Assuming you don’t try to run the Q8 with only one battery, it never has to.
The batteries are in parallel, the total amp draw is divided by the number of batteries loaded. With 4 in there, that strap will only be carrying 5 amps. No problem.
Well this delay is fantastic. I have literally zero cares about the indicator light. I almost always disable them when possible. I guess our back orders went from end of this month to end of this year.
I just want to thank The Miller and the rest of the team that made this light and group buy happen!! I think it’s great that the communication with ThorFire has been very successful as you really don’t see that with most other manufacturers in a group buy. Usually you end up getting what you get and maybe get the problem fixed later either by a refund, replacement, or parts mailed to you in order to fix it yourself. In this case, the production has been halted so they can address the issue and that is fantastic! I know that a lot of people have pre-ordered their lights and are excited about getting them. Most of us flashlight folks are impatient when it comes to waiting for a light that has been ordered, me being a perfect example. I would label myself the most impatient person here :person_facepalming: . I would advise everyone that has ordered or that plan to order the light not to seek refunds and not to pass up this great light that was made just for us because this doesn’t happen very often. There’s always going to be some type of issue with a light whether it’s discovered during a QC check or in the customer’s hand so this is a good thing…it just means that when you receive your light that it will most likely be problem free! :+1:
From your picture, it looks like you’re showing the batteries with all the wraps, as they are delivered to you. If so, that’s not an issue, because you need to remove that outer wrap anyway.
The cells have 3 wraps:
1. The original pink wrap, just like the flat-tops.
2. A clear wrap, that adds the button top and holds it in place.
3. Another clear wrap, that covers the positive and negative terminals, to prevent an accidental short during shipping.
You need to remove (3), which you know. So, any problem with it doesn’t matter.
If it’s (2) that’s the problem, then that is an issue. You could try to fix it yourself, or just remove it and use the cell as a flat-top in another light.
Preorder 58 arrived today, in top condition. No switch problem, Leds, reflector, springs and glass lens look flawlessly. The screws seem to be no issue at all. It is an amazing flashlight. I love to play with the Ramping. Only is that the O-ring on battery tube may need little bit lube.
I gave away my charger, so had no charger to charge the Samsung 18650-30 batteries. I had to use my Rofis TR20 flashlight to charge one battery at a time with that integrated 0.3A usb charger. Ran Q8 battery check to find the voltage, it was only 4V. So I guess Rofis TR20 can charge only to 4.0V, or it is not meant for INR batteries. I have now ordered Lii 500 from Fasttech.
Anyone have a suggestion on which batteries to get? I’ve never needed 18650s before, was looking at the comparison tool on reddit, but really don’t understand much of it.
Yes I know, and it’s at least a relief that this lousy construction is no imminent showstopper for the use with our C8, but Banggood sells these batteries with the declaration “Max. continuous discharge: 20A”, so I thought it’s a more substantial electrical connection. For Example (a pair of Sanyo 2600 mAh BT-cells I own):
Remember that the button tops are ‘modded’ batteries. They don’t ‘have to’ work just like stock. As the various tests that have been posted here show, different button top like mods produce different results. Solder boobs seem to add the least resistance. I would guess that spot welding the button top directly to the top of the cell would be next best, and this jacked up ‘weld a strap to the battery and a button top to the strap’ would be further down the performance spectrum.
The addition of the button top adds something to the resistance of the cell. So it WILL NOT perform as well as one without.
