The XP-L HI is $3-4 more per each than Nichia 219C or XP-G2 emitters. Multiply that by 4, select desired tint bins and there ya go. The domed XP-L HD won’t fit under the Carclo quad optics.
Surely someone here aspires to a career in editing documentation?
(P.S. — is there a way to download an entire thread without pagination, as a long text file? Then deleting everything not part of the desired end product becomes fairly easy to do)
It seems to me most everything is in the D4 UI V2 diagram. The only trick i heard of is to unscrew the tail cap to reset the memory to 100% 7135 level. How to properly set the step down temperature could use some additional explanations too. Is there much else?
Ah, that was a gotcha! I’ve been unscrewing the tailcap to lock out the button, and suddenly was surprised to find the light won’t get more than slightly brighter, ramping went away.
Must be I’m falling into that memory setting.
Thanks for the reminder where to find the printed GUI chart.
Another please-remind-me — this driver has discharge protection so I can use unprotected cells, right?
If it makes you unhappy then vote with your wallet and don’t buy it. Pretty simple solution. Or take it up with Hank. By posting that here you’re discussing it with people not in the production loop. Don’t want to pay the extra $18? Then don’t.
Thermal Stepping Down question and separate ramping question.
Just got my Gray XP-G2 D4. Long story short, steps down and continues to step down from pretty low levels, even from cold, rested start. Ramped up to what I think to be about 600 lumens or so (comparing it to what’s supposed to be about 600 on my ZL SC62w), a very usable level IMHO. Light doesn’t get hot to the touch at all….but starts stepping down pretty quickly…and keeps stepping down about every 5-7 seconds until it gets in the 150 lumen range….NEVER even warm to the touch IMHO. I think I read that the regulation is of course basing it’s feedback on internal temps and so my “feel” on the outside isn’t directly proportional to the “need for stepping down”….but this seems a bit aggressive. Basically only giving about 1 minute or so of 600-800 lumen light. The questions: Does this sound normal? Is there a way to adjust this to give longer mid lumen level or is that not safe?
Separate ramping question:
When I’m ramping up from off, there are 2 “flickers” in the process….like a quick blink…one at about 1/3 the way up and then one right before the brightest setting. When ramping down, only one “flicker” nearer the bottom end. Is this normal?
Couldn’t find anything in the thread referencing it….so with these 2 behaviors I’m wondering if I may have a gimpy light.
These behaviors are with a freshly charged and rested Sanyo 18650 GA at 4.1V and then a Samsung 30Q at about 3.9V.
I haven’t yet tried Lego-ing all my other tailcaps onto this tube.
But I’m hoping one of them will fit the threads/depth/connection and be suitable to attach a split ring to connect a GITD keyfob and “lobster clip”
Those things are both answered on the first page of this thread, in posts #1 and #2. Both were also answered a few comments ago, in jon_slider’s comment #1790.
From off, click 10+ times and hold until hot.
The flickers are there because people requested it. It can’t be turned off in this version, but the code is available if you want to change it.
I pushed an update of RampingIOS.c to trunk. It adds support for higher-voltage battery configurations, like 2S/3S/4S. That part of the code wasn’t really functional before.
