@polarweiss, I donāt know what is different in your build, are you sure that the reflector is not prevented to get close enough to the board by some obstruction? And that the led is centered precise enough?
At least in my two builds (Black Flat and dedomed XP-G2), the reflector at less than 0.5mm to the board gave a well focused led.
Finally I received this light to play with (first order got lost). I havenāt made much pictures of the build only the two below.
I sanded down the pill rim and in the center of the pil I added a sanded down noctigon. On top I placed the maxtoch mcpcb with dd xml2 u4. All glued together with artic silver adhesive.
Took a while to get the focus right, but it has a real nice useful beam now.
Didnāt like the shiny ano, so baked the light on the stove.
Very nice and light light. It encourages people to step forward into modding art and it is probably best reflector thrower in this reflector size(diameter, depth, single 18650) in a world.
Did anybody find a good centering gasket? The stock one is crap in my opinion. Or are there any trick center it succesfully? The Reflektor always off-centers on the last steps of tightening.
No answers? I am planning to build another one of these. Got the first one right, but after a lot of adjusting. A tighter centering ring would help a lot.
Yes I really tried with itā¦ Ordered from Simon toā¦ But no matter what I tried it did not looked nice to my eyes.
The best you can do for yourself is that you donāt use it at allā¦ This is product of eyeballing:
A bit uneven spill from side to side is product of drilling reflector base with accu drill but the most important thing is perfect hotspot with 300+ kcd
Looks kind a warm towards green? Yeah baby! Because it is good old XP-G2 S4 2B inside :+1:
This is probably only reflector light beside Jacob A60 that I actually like.
If took the top rim of mine and added a large mcpcb, but the wires shorted.
So i want a copper or aluminium pill and use a smaller mcpcb with the wires more pretected.
Was measuring the throw on my D1s today (120kcd). I also tried my souponfire light (dedomed xml2-u4, Blf a6 driver, 24agw wires) and got 205kcd. Maybe could have got higher numbers with thicker wires, but I am still amazed by the potential of this budget light.
I think there is no better reflector thrower than this Mitko super thrower, but only modded versions so if you are not up to the task donāt order themā¦ And especially under 15$ā¦ For maxtoch fans this modded light will easily out throw your super duper factory maxtoches with 2x18650 cells when properly moddedā¦ That does not mean it is better light of course. We could also mod Maxtoches
Sorry to bring up this thread again, but did any of these replacement pills work with this light? I canāt decide whether to put in a 2mm white flat or sliced XHP50.2, then I thought if I could have multiple pills that would be great.
