That’s so metal.
You are now officially Too Metal To Headbang.
That’s so metal.
I have 4 UV lights, each with a different emitter. 3 of them are Nichia. 1 is LED Engine LZ1. The top of the line Nichia was the most difficult to acquire. It’s not as obvious the differences between these 4 as I would have thought, especially considering the price of the top of the line emitter, but it sure cure’s optical adhesive in a hurry!
Convoy S2 18350 NVSU233A (this one has a weird Silicone add on dome from Nichia, works, but looks funky as it’s really big)
Copper X6 with NVSU333A
Jaxman U1 with NCSU276A
Solarforce L2M (18350) with LEDEngine LZ1 (this one has an AHorton aspheric)
The Nichia NVSU233B is also great, even less visible light output and more UV output
Only downside is the higher Vf
Modded a Thrunite TN-31 with a SST-40, already had the light with bypassed resistor mod and on turbo it gives the XHP-35 Hi led on the AceBeam K70 a run for its money. It’s blindingly bright!!!
Dangit TK, I was all prepped to rock out with some April Wine! (uh, 1979 head banger music?) [memory… sudden ancient flash of Alesha in her ’78 Trans Am with Lightning Rod shifters, literally head banging in the car, driving, to April Wine. Scared me! She was a bad driver when she was watching the road! And along with that memory, another time she …. nm… suffice it to say the police were involved and it wasn’t music.]
158 kcd awesome , Hey Sledge, whats the tail amps, ?
Thanks!
I haven’t tested it on a full cell yet, but I got 8. something with a cell with unknown voltage. I’ll check later today with a fully charged VTC6.
I built my first driver from scratch (well, from oshpark and a bag of parts) and it worked!
Even better, I got it to do 4-channel PWM for red, green, blue, and amber LEDs. With an e-switch to control it.
I had thought the 3rd PWM channel was weird, but no. The 4th channel is. The attiny85 doesn’t have direct support for 4-channel PWM (the hardware does channel 3 OR channel 4), so I had to do it semi-manually by chaining an extra interrupt off the PWM timer and using that interrupt to manually turn the 4th channel on and off.
Also, for some reason the 4th channel is inverted so 255 is off and 0 is full brightness. I’ll have to see about fixing that.
But anyway, woot! This means that soon I can start on the fun parts.
Nice TK !
Feels good to make your own drivers , especially when you can also create a new firmware for every flashlight
thought this would be a fun zoomie host to play with.
updated the stock triple color led to a single sst-40, driving it at 5.5A with a east-92 driver, powered by a littokala 26650.
What zoomie is that, solRNY?
I swapped 4x XP-L2 4000K 90CRI leds (from Mouser) into my black Emisar D4. A partly succes.
The jay:
The meh:
Here is two white wall shots. Do not look at the actual tints, first because the pictures are made with auto whitebalance, and second my phone camera is damaged by UV-light so the center of each picture is brighter and slightly more pink than the edge :confounded: .
Left Carclo 10507 (S2+) with XP-G3 4000K 90 CRI, right Carclo 10621 (D4) with XP-L2 4000K 90 CRI.
D4 with XP-L2 compared to D4 with Nichia 219C:
Looks like this flashlight: https://www.banggood.com/de/Warsun-X50-XM-L2-3Modes-1200LM-Zoomable-LED-Flashlight-p-1020998.html
Thanks for the link. The description says Boruit. Is the lens glass?
ha, you reminded me that I have a glass lens from a project years ago! found it, and was excited to test it, but it did not work out well. the focus was lost mid way thru extending the tube.
the stock lens is in the middle and is not glass, it is the biggest lens of all my zoomies.
I like most everything on this host except for the pill, the thermal path needs a lot of work.
Made a new “walking the dog” flashlight.
Eagle Eye A6 host
BLF A6 driver
Smooth S2+ reflector
pflexpro Micro-Textured lens
De domed SST-40
Eagle Eye X7 de-domed SST-40(left) Eagle Eye A6 de-domed SST-40(right)
It has a nice wide beam and still puts out some lumens, not as much as a quad or triple but is has more “throw”. It pulls 8.45A from a fresh VTC6, settling @ a mere 3.22A after stepdown.
I also swapped the emitter in a Sofirn SP31 to a XP-L HD 5A3 :
Sofirn SP31 XP-L HD 5A3 (left) Eagle Eye A6 de-domed SST-40(right)
Djozz killed Darth Wader light, There is no fun in that any more
So Djozz said: Wader… You shall not pass!
Anyway fantastic mods guys…
How about making one for your dog? Kodi loves his! :+1:
This is why I’m a bit concerned about the FW3A’s optic and emitter choice. It risks making an ugly multicolor beam with lots of artifacts.
