It looks complicated, but it’s one of those things that is very wordy to explain but simple in execution.
I use UI 3 and love it. I have my 3 levels set like BeardedRaleigh just mentioned. Here’s my explanation from a few posts ago:
While the light is on, double-clicking will continuously cycle through the three brightness settings. A ‘fast then long click’ moves backward while the light is ON.
Once you get comfortable with the operation, you can also use shortcuts to the three modes from OFF.
At any time while the light is on, holding the switch activates Turbo until you let go and it returns to the mode you were in. This is one of my favorite features.
Out of shear curiosity: Has anyone (maybe ToyKeeper) identified the used chips on the driver or has at least high-res photos of the driver where the markings are readable?
I found this post on TLF where I can see the components or a photo on some russian site but neither A335 for the D1 component or VT1 are readable well enough or can be found somewhere.
From the general circuit it looks like VT1 is the mosfet for the boost converter, D1 is the uC since it has pads for the switch and LEDS and D2 is some kind of OPV?
I’m just curious how they implemented everything (discrete buck IC + control µC, µC does buck in SW, …)
If you are not able to make boost driver design “from zero”, dont try to rechip meteor driver. You will get tons of issuies from hardware that you wont fix.
If I see correctly this is some kind of driver the M43 is based on? Because the M43 is missing some redundant parts that allow for higher currents/faster switching.
The M43 code and driver schematic aren’t available, but the schematic above is similar and an older version of Indigo is available. It’s written in assembly. This may be enough info for someone motivated to fill in the gaps between what is available and what is not, but nobody has created any other firmware which can run on it.
So, nothing Narsil-like on the Meteor.
However, if you want the Meteor UI (er, UIs) on your Narsil light (Q8, GT, D4/D1/D1S, etc), that can be arranged. I implemented most of it one evening while cloning UIs for my new toolkit, and could probably finish the rest in a few hours if anyone wants it.
My Meteor M43 Nichia 219C saved the day! Tonight was my daughter’s Homecoming dance and she had 16 of her friends come over beforehand. It was raining out so they couldn’t take pictures outside. When they gathered in the living room to take pictures, we were trying to figure out the best location, but the lighting wasn’t right. So I ran down stairs and grabbed my M43. I did a ceiling bounce in turbo and the pictures turned out great! There were lots of pictures, so in between pictures I cooled the flashlight with my hands. At times it got very hot, but it never shut down and kept providing great light. Some of the parents were quite impressed with the flashlight. This is the first time I actually felt justified buying such an expensive, but worth every dollar, flashlight.
Thanks for the info - I’ve been waiting for it to reappear, even if that makes things a bit awkward … so many nice lights, so little money! Wanted to get a 2nd MF-01, an MT07S, and either an SRT9 or Fitorch MR35, and now the M43 is available again … someone please convince me that I don’t need any more flashlights! (or maybe just one, or two…) :sunglasses:
Saw this too. Specs were also changed back for the Nichia 219C to 80+ CRI (from 90+ CRI). It’s probably done because they’re busy selling the D1 and D4. My guess…
