Convoy L2/L6 modding thread
The original driver is a LD-29. Kaidomain’s LD-29S should work. 3A at 6V.
Or if you can fit it in: FastTech’s 4A driver.
XHP50.2 might be a better fit as a thrower.
I am still selling the 4. batch, about half of the ones I can build are sold
I’ve got a whole write up on how to do this in my signiture.
Lexel can get you a driver.
Simon at Convoy can get you a translucent side switch.
Liitokala are definetly good. I’ve got the blue and the newer ones are black, but they all perform about the same. I’m getting 17.3 amps at 30 seconds.
It’s too dangerous to have built in charging with series cells. Just get a fast charger. I’ve got the Xtar Sv2 rocket which can charge 2 26650 at 2 amps each. It makes for quick charging. Sometimes they are on sale. I got mine for about $19.
Keep in mind that slicing the dome always looses you lumens, but usually creates a smaller hotspot which gives more distance. I tried this on a xhp70, but didn’t like the loss of lumens. I prefer the dome on. I kept the dome on my 70.2 as well. I haven’t done any lux measurements to see what the distance is, but with such high lumens, 8,000 maybe, the range is very good. I wouldn’t be surprised if it was over 900 or 1000 yards.
Keep in mind though that when your making 120 watts the light will heat up fast. I only use full power on rare occasions like testing or if I need max distance. Maybe 30 seconds at most with full cells and full power.
It also tends to burn through braided copper spring bypasses. I had to use a thicker copper wire for a bypassed tail spring.
If i try a 50.2 on this driver will it go up in smoke?
You bet-cha! :smiley: POOF! I gave up on them, I still like the old 50’s better for throw!
The 70.2 won’t, neither will the old XHP50
I been thinking about building this what do you think about it, Convoy l2 with 20mm mtnmax buck driver,xhp35hi e2,and using 4 26350’s or aspire 18350’s with spacers.It says 2.5 amp max on 12v how many lumens should that be good for?
2000+
I have several XHP35’s running the MTN.MAX and LD-2 M2 at 3amps 4-26650’s 4-26350’s 4-26500’s 4-18500’s 4-18350’s but not in my L2 anymore.
I have the Mtn.Max 3amps drivers in my Jaxman X6 (E4 1C HI) Convoy L6 (E4 1B HI) Trustfire X7 (E2 1A HI) Nitecore MH20GT (De-domed HD E2 1A) Trustfire T90-2 (E4 1B HI) Lumintop SD75 (E4 1B HI) TN42 (De-domed HD E4 3C) and a TK61 (HD E4 3C) but they are running the LD-2 M2 Linear driver at 3amps.
So 2.5amps is relatively SAFE! Good Luck with the focusing!!
does mtn have a buck driver that wil do 3 amps on 12V XHP35?
In most cases, 3A is too much for the XHP-35. Stay at 2.8 or below and you’re good.
Jeez Kawi, you must really love throwers. Do you think any of your hot rod lights could out throw the blf GT or is it going to be the extreme thrower?
Jeez with that huge reflector it should be extreme stock, but lets see what it does at 3 amps and one of these De-domed E2 or E4 HD XHP35’s in it, or at 6.5 amps with an old XPG2 or one of the DE-domed W2’s in it, should warrant the extreme title then eh or until a Bigger reflector light comes out……hmm….
LD-2 M2 Linear drivers at 3amps should work well in my GT, plenty of heat sinking in that truly Monster Light!
Been busy de-doming…… :wink:
Yep! 4S 12v 3amp
R075= 2.5 amp R068=3.0 amp 20-22mm is the smallest up to 27.5mm that I have in my lights.
E-Switch momentary too, I asked and Richard RMM made them for me!
T/A’s test showed 2.7-2.8 amps was the Max out put Lumen wise on the LED’s he tested, I don’t worry at all about the .2 over current the E2-E4’s handle it well so far. Tune it down by adding 2.5” 24awg leads, I tested 2.8amps on one of my TN42’s doing that. But since shortened them and added a de-domed E2-1A and the tint is way better than the de-domed E4-3C!
Finally……
LD-3
3A 2S for XHP50.2
2 Thermistor
XHP50.2
40H(2-step) 4000K H4 90CRI
LED Reflow soldering
LD-3 17mm to 20mm
soldering
Smooth light cup
L2
Left:XHP50.2(L2) 、Right:XPL Hi (L2)
hi
i got my TA Driver NarsilM from LEXEL today !
I changed the xhp to XHP70.2 P2 bin and this TA driver. What a surprise !!! I just doble the output. Ramping is sooooo good.
Ceiling bounce test with MT07S, L6 modded MTN Fet driver silver , L6 modded TA driver black, MF01. The original L6 was at 202 with the same setup
That really is a sweet mod to the L6, between the output gains and the new functionality it’s like a whole different light. Nicely done! :slight_smile:
Thks
Also I forgot to mention that I swapped reflector from op to smo
some beamshots tonight
MT07S turbo:
L6 modded 70.2 P2 BIN + SMO + MTN FET driver
L6 modded 70.2 P2 BIN + SMO + TA FET driver NarsilM UI
New to the forum... So I just got the L6 and I am a little disappointed with how bright it is. Maybe I just had my expectations too high, but overall it doesn't seem all that much brighter than my 1000lm Fenix TK16.
I would like to modify it to get a more focused beam and more power overall out of it. However, I am going to be using it primarily for work and being able to keep it at the max brightness for extended periods of time is important. I'm fine with putting it at a lower power setting once I get to 5 min or so. I plan to get a SMO reflector and a XHP70.2 LED for it as both should help get me in the direction of what I want without creating additional heat. I've been reading through a ton of different threads on this forum, but I still have a few questions.
  • Roughly how long can the stock L6 be left on turbo before it is going to damage itself due to heat? I wear gloves so I don't care that much about it getting too hot to hold.
  • Would increasing the amperage to the LED significantly reduce (to where it is now below 5 min) how long the light can be left on turbo? Essentially, is the stock L6 set to about the max power you can pump through the LED before it will start to fail within 5 -10 min, or can I get more out of it with a resistor modified driver or a different driver like the Texas Avenger?
  • What usually fails first due to heat failure? The LED, driver, or batteries?
Thanks for the help.
I don’t think any of the modded L6’s can do a full 5 minutes on turbo. Stock can do it until the batteries run down, but it gets super hot.
Mine is probably over 8,000 lumen and I don’t like using it on turbo for more than 20-30 seconds. It gets hot quick!
The stock L6 should still blow away the TK16. Maybe have 3 or 4 times the hot spot size as well.
The SMO does help to reduce the hotspot size and improve distance.
The 70.2 just gives you a smoother hotspot with maybe more efficiency. I’m not sure how it will effect a stock driver.
The amount of light of the L6 is good, but its not a dedicated thrower
You can get more throw with a smaller light and small die LED like XP-G2, but with only 900 lumens
