I measured 17.9A at the tail with a clamp meter on my L6 and it's surviving so far. The cells will drop pretty quick at this rate, and the heat is a problem of course. On LK cells w/solder top, it started at 9,100 lumens, dropped to 8,230 in 30 secs.
I have over (12) XHP70/70.2 lights in my keeper (never to sell) collection, and this little UTorch UT02 is one of my favorites!
Machined out the head for a 32mm Maxtoch DTP board, 70.2 P2-1A Lexel built T/A Narsil driver, with reasonable out put 9amps at turn on and just over 8 amps around 30-40 seconds, or how ever long it took to try and grab the shot of the clamp meter in 3 attempts…
i am not sure how to know if the reflow is any good, maybe when i “bop” the led it created voids in the solder. i will try again. without “bopping” the led. any reflow tips?
maybe after this i will learn to accept less than insane maximum
when i bop the led some solder did squirt out, i then push the led a tad to see if it will pull itself back onto the pad. i wonder instead of bopping to squirt, i would bop and hold till the led cools down for better contact.
the led did go blue before “poofing”, long enough for me to realize “oh sh!t” that is not the color i want.
i wish Narsil have a ramp speed setting, current setting is too fast for me to stop it from going full power, a much slower speed would allow me to stop once i see some blue tint.
Dunno, only a wild guess here because of course the GT is the widest head light around.
I noticed with the 3 XHP70.2 P2 3B's in the MT03, I don't notice the yellow ring around the halo. Not sure it made a difference, but I scraped off the yellow on the edges of the LED. Pretty sure my MT07 and L6 have the yellow ring.
I'll have to try it on the L6 or MT07 and see if it makes a difference.
You think that might reduce the yellow around the main beam? Let us know of your findings, I was wondering if a sliced dome close to the surface of the die might reduce that too…
I reflowed this XHP70.2 N4-3A 5000K from fasttech on my Acebeam EC50 Gen II 5000k, but there isn’t any difference, my integrating sphere shows the same lumens for all modes with both leds
This is not that surprising. I am sure that light uses a regulated driver. At the same currents the total wattage is less due to the lower Vf of the LED. This means that while it is more efficient it doesn’t produce anymore lumens until you drive it harder.
The same thing can be seen in my XP-L vs XP-L2 test (the XHP70 uses XP-L and the xhp70.2 uses XP-L2 dies, so it is a great comparison).
Basically you would need to boost the current to see more lumens. Right now you should get an improvement in battery life.
It’s also because the LED needs to be in a higher Bin to actually be birghter. An XHP70.2 in P2-Bin should make the light brighter at the same current. The differences are small though…
The MT03's beam looks great - no noticeable yellow halo, but on the L6, it seemed to make no difference whatsoever. Maybe the shallow OP reflector really helps, big time, dunno.
I tried slicing a XHP70.2 dome. Little more silicone came off than what I wanted. Some yellow phosphor came off, and looked like a broken wire. I could only see 1 wire connection, so thinking it was the one extra wire, like the old CREE's have - forgot what it was there for. Looking at the phosphor of the LED, I could not tell any was missing - still solid yellow. The LED lit up ok, but when I cranked it up, started seeing smoke - didn't have the reflector in yet, so I could not tell where the smoke was from. But the MT07, one big light, got pretty warm, I continued with high amps to see where the smoke was coming from. Went too far with it I guess, and a black spot developed about in the middle. I dunno -maybe the slicing, maybe the extreme high amps - didn't measure them, but with a 404 FET, 2S2P of Sam 30Q's, 18 AWG wires, spring bypasses, thinking the amps were wayyy up there.
With no reflector, the tint looks pretty darn good - nice creamy white from a P2 3B.
So any ideas if it was slicing, the broken wire, or the high amps was the cause of smoking the LED?
