Nope, the X5, D4, and FW3A are still pretty big. I’m thinking more toward the small end of 14500 or 16340 lights —
something with approximately the same total volume as an 18650 battery.
About fans: When 12 Volts fans are to high Voltage, there are also a bunch of 5 Volts fans out there.
Of course there is the waterproof issue with fans…
You could make them water resistant though, but i doubt there are water resistant fans on the market in a small size.
On another note, how about a recoil light?
I started a topic about a year ago, but i can’t seem to get it going.
The problem is finding a reflector…
But, like with the GT, it can be made by a flashlight manufacturer (or they can have it made by a specialized manufacturer)
A recoil light is a thrower pur sang, has no spill and a very tight beam without a corona.
It will probably out throw the GT because it uses practically all of the emitted light from the LED.
It would be unique.
The SST-40 on 5 Amperes seems like a good LED for it.
I’m for it, just for the sake of having it made. I think it would be a more unique BLF light than what we’ve done so far. But, I wouldn’t buy one, because I have no need (and very little want) for a super thrower.
Liking the AA version of BLF348, PM send to the pointing him to the post.
TK, I get it.
With your new eswitch firmware creation platform, and addition of people being able to program using the led as signal receiver could be very cool.
SST 40 seems smart choice.
Double tube like FW3A for tail switch
Could be nice to have Fritz design it.
Just saw a little On The Road clone (an Olight clone in itself) with build in charging for a mere $13 on AliExpress. Gonna be hard to beat such a light if quality is good (gonna order it tomorrow because of this conversation )
Recoil, you guys want it to be so big that sure it will beat the GT. Lots of challenges. Is there an interest list? Just start it and if it fills finding a manufacturer becomes easier and you see what happened with the GT, there was no reflector but LT let it be made, that could happen here as well.
Since we’re talking drivers here too, i think many of us would want to have a 1S boost driver for 6 Volts LEDs, like the Nicha 144, the XHP50(.2) or for a quad (2S2P) of 3 Volts LEDs.
Yeah, 5” is big (recoil), but it will be short too (more like a box).
(edit) Actually, the GT is almost 5” reflector diameter also.
Maybe i should build one first, maybe for the scratch build competition.
But i’m not really productive lately…
I’d also be interested in a scaled up version to allow 21700 cells once they take hold.
A single emitter light with the latest and greatest led would be cool as well.
Well I must say that I hope we can move the FW3A to prototype phase fast when the busy GT stuff is settled.
First boot up would be Q16 if Thijsco19 and Cawi can find the time to work on my awful sketches
But the BLF ST (Short thrower, Q8 compatible threads, same overall length as Q8 but with shorty 18350 tube and longer head for one reflector SST40 driven at 7A) would make such a nice set with the Q8. For those two I would buy a case.
Of course the illusive AA driver for a Q4 and Q2 is a really nice goal.
All these seem lights for Thorfire to make. (Due to some parts I want to use on the Q16, some S70(s) reflectors) and threading compability and well just nice to have them do the Q series if they want to.
Sounds like a great plan! The Miller Plan.
Is there a thread for information about this scratch build competition?
The 5th Annual BLF / Old Lumens Scratch Made Light Contest is Now Closed - See you again in 2018! http://free.timeanddate.com/countdown/i47vbc67/cf12/cm0/cu4/ct0/cs0/ca0/cr0/ss0/cac000/cpc000/pcfff/tcfff/fs100/szw320/szh135/tatTime%20left%20to%20build/tac000/tptTime%20since%20Event%20finished/tpc000/mac000/mpc000/iso2017-11-01T00:00:00 Hello everyone, The contest officially starts as of this posting and it runs until October 31th at Midnight (UTC). Some inspirational images of builds …
The more the merrier.
Oh yeah a recoil thrower as OLSB entry, cool to see and could spark interest for the type of light.
Yes. One of my favorite style lights early in this hobby.
I guess the type became harder to make with more powerful LEDs?
I have one sub $5 and it focusses good. It misses the advantage of being able to change to flood as zoomies have.
With the size Jerommel envisions cooling is less of an issue then only having one very thin “leg” to take the heat away.
I would like to see a BLF automotive light bar, not that I could actually afford one.
Some of the rough ideas that I have had include-
- It being around 300mm-400mm in length, small enough so that it can still fit small euro cars and perhaps with a modular mount system so that 3 or 4 could be easily joined together for those with trucks.
- A driver designed with a high and medium setting operated from a single On/Off/On switch, not only for the obvious reason of not always needing full brightness but also so that members with small euro cars could still use it without needing an alternator upgrade. A low voltage cut-off to protect from a dead car battery and perhaps thermal management so that if the bar is left on while the car is stationary it won’t overheat.
- Tint selection would be chosen for reducing eye fatigue and enhancing road hazard visibility rather than the highest output. TIR lenses could be used rather than reflectors to reduce tint shift, and if common sized TIRs were used the end user could mix and match if they weren’t happy with the beam pattern and wanted to increase flood or throw.
- And for the really tricky part, keeping it as budget as possible.
Sounds all great.
Though I think it’s wise to slow down a bit with those big and more expensive projects.
Let the GT, Q8 and the fw3a finish and maybe go with something small. Like that bigger blf348. That shouldn’t make most people broke.
In the meantime we can work on the q16, that would be another big and probably expensive light. But it will take some time to develop.
Of course, there is nothing wrong with filling this thread with everyone’s wishes.
Well idk if I agree with you here Thijsco19
If all people who have bought a TN42 or one of the other big throwers had gone for the GT, they all would have spend less and gotten more throw.
Same with the Q16, yes it will not be cheap but having lots of lumens for a long time should make it a much more awesome light then almost all of the 10K+ lumens lights out there for almost all of those have a short high output burst and are expensive.
But in light of the wish for small I ordered that tiny 16340 light with build in charging.
The Q4 and Q2 shouldn’t also be expensive.
If Thorfire delivers and wants to do the Q series we could do different lights with faster working manufacturers like Lumintop, like the not really expensive FW3A can be followed by a copper or brass version (costing more) and/or a really tiny 16340 light TK is talking about.
The AA version of the BLF 348 is not for us/me to start, with several runs it is the most successful BLF special IMHO and done by the and Gearbest. It is logical they do the AA version too.
I don’t think it’s possible to do a good light bar cheaply. Are you familiar with Richard at Mountain Electronics? He has created his own line of vehicle mounted light bars. They are some of the brightest out there and have multiple brightness levels that can be controlled from inside. http://www.mtnlitebar.com/
Yes MTN Electronics has lightbars covered and they are not flashlights.
