I used Lexel’s solution for this and it works nice. I gone down to 20,05mm at the grooves next to the threads and that is enough to fit the O-rings.
I also tested o-rings from Convoy UV lights that fit perfectly without reducing the diameter
Yes thanks, i will do this eventually.
Thank you also to Lexel for a great mod.
Convoy M2、LD-B4(12A)
LED:Nichia 219B V1 R9080 4500K
120uA
Steel that looks fantastic! You need to tell something about those mcpcb’s and driver and tailcap lighting. What they can do? Where can I buy them? How much they cost? I’m really curious.
looks like led4power material, very nice!
Here
https://led4power.com/ Added new copper DTP boards: https://led4power.com/product-category/mcpcbs/copper-dtp/ Price for 16mm DTP pcbs: 1pc - 1,07€ 50pcs - 0.95€ 100pcs - 0.8€ Price for 20mm DTP pcbs: 1pc - 1,17€ 50pcs - 1.0€ 100pcs - 0.9€ Price for 20mm 3XP and 4XP DTP pcbs: 1pc - 1,37€ 50pcs - 1,2€ 100pcs - 1.1€ If you want to buy 50+pcs, please contact me so I can give you coupon code, currently page doesn't automatically calculate discount. Gold plated pho…
Thanks!
Very nice work and pictures steel_1024.
The tint on that Emisar D1 looks very green is it the 3A tint ?
Green body, green light!HaHa
Yes, XPL Hi V2 3A
1C3, that’s one of my favorite lights right there! (EagleEye X6 triple mod)
How do you like it’s performance?
… no comment.
Edit: The ferocious Emusarus Rex stops to take a smoke break.
Hahahahahahahha awesome pic TK
I can easily see why, the cute-3 produces a really useful beam, the host is really well built, has a nice size and it has the best thermal path of any host of this size I’ve had my hands on so far, with those deep fins centered right on the led shelf, though driving it at ~3A doesn’t really push it. But since I’ve had to buy two hosts, I’ll make sure to build something more hardcore in the other one .
This is my take on a lantern attachment for he Q8. My girlfriend thinks it is ugly but I think it looks ok.
It is a 95-or-so% downlight which has advantages and disadvantages. When carrying it, very little light gets in your eyes directly from the lantern which aids looking around. When placed on a table it is a pleasant reading light for the same reason. But if you want to illuminate an area, it has to be hung up at some height because having it sitting on the ground it will just illuminate your feet. The light is way too cool for a camping light, but I plan to put 2700K 219C's in one of my Q8's anyway, so that will be my lantern Q8. I know that a camping lantern is aimed at low illumination and long runtime, but I do not mind to have the huge output of the Q8 at hand for illuminating an area if needed.
These are the parts:
I sawed a replacement lens out of 3mm clear polycarbonate sheet, the exact same diameter of the stock lens. Polycarbonate is tough and will not crack, and it is fairly heat-resistant. I drilled two 5mm holes in it, 17mm apart. The M5 screw heads will nicely clear the reflector then. Under the head of the screws a stiff rubber o-ring was put to waterproof the lens. The 95mm diameter hood is made of 3mm aluminium sheet that I hammered into shape over a 65mm diameter iron disc that I had around (from a speaker magnet I believe it came). The outside is painted with flat black heater paint, the inside I painted with latex wall paint. I'm planning on a nicer looking and more durable flat white metal paint, but the latex paint is what I had around and works well for thetime being.
Some more pics:
The latex paint does not look great but does the job:
The beam is fully captured by the hood, the leds themselves can not be seen from any angle, just some indirect stray light from the reflector can be seen:
The screw heads clear the reflector, they are positioned right in between the reflector cups:
The lantern gives an even and fairly diffuse illumination from the hood downwards, plus little light upwards which is stray light coming from the reflector and bezel:
Standing on the table, the hood is high up enough to produce a useful light cone for reading:
I modded my On the Road M3 just the other day by stripping the anodization and polishing it up. I then swapped the driver for a qlite momentary driver, put in a 3000k xpg2 led, and a TIR reflector. Now it’s my favorite EDC light.
Interesting work there djozz, looks very effective. Nicely done!
Stripped and polished a Solarforce host and built a 219c P60 drop in using a Convoy driver with biscotti. Also stacked four additional 7135 for a total of 4.2 amps.
Nice work
Hum, do the stacked 7135 chips work on that side of the driver? I thought they only would work in the interior part :person_facepalming:
It’s much easier to stack them on that side … :nerd_face:
Thanks!
Yes, they work on both sides
It sure is easier on that side. Just remove the spring and you’ve got a lot of space to work with.
