Imalent DX80 32000 lumen monster
Another delay.It is coming soon by the BG
At GearBest they changed it until 29. September, also their representative told me that even second batch will have to pass their QC control before shipping. So I wouldn’t risk buying it anywhere before official Imalent approval.
I ordered 1 thru BangGood on Aug 6.
I haven’t heard anything yet, which is good.
Imalent answer that my Dx80 its ok, so, i continued making test to the FL.
:+1:
Finally we will have true output measurement then…. My guess is 28-29000 lumens at start and drop to 25000 in first minute….
Thats the performance I would expect from 4x high drain 18650 cells. Voltage drop Should be much less with 8x cells.
With 4 XH70.2 yes, but with 8 of them it’s more less the same….
Finally the head of my DX80 will be shiped to china. The DX80 works very well, but modes aré no correct.
Couldn’t have said it better myself!
Wait…what? can you give some idea of run times and such before sending it off?
Argh! you got one but have to send it back :frowning:
tough luck, it read like yours was OK before.
Imalent says to me that i can test the flashlight, i supose the DX80 are OK, but not.
Really The light worked very well. But all modes, from the low to the mid-high, were much more powerful than specified. The consequence were runtime ridiculous, especially in the medium-high mode, which only differed from the high and turbo in the first few minutes. Moreover really have not low mode (more 700 lumen in my medition).
I have to send only the head, so i think that they are working in another Driver. Everything else works very well (charge and discharge, temperature control system, pushbutton, oled screen). The quality is very good, and the projection is impressive.
In the next days i will publish all (whitouth rumtime and modes because my meditions are the meditions of a dammage model)
What’s the highest output you managed to get? And is there a fan under heatsink or not?
My highest output its 25401 lumens and 22320 in 30sec. Cool off. But its very probably that my IS its not correct calibrate to this lumens. I explain this here Imalent DX80 32000 lumen monster - #264 by Maiden666
My result are very very similar in hight mode. The rest of modes have a real problem. When i send my data to Imalent, they say me that are working in this. They resend to me a document whit a HPLED Fast Spectrophotometer Test Report. The Flux are 32160 lumen.
So,X80,or DX80?
Or rather,X9? :smiley:
At this point, definitely the X80.
:person_facepalming:
My english is very bad. Sorry
MODEL SPEC ON 30 SEC
IMALENT DX80 32000 25401 22320
ACEBEAM X80 25000 22275 18741
The dx80 is a beast alright. Still not to unwieldy.
DT70 is a lot more powerful than the TN36UT 2017.
@maiden666
How is the dx80 Beam compared to the acebeam X80 ?
Same flood characteristics? Or a little bit more throw?
