MtnDon's Entry, 2017 (5th Annual) BLF Old Lumens Contest, Handmade Category
68 posts / 0 new
MtnDon
MtnDon's picture
Last seen: 20 min 31 sec ago
I have a mental vision of what this project is supposed to look like, nothing on paper and especially nothing with CAD or even Sketchup. So I guess this is a firm commitment to build. Hopefully I finish.
First image: 1/2” copper slip type pipe cap and a switch boot. Some raw parts
I need a hole drilled in the center for the boot to fit through. Filed a bit and center punched
The drill setup. A wood block clamp to hold the round cap. A step drill in the drill press.
The hole came out more or less nicely centered so this one is a go. This is the second one as the first was off center enough to look “wrong”. The burr from drilling has been cleaned a little with a file.
The boot fits! (not the sharpest image,,, I guess I moved)
That is all for right now. Next I’ll clean the copper edges up and make it look nicer.
Edited by: MtnDon on 08/31/2017 - 18:09
FmC
FmC's picture
Last seen: 6 months 3 weeks ago
It’s definitely some form of commitment!
Good luck with the build, MtnDon Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
Nice start Don. Love the vice with its custom built soft jaws.
CRX
CRX's picture
Wink Thumbs Up
MtnDon
MtnDon's picture
It got smoother & shinier overnight.
Now, where’s the rest of this light?
DavidEF
DavidEF's picture
Last seen: 3 days 10 hours ago
Looking good already! Cool Thumbs Up
- The YKK Philosophy
MtnDon
MtnDon's picture
I completed the first stage of my wall of bookshelving and have a couple afternoons free before getting back to that home project, so I got back to this light project today.
Here is that first part I made and the section of wood I will cut the next part from.
I’ll be using about 6 inches of this if I only have to cut once. This piece has slowly been getting smaller since I bought it about 25 years ago. Then it was about as long as I am tall, a few inches under 6 feet.
I’ll be making a hole with this drill. 3.25” (about 8.25 cm)
The clamp makes a decent safe handle
LOTS and lots of shavings!
Drilling takes a while as I stop and let the bit cool every half inch or so. Can’t use a water or lubricant bath as with metal. Pity. The bit needs a sharpening as it is also making a lot of dust as well as shavings.
For the curious… this is the base board I used under the padauk block to prevent tearout as well as to keep the bit from hitting the cast iron drill press platform.. The drill cuts shavings between 0.4 to 0.5 mm thick.
That’s all for now. Thanks for looking.
MascaratumB
MascaratumB's picture
Last seen: 4 min 29 sec ago
Curious to learn and see where it will go Wink Good work Thumbs Up
Turningbluechips
Turningbluechips's picture
If you ground/sanded a taper toward the shank on that hole saw boring bit you have there (I’d like to know what it’s actually called) you will get rid of most of the heat issues. HSS really doesn’t like heat, for wood you could try wax as a lubricant. Also peck drill and high rpm.
CRX
CRX's picture
That’s some drill bit! And a nice chunk of wood Thumbs Up
MtnDon
MtnDon's picture
The drill bit is a Forstner bit, invented about 150 years ago by a Benjamin Forstner. Usually they do not have a toothed rim like this one, just a circular rim. They are meant to cut/drill a flat bottomed hole. The flat bottom holes have a slight dimple in the center where the centering spur protrudes slightly. This one was specifically sold as a clock making bit… drilling a recess in a wood blank for a small battery powered analog clock movement. With a drill press you can drill overlapping holes, even drill at an angle if the work piece is clamped down to the table.
MRsDNF
MRsDNF's picture
What CRX said. The block of wood is a lot bigger than it looks in the first picture on my phone.
lostheplot
lostheplot's picture
nice start .keen to see the result
sorry all images down
thanks photobucket
MtnDon
MtnDon's picture
Progress measured in small increments…
I needed some more holes, so…
My under 2 inch forstner bits
Two holes done and my newly arrived Q8 Smile
3/4 of the bookshelves project done. 1/4 to go as a corner cabinet to the left. Then I’ll be free to do the waiting flashlight stuff unimpeded till the next (inevitable) project.
fritz15
fritz15's picture
Last seen: 3 weeks 6 days ago
Wow wow, wood is so last year Big Smile just kidding, I’m looking forwards to seeing the built!
MRsDNF
MRsDNF's picture
Are you filling the bookcases full of flashlights? Silly
MtnDon
MtnDon's picture
If it was my own, probably. But I’m building them for our son’s place. FYI, they will end up with sliding Japanese Shoji doors. They look a little like a window with a lattice framework. Instead of transparent glass traditionally they use translucent paper. We will be using a laminated paper for greater longevity. LED strip lighting will be run behind the lip of each shelf. They will be dimmable.
There will be real books. Smile Who knows what else? Maybe a Q8 if I can bring myself to give one of mine away. Facepalm
Back to this years contest entry….
More holes needed…
After drilling those three holes I sliced off a slab with the table saw. Then drilled out the holes in the block and pressed some aluminum threaded inserts into place.
Another view of the block and plate. When completed the plate will be mounted back onto the block face.
MtnDon
MtnDon's picture
I need a round copper disc, 3/4 inch in diameter for a cell contact. Using aviation snips I cut one from a scrap of 0.020” copper. This is the rough blank.
A file was used to remove the excess and round it off
That is a piece of 3/4” walnut dowel used to check roundness and size. Looks okay to me.
More later.
MtnDon
MtnDon's picture
Holes and grooves…
Using a very long 1/4” bradpoint bit
The drill tore out at the bottom a little, but that is going to be hidden from view, so it never really happened Wink
I need some grooves to run wires in. Never tried this before so here goes…
As well as the Dremel cutting wheel I used a Dremel cutting burr and a small Dremel drum sander.
More to come another day.
MRsDNF
MRsDNF's picture
Very nice Don. Do you glue the threaded aluminium in or just press fit it? I’m learning lots about different drill bits as well. Thumbs Up
MtnDon
MtnDon's picture
It is a tight slip fit. I use a bench vice to slowly squeeze them into place. I did not use any glue on these as I don’t think I’ll ever torque the screws heavily enough to worry. When I feel the need to lock them more securely I use a triangular file and file a small groove down the length of the aluminum insert. Then when it is in place a drive a small brad, or finishing nail into that groove. It locks very well.
I used to have some special cyanoacrylate glue that was made to allow making a slip fit. Made by StarLoc, Wet one side like the wood hole, drive in the insert and in about 5 minutes it would set. I still have the empty bottle, but have not found anything like it. Haven’t looked hard though. I bought it from a UK seller a couple years ago.
FmC
FmC's picture
Good to see some more progress, Don Thumbs Up
I’m back in Aus after spending the last week or so in the US on vacation, & have a lot of catching up to do; both reading BLF, & working on my DIY build….
…that reminds me, MRsDNF wanted some Drag Week pics….
MRsDNF
MRsDNF's picture
Yes please. Smile
DavidEF
DavidEF's picture
FYI MtnDon, a US penny is 3/4” diameter, and if you get an older one (what was it… pre-1982?) it is nearly pure copper (at least as pure as that plate you cut out, probably.) Once you sand it down flat, it is nice for this kind of thing.
MtnDon
MtnDon's picture
I remembered that late last night. Sad It would be a very nice fit. Yes, pre ’82 are 95% copper. Oh well, maybe I’ll look for one for the other end.
MtnDon
MtnDon's picture
Some days are better than others; some worse than most. Today was one of those oops days I suspect most of us have experienced from time to time.
Rather than starting with a new block of padauk I am making a slight redesign to cover, do away with the oops. I sliced of some of one side and have a slab of something brown glued and clamped. I say something brown as I have no recollection what it is. It’s not American walnut. The glued up laminate is on the left. The wood on the right is just a clamp block. Tomorrow I’ll trim the excess and then slice off just enough to return the block to its former thickness. Then carry on.
The contrast between red/orange and brown should look fine. I hope it looks planned. Wink
To add insult to injury I misplaced the wonderfully round piece of copper sheet I made. It seems to have been swallowed up the the gremlins. Facepalm So I found two 1976 pennys and filed away the design on the tailside. I’ll use those rather than carve and file some more sheet goods.
DavidEF
DavidEF's picture
I’m sure that color contrast will look perfectly planned when all is finished! Wink
MtnDon
MtnDon's picture
Back on track tonight. Smile
I trimmed off the glued on ‘brown’ wood. I made an “O” into a “U”. Wink I removed a portion of the wall that encompassed the large diameter hole using the table saw, then a file and a sanding block. The block edges will be radiused next.
Here’s the side with the glued in ‘brown’ wood.
The removable access plate that I refer to as the back.
I tend to hang onto things. The 8-32 screws that secure the back are aluminum chassis screws from way back when we raced 1/10 and 1/12 scale cars. The screws are from my box of left over Associated RC10 parts. The heads are a little rough on those; final assembly will be with “brand new” 33 year old screws.
MRsDNF
MRsDNF's picture
Looks really good Don. I only see a C though, no flashlight.
Did you get the better halves towel put away before she knew what you were doing with it? Silly
MtnDon
MtnDon's picture
Hmmm. Where U perceive a C, I C a U. Facepalm Funny how we look at the same thing and see something different. My head must be on sideways to see a U. LOL
Towel ; That is a genuine “shop towel”! A hand me down, so I am totally safe with whatever I do with it. Thumbs Up It is a little worse for the shop wear though,… I should have looked for a cleaner one for a photo backdrop.
MtnDon
MtnDon's picture
I will turn it into a light soon…. Smile
_
Must be a hand held and battery operated light (Read: Loosely classed as a flashlight. Lanterns and similar are ok.”_
