter.
And you may need to be logged into Ali-Exp to get the contact sell button.
aL1
aL1's picture
Ditto, I think you need to be logged in....
Lightbringer
Aha. Thought “Service center” and “Contact now!” was like contacting Amazon (ie, AX admin) vs the seller.
Yep, assuming “si***ao” is Simon, I just sent him email.
Thanks, y’all!
Lightbringer
aL1 wrote:
Ditto, I think you need to be logged in….
Oh yeah, it did ax me for a login and password, so I did in fact log in.
If I don’t have js turned on, for some reason AX insists on feeding me the page in spanish. ??
Lightbringer
Oh, as far as dimensions, I’m not fretting it. Stuffed the TIR in there, screwed it in snug, battery fits fine. Worst case, Mr Spring should take up the slack.
Jack Kellar
Jack Kellar's picture
Last seen: 18 hours 26 min ago
Thanks, I was about to say that.
Still, how does the S2’s pill go with an S2+ reflector? Does it even work, or is the slack excessive for even the longest 18650’s?
MascaratumB
Thanks for clarifying the things, I totally forgot to do that Facepalm
I didn’t knew the smaller is for the S2, I never had one, I’ll just use this pill for a mod.
Thanks Thumbs Up
Jack Kellar wrote:
Thanks, I was about to say that. Still, how does the S2’s pill go with an S2+ reflector? Does it even work, or is the slack excessive for even the longest 18650’s?
I guess is like Lightbringer said, the spring will play an important role here Wink
BTW, with the retaining ring in the back of the pills, drivers like biscotti or others that have extra 7135 chips in the back won’t fit as the ring doesn’t screw in properly ! I tried and it doesn’t work, so soldering is the best option!
Lightbringer
Wellp, I ordered some zwb2 filters and forward-clicky switches, and he said he’d throw in 3 pills for free! That was really really nice of him!
