As interesting as philosophy of governance is, it’s one of those topics which tends to get out of hand pretty easily.
Instead of responding with data on the effects of various governance strategies (data on this sort of thing tends to be counterproductive when humans are involved), I’m hoping we can stick to less fiery topics… like actually starting fires.
Dale, that is the laser you made for destroying wasp nests from a safe distance, no?
Can anyone tell me how long I can run the C8 at 100% in let’s say 25-30 degrees C ambient temps until the heat buildup is too much. There is a runtime chart floating around which shows a max temp of 66 at about 40 minutes in with an ambient temp of 25(?), is 66 too high?
I can’t say if that’s as hot as one gets, or if those numbers are accurate, but I can say that 66c is not “too high” for the electronics. That heat won’t hurt your light. It may hurt your hand though. How tough are you?
Bottom line — if you can stand to hold it, its not too hot.
If you’re holding your light, it doesn’t get that hot. Your hand draws a lot of heat from the light. I think those run-time temperature graphs are done with the light tail-standing.
Thanks! A grey C8 is calling my name… I see people get around 80,000 cd out of them in stock form - that would make for some impressive pocket thrower. My current go-to thrower is Thorfire VG-10, and that barely clocks in at around 12,000 cd.
You’ll be satisfied for sure. I have a C8 with a domed XM-L2 and an OP reflector, and it’s still easily my longest-reaching torch despite the throw-unfriendly setup. It laughs in the face of a 100m distance!
Yes, I have a stock C8 silver, and it’s a great pocket thrower. Jacket pocket, perhaps. Easily my go-to for an outdoor thrower, since it’s so light. I have the 7A and 3A, and I prefer the 7A tint. Though I might get a 4C, since it’s probably a good compromise.
If all you have now is 12k cd, you’ll notice a huge difference. But bring a flooded as your main light, because a C8 is bad up close.
Unless you’re tail-standing it. Throwers make great lights for tail-standing, since you don’t get much spill to catch your eyes when sitting near the flashlight. And, the C8 seems to have an AR coating, so you don’t get glare off the lens either.
I like the 7A tint on the C8 for indoor tail-standing. Nice incandescent-like light.
True. Ceiling bounce with them is a dream, especially in 7A tint. I have an M1 in that and love it to death – when I’m in bed, I set it to 0.1% or 1% depending on what I want to do, tailstand it on the nightstand then put a Thrunite T10 diffuser on top of the lens. Best lamp ever.
Well, I have a Haikelite MT02 that measures around 60k cd, but it’s just too heavy to carry around on my long nightly walks. It’s a good exercise though.
Yes sir. I’ve got an OTR M3 clipped to my cap visor, and this one’s pretty floody. I just need something throwy and not too heavy in my jacket pocket to occasionally light up something further in the distance, which is what I’m using the VG-10 for, currently.
Hello long time to read the thread returned to ask something if someone has the answer. Is that pouch good for the flashlight? http://www.military1st.eu/ma48-008-condor-flashlight-pouch-multicam.html
as i can read the dimension of the flashlight is:
Diameter of head : 44.5mm
Length : 143mm
Diameter of body : 25.6mm
and the pouch Dimensions: 5.3”x2”x0.8” (13.5x5x2cm)
Thank you in advance.
I have the second one and has a very cheap feeling, i have the first one for convoy s2 it’s very good quality and sturdy built. thank you for the info.
