I prefer to mow on the weekends in the afternoon once the grass is dry, but when it’s growing crazy like it did this summer, I also need to mow during the week after work. And sometimes there are kid duties, so it gets pushed back even later, and now this time of year, sunset is a little after 7pm.
I try to be a good neighbor so it’s rare that I’m finishing up in the dark.
I have mowed a fair share of grass in my day. It’s not uncommon for a Briggs engine to backfire and shoot a flame after it has been running on full throttle and quickly put into low throttle.
Not saying its impossible for a fire to start from that but for it to happen that grass certainly hasn’t been growing and didn’t need cutting. It would be dead and dried out.
I got these for my rear-firing reverse lights on my car. Quite nice, aims the light where it needs to go vs relying on a reflector to do the heavy-lifting.
Would seem to be a better “fit” for your mower, as the original was that way, too.
Thanks for the suggestion Lightbringer. If the new bulb goes bad, I may get them. When I was doing my research, I saw the bulbs with the lens in front, but wasn’t sure if they would be bright enough or if they would have too narrow of a beam.
Well today when I was cutting the lawn (first time since I replaced the bulb) I noticed that the new bulb started flickering. Looks like 6, maybe more, LEDs on one side. The lawnmower must vibrate too much for the bulb. There are lots of solder joints on the bulb so I guess this was inevitable. Disappointing nonetheless.
This is what Lightbringer was suggesting. Looks pretty good, not too expensive, and should hold up better. Plus it should put more light in front of the lawnmower where it’s needed.
My new bulb(s) came in the mail today. BTW, the eBay seller that sold me the 85 SMD LED bulb gave me a full refund. Here’s the defective bulb (I count 8 LEDs bad):
Here’s the defective replacement bulb with the lawnmower lens on (left) and lens off (right)(10 sec, F/20, ISO 1600):
Here’s the new bulb with the lens on (left) and lens off (right):
Again, here’s the defective replacement bulb with the lawnmower lens on (left) and lens off (right)(10 sec, F/18, ISO 1600):
Here are my observations:
The new bulb gets a lot warmer than the defective bulb.
The new bulb is significantly brighter.
Even though they are both cool white, the new bulb is less cool and shows the green of the grass better.
The lawnmower lens kinda sucks. Even though it helps disperse the light, there are streaks that are noticeable with the new bulb.
The new bulb is certainly much better than the original bulb that came with the lawnmower. Rarely do I end up mowing in the dark, but it’s nice to have the extra light when needed.
I’m betting that the (facetted) lens is meant to take all the light that’s bouncing around in that 5-sided cube (ie, 6th side missing) and just scatter it as best it can. Enough random bounces, and it’s “smooth”.
The bulb with a brazillion discrete LEDs all over, around, on top, everywhere, similarly threw light everywhere, to again bounce around the mirrored cube and out the front lens.
Now with a single point-source throwing light just out the front, the front lens is acting like a chopper for those pyroelectric person-detectors (alarms, auto-on lightswitches, etc.), ie, a “fan” of individual beams directed all over the place. So now, all those light/dark areas show up really well.
If you can stick just a clear piece of plexiglass or something over it, to keep out grass clippings and other filth, you can have that nice smooooth light courtesy of the bulb’s aspheric lens.
Thanks for the suggestion. Another option would be to put something inside the lawnmower lens to smooth things out. Or if I really wanted to be experimental, I could sand down the inside of the lens, but that seems too risky. I’ll see what I have to put inside the lens and see if that helps.
Last week I noticed the headlight was no longer working on my lawnmower. So I pulled off the headlight lens (it’s glued in) and looked at the LED bulb.
Well no wonder why, the LED fell off the MCPCB (see bottom left corner)! Wow, that must’ve gotten very hot in order to do that. My guess is that MCPCB must have dislodged from the bulb shelf due to the lawnmower vibrations and overheated. I see there’s nothing to secure the MCPCB to the shelf.
So it was my first opportunity to reflow a LED. I don’t have solder paste, so I tinned the MCPCB and put some flux on the bottom of the LED. Held it over my heat gun and as soon as the solder melted I took it off. It looked pretty good.
Since the bulb is essentially a hollow shelf flashlight, I wanted to improve the heat management. I found a washer that fits on the shelf, made some notches for the LED wires, flattened both sides, and used some thermal compound next to the MCPCB. I then used 2 very small screws to wedge the MCPCB and washer against the bulb shelf.
I also sanded down the aspheric plastic lens and made it frosted. The beam was too narrow before and showed lots of artifacts.
I’m happy to report that my reflow worked and the beam looks much better. Time will tell if my heat management mod actually makes a difference.
Not surprised a bulb like this will fail when operated as a headlight, even if the power supply is good. These are not engineered to last, at least at $6 a piece.
I guess these bulbs were mostly meant to replace a reversing light - an application where they will typically not be on for very long periods at once. If not meant for that, it’s where these shine(no pun intended).
Some of these do work very well in many vehicles that have a very low powered and dim incandescent bulb that’s mostly a signal for others. In dark and rainy places an actual projector that helps to see a little is very necessary and one of these sometimes helps - even through the original diffuser of the rear lights assembly. Mostly it’s an illegal modification but may also be legal in some machines not operated on a public road - this will depend on jurisdiction and a bunch of details. I don’t endorse illegal modifications to vehicle lights, but this is worth noting and has served me well in an off road application. It’s nowhere near actual auxiliary reversing lights, but it gets some light behind the machine for $6, requires no modification and retains OEM look. It’s worth something that you don’t have to mess with the wiring harness or even drill extra holes in your machines.
This is why I, too, would attempt to modify the bulb assembly itself instead of just installing an aux work light on a lawnmower that already has the headlight. My recently purchased mower has none, so N/A and will not be participating in this endeavour but just installing a cheapo LED aux light - which is a viable alternative in case you need more lumens and/or won’t be satisfied with the miniature bulb performance.
Even in a car this is probably the controversial lighting upgrade that causes least harm to others. It’s nothing like amateur drivers blasting their front fog lights goin 100 km/h in darkness when it rains, or DIY HID kits or fubar’d halogen bulbs someone decided to cram in 15 tilted degrees. :rage:
Making an actually usable 100% duty cycle modification is a respectable project. :+1:
My guess is that it is running off the battery and the stator is just charging the battery. But for the LED to actually fall off the MCPCB should be due to heat and possibly vibration.
