Good to know, I’ve set my 1A higher, blinked 6 times after I set it?
The room temp was very cold when I tested the 1A at 5,400 lumens the next night was warmer and I couldn’t get past 4,800
I got a consistent 4,000 for the 219c with Sony VTCA5 and 3,800 with VTC6, which is on par with reviews. The 1A is far more erratic, even the same batteries yielded different readings.
Precisely mu thoughts from today…include USB type C plug. Use it to:
reflash the chip
with a helper app, provide GUI configuration
charge the battery
turn the light to a powerbank
As to predictability, the light has better memory than I do. I often avoid turning it on with a single click and loosen the head before that, just in case it’s on turbo.
Also, I never know what direction will the ramping go.
That requires a much more capable MCU than we’ve been using for flashlights. An atmega chip can do it though.
There was an arduino-based light a few years ago, but it was expensive and kind of meh. There was also one with bluetooth for configuration, but it had physical design problems and the concept was never developed very far. Some recent driver designs use vias for programming pins so it can be reflashed acupuncture style without removing the driver, and requires no host modifications. That might be an idea worth exploring further.
That’s why I used different ramp controls in newer UIs. Hold to ramp up, click then hold to ramp down.
I made a reversing one about 3 years ago, but the way it often went the wrong direction always bugged me. So I had been meaning to change it, but I didn’t really touch e-switch code again until recently.
The XP-L HI is $3-4 more per each than Nichia 219C or XP-G2 emitters. Multiply that by 4, select desired tint bins and there ya go. The domed XP-L HD won’t fit under the Carclo quad optics.
Surely someone here aspires to a career in editing documentation?
(P.S. — is there a way to download an entire thread without pagination, as a long text file? Then deleting everything not part of the desired end product becomes fairly easy to do)
It seems to me most everything is in the D4 UI V2 diagram. The only trick i heard of is to unscrew the tail cap to reset the memory to 100% 7135 level. How to properly set the step down temperature could use some additional explanations too. Is there much else?
Ah, that was a gotcha! I’ve been unscrewing the tailcap to lock out the button, and suddenly was surprised to find the light won’t get more than slightly brighter, ramping went away.
Must be I’m falling into that memory setting.
Thanks for the reminder where to find the printed GUI chart.
Another please-remind-me — this driver has discharge protection so I can use unprotected cells, right?
If it makes you unhappy then vote with your wallet and don’t buy it. Pretty simple solution. Or take it up with Hank. By posting that here you’re discussing it with people not in the production loop. Don’t want to pay the extra $18? Then don’t.
