You can change the modes how you like them in the firmware (which doesn’t exist). On my experimental buck-boost board (you shouldn’t order that board, forgot some things), you could have 1024 brightness levels to choose from. But the current difference at the high levels is much bigger (2A -> 1,88A …) than on the low end (14mA> 16mA ->…). That’s just how the circuit works (it’s a voltage divider with an OpAmp, forming a noninverting amplifier).
We probably have to wait for these drivers until there is a public datasheet for the MP3429/MP3431 (thanks Jensen567, nice chip you found). But if someone finds a similar chip, just post it.
Right now we can’t even do this, we have zero firmware for these MCU’s. Once we have some firmware adding all the extra features will be just a matter of porting them from the firmware we already have.
Then maybe stick with the older (cheaper?) MCU for now?
I mean it would be cool if BLF came up with a line of drivers “you want but don’t exist”, like aforementioned 1S to 6 Volts (3 to 6 Amperes) w/o PWM. (i keep mentioning that because i really need one).
But that’s quite pointless. Only makes it more complex (from an end user point of view).
Obviously the high mode is always 100, and the next usable mode downward should be 30 or 33% of that, the one below that another decrease of the same magnitude.
Or is this a personal thing?
Every light i own that uses smaller or larger steps i like less in that respect than a Nanjg 3 mode driver light.
Ramping is not user friendly either (in my opinion), you always end up where you didn’t really want to end up or it has to be very slow.
It could work well with 2 buttons (up and down) though.
The new MCU’s are cheaper by about 10-20% from the prices I have seen.
We can’t use the existing MCU’s for new driver designs due to space constraints. A tiny85 takes up almost half the usable space on a 17mm driver, there is no room for anything else except what we have been doing.
The new MCU’s come in tiny 3x3mm packages that allow the space for new driver designs.
For example, that driver that was posted earlier in this thread is impossible with a tiny85, just not enough space.
Jerommel, just wait till you have played with Narsil and things change for you
There is a lot I really want added and even deem important like a couple of “safe mode groups” limiting both modes and highest output, so when handing a light to somebody who knows nothing it ia safe for example.
Not only for safety but also pretty useful in small lights, find the best top mode it can run without overheating
But also I want two switches operating two sets of LEDs separately for the Q16. I think we would need two drivers now but with more pins maybe one driver can do it (yeah sorry I am a technical newb)
A single driver can do that, the only issue would be space depending on how the LED were controlled. Although unless you are talking about different color LED’s you are pretty much always better off driving all the LED’s at a lower current then running a few of them harder.
Well needing two sets of LEDs each set of two having a different function (2 for throw and 2 for flood). Makes a lot of sense to be able to choose either or both for max output.
BTW, how about some waffer level package chips? These can be nearly 3 times smaller than Attiny1616.
Example here
Not sure if it has all that is needed. Not sure if it’s hand-solderable. And it’s slightly more expensive than Attiny. But is significantly more powerful while saving another 5.7 mm².
there are some limit, the range of changing current is quite narrow
(2 to 3amp on 3amp version), what i want is wider current selection, like 0.5 to 10A, all determined by a fomular with 2 resitor
I have to know which one on the LD3, i’ll PM you (led4power).
because i bought 6 of them, all 12 Amperes, which in hind sight wasn’t all that smart… :person_facepalming:
I’d like to hear what your thoughts on converting standard DC-DC converters into controllable constant current LED drivers are.
The best way I have thought of would be to replace the resistor divider usually found on the feedback pin to set the voltage. I figure if you use a sense resistor coupled to an op-amp, so the circuit would adjust voltage up until the current hit the feedback level.
I haven’t yet figured out a control scheme from the MCU though. My first ideas would be either a digitally controllable op-amp or a digitally controllable potentiometer to change the amplification factor of the op-amp. The issue I see here though is it might be difficult to find suitable components to support both high amplification for low currents and potentially no amplification or even reduction for very high currents.
I can’t find any decent 1x AA drivers either…
One mode would suit most of my needs, but they’re usually not current regulated and have low efficiency (so it seems).
It’s a little strange though, isn’t it?
You can buy all sorts of LEDs, hosts, batteries and parts, but the choice in drivers is disappointing…
That’s why this thread is here. Tomorrow (or today actually) I will write some text about ideas I collected about turning a voltage regulated converter in a current regulated one. I think Linear Technology has an IC which could be used for 1xAA/AAA, at least I found one a few weeks ago.
