Just put a mirrored cone right over the led. Suspend it on 2 thin arms.
My tweeters use something similar.
Just found this thread and Iām making my way through. I guess the purpose of this thread is for brainstorming, but itās definitely kind of hard to keep up with as the topic bounces around from one light, to another light, to a lantern, lol.
Are the concepts fleshed out enough that it would be a good idea to post an official poll asking āwhich of these lights would you be most interested in for the next BLF project?ā
If someone happens to be interested in discussing any particular project from this thread, they are welcome to start a new thread to discuss that project in more depth. Otherwise, I think this thread is serving its purpose, and a poll is probably unnecessary at the moment. Then again, if you want a poll to be started, youāre welcome to do that as well, Iām sure.
yes no poll, a project comes when it comes
I was really set todo the Q16 but then the QT/ST came along
It is now waiting to see how Thorfire actually did before deciding on how to proceed.
The lantern is a long running DBSAR project an I have been feeling guilty about the Q8 taking lots of attention from it, so that is his thing, I just try to get it going.
The Q16 needs so much testing and behind the scenes there is talk about moving to a MCUs with more options, ideal for the Q16
Then all of a sudden Lumintop also made progress on the FW3a
So now I am not going to start a new thing.
It seems logical to work on the ST/QT soon, it is a clear defined project making a nice set with the Q8 and using a lot of the same parts, so it is clear what we want.
Tiny drivers, for Q4/Q2 and TKs mini 16340 light require a small MCU too.
So it all makes sense (well to me)
and the braindstorming is just awesome and who knows where it might lead to.
Ah and I am trying to get some sort of database for open Source CADs to use going, this would make it a lot easier for another team to kick off and make things that Lego with the rest.
QT Ļ
QT Ļ
Hahaha this MUST be printed on the driver silk for sure
I have no idea if this makes sense, but how about a headlight with a strip lens?
Here, a rough sketch of 18350 light with 5-6 XP-sized LEDs and Khatod pl1629. Size roughly 35x40mm.
If you rotate the LEDs so theyāre in front instead of above, a similar headlamp already exists:
Itās similar, but not really.
First, itās 18650, so more bulky. For this reason it also needs a 2-strap headband adding to the bulk.
And it has only one white LED, which is less efficient. 6*XP-L2 V6 does 700 lm @ 200+ lm/W. Add a boost driver and such light doubles the sustained output of a 1-led + linear one.
Have you seen my contest light thread from last year? I made a light bar of sorts, using XP-E2 mounted on a board I designed myself. That board could be tweaked a little to make your desired project. I would actually love to see something like this made by a ārealā manufacturer as it could be a really popular style if done right.
Interesting, thanks!
For the reference, hereās the thread:
Update 08-18-2016 Okay, here it is, for all the world to see. PLEASE tell me any every thing Iāve done wrong so I can fix it! Mostly, I have no clue about the layout/positioning of the driver components. Please tell me what needs to be optimized there, and if anything needs to be added to it. Also, I think those are supposed to be XP pads, but they look big to me. Is everything the right size here? That unmarked circle under the resistors is a solder pad for Vin, by the wayā¦
As to the Q8-based thrower, hereās a nice idea for cost cuts from Astrolux. Though the light with 18350 tube looks so cute that Iād probably take it.
What about a headlamp with 2 LEDs driven at low current for efficiency that uses a 20700/21700 battery? More capacity than 18650 and more efficient led setup should result in pretty long runtimes with the lower modes en a very high (but short!) Turbo output possible.
Possible led choice would be sst40.
Iād rather have a lightweight 18350 based headlamp and bring a few spare batteries when the runtime is really needed. If you really depend on it, it even makes sense to bring two headlamps.
DBSAR, yes you are right, sorry for again talking about a simple diffuser.
So a Q8 tube compatible head
Driver with less amps then Q8
Single warm led
USB charging.It seems a driver like the ST needs but with less 7135 chips and charging chip
Of course in your proto the total length is more then needed, since you build on a SRK.
You had an inverted reflector/cone planned for sideways light right?
Powerbank function?
Charge the lantern with a solar panel and at night cherfe phone and or speaker.
Ample space and more versatile.Maybe cool to do ST and lantern at the same time aiming for early summer for finishing the lantern.
You have a Q8 ordered?
Not a red lighted switch but green acting as beacon.
*I would love to have to have a lantern head that would work with the Q8-lego system. I made a diffuser out of a translucent bottle that works well with the Q8, but I am sure that a dedicated lantern head would be much better. USB charging and power bank function would be amazing. I wish that the Q8 had USB charging to make it easier to give them as giftās to non-flashlight crazed family members.
Yes the BLF lantern of DBSAR ideally should be ready before summer 2018 right
Has anyone made drawings of what the lantern might look like?
There is a whole topic about it, DBSAR made one based on an SRK.
Pics in OP
And a general idea here
Djozz, just see how much metal is ditched looking at the Q8 an a rough sketch [image]
It would be interesting to see a zoomie built around this optic:
http://www.polymer-optics.co.uk/wp-content/uploads/2016/03/130_Zoom_7Cell_Optic.pdf
and some small, powerful LED. Oslon black maybe? Not very efficient, but I see nothing betterā¦
