Convoy L6... XHP70 Beast!
yes it is with the smo reflector, and dome sliced xhp70.2 with no centering ring
I don’t feel it’s the driver, although maybe. I noticed that the flickering is no longer an issue with the light, but I figure it doesn’t flicker now because the one half of the XHP70 .2 doesn’t light up, while before when it flickered, it was that one half of the LED going in and out.
Even if it’s 1% output or 100% output, I can see only one side of the emitter glow once I power the light off.
Will have to message Vinh about it. He accidentally gave me a tail-switch UI instead of a side-switch UI anyways.
The dies on the xhp70.2 are wired in 2s2p. So if it has been pushed hard and run very hot it’s possible one of those little bonding wires has been damaged and is not getting good contact. That would cause 2 of the dies to not light up or be weaker.
Quick question, would a XHP70.2 be a direct drop-in into my stock L6?
Sure. Just get it on a 20mm DTP mcpcb.
Thanks!
Does Simone sell spare OP reflector for convoy L6?
Not that I know of, but if you ask Simon he may be able to sell you one. You can contact him through his Aliexpress store.
@Tangra If Simon doesn’t sell OP reflectors , send me a PM
ok so can someone link me to some batteries on ebay that work 100% with this light?
The problem with ebay is you never really know what your going to get. Could be legit cells or could be fakes. That’s why no one buys from ebay. Have you checked if Banggood, Gearbest or Fastech can ship cells to Sweden?
Maybe NKON can ship to Sweden too! The prices are not the cheapest ones, but maybe it can help!
sadly neither BG or gearbest ships those batteries to sweden anymore :frowning: i am so doomed lol… i will check nkon thanks.
No, this is a common problem with these new Cree “.2” LEDs. Your’s might be a defective one. A few people had problems with the XHP50.2 when it came it.
I have not seen this happen as like the 50.2, yet? I would try to re-flow it with a bit more solder paste, I had one 70.2 do the same thing, well almost, flickering , low out put, testing on the rock, re-flowing it took care of it. The other thing was too much heat during the re-flow the solder mask turn color ever so slightly and the 70.2 ended up dying. I re-flowed another keeping better attention during the process, all went well!
There is no maybe.
They do and are relaible.
Jaxman sells the liitokala 26650 that do wonders in the L6, just add a solder blob. Jaxman battery link
I have ordered from them and got batteies delivered to Sweden.
Edit: Holy shit i just noticed the shipping price. That have gone up by alot since i bought from them.
I know they are, I recently bought some batteries from them, and NKON and the batteries are reliable!
Took some days (a week, maybe) to arrive but were tracked and came well packed. The shipment is a bit pricy, though…
I normally buy my Li-Ion from an AliExpress store and so far they were reliable too (Sony US18650VTC6 and Sanyo UP14500P): https://www.aliexpress.com/store/1382210?spm=2114.12010612.0.0.5bdadf47w8hvZ5 .
L6vn - Power Pole 300 yards away.
That is SWEEET! :smiley: Nice purchase. I’ve never owned one of his lights. Maybe someday…
