I use the sublumen mode of my zebralight, utorch UT01 and EagTac D25A…. in the night, really all nights, and I’ve also used it in a movie theater.
If I wake up at 3 in the morning, a light of only 5 lumens already seems to me too much….
CUTE!!!
I know this is going to be too expensive for me, so I will keep it at the $12 On The Road M3 clone (Olight clone) with USB charging and clip i just ordered today.
Or is this one actually affordable?
still, want to know parasitic drain (important on such small cell) and see a review.
But CUTE for sure!
Sure, sir, I know enough about logaritmic perception…… Ultracompact lights for keychain and EDC do not need tons of modes. I respect your opinion.
Is good the logaritm for the tool? (before broke by the alkaleaks case) Enough for bought you one at least….
Although you do not believe it, I have some experience in flashlights, …. test, reviews … perception …. etc.
That is exactly why manufacturers ought to check Bistro and Narsil out, now it is often/almost always lots of preferences and a limited choice, while there are suchbgood firmwares where each user can set it up just how they prefer.
“Operation
When OFF, click the side switch to enter into the last
memorized mode when last powered off, click to change
mode, cycle through moonlight(1LM)→Low mode
→Medium mode(45LM)→High mode(600LM or 305LM);
Long press side switch for 1S to enter into the moonlight
mode when OFF.
Long press side switch for 1S to turn OFF when ON;
Quick double-click the side switch to enter into strobe
when the side switch is unlocked; Double click again to
enter into SOS and click to exit. Lock-Out
Long press the side switch for 5S to lock the flashlight
controls. Press the side switch three times to unlock the
flashlight (The lamp will flash three times to indicate
status change and will flash twice to indicate the
flashlight is failed to unlock). Battery Capacity Indicator
When OFF, press the side switch three times, the main
lamp flashes to indicate the battery capacity:
Three times: 70–100 capacity;
Twice: 30–70 capacity;
Once: less than 30% capacity;
The lamp flashes twice every three minutes when battery
at less than 10% capacity, replace battery
immediately;
Note: The lamp will display as above only when using
16340 Li-ion batteries. ”
