No, Joey, I’ve said all along — I want the manufacturer to test samples from the first run properly (that’s QC) and check during production for problems being built in (that’s QA). And I’m well aware of the “quality fade” issue that we’re all hoping to avoid with this production.
I’ve accepted that the first run of any batch is going to have undetected problems because we’re the QC/QA people for most of these manufacturers. That is, we’re the “Charlie test” group. There’s the alpha test (first round); there’s the beta test (did the first round get fixed?); and there’s ship it and “Sorry, Charlie” test group.
If the first round were proving to be good enough, they wouldn’t have stopped pushing them out. Four percent failure in the first 24 hours is one thing. But if that’s an early indicator of a problem that will emerge, that’s something else.
If they are concerned that the asymmetrical brightness is an early indicator that a light may develop the flicker-failure problem, they have good reason to pause.
Trust me on this. I own a Cometa. I’ve avoided a number of the other disaster-batch flashlights that have been popular here.
Talk to anyone who bought one of the bad ones. Ya think they feel different — happier — because they got them early?
Don’t think so.
Oh, did you find out about the secret “purr” setting on the interface? Mmmmmmmmm.
My cat’s jealous.
But the fact that these four lights are showing very similar problems leads me to believe that it’s much more than a coincidence and it bears looking into.
Posted this as an edit to my original post…but wanted to put it here in case it was helpful or relevant to anyone.
It appears after playing some more, that my switch just MAY work like it’s supposed to in regards to disabling the switch LED when the light is off (after reading TomE’s suggestion of how to hit it). It does appear you don’t have as long to click the switch a second time when the light is in the lower voltage outputs…and that timing is a little more finicky…for me at least…than when the light is in brighter modes. SO….mine may NOT be an issue…JUST FYI. ALSO, I just left the switch LED on for the past 3 hours or so and after coming back to the light, it did NOT appear to be flickering or anything.
THANKS AGAIN Q8 team!
And thanks TomE for encouraging me to play with the switch thing some more. :+1:
A little time with a piece of sandpaper on a nice thick piece of mill finish steel can quickly adjust this. I use a worn coarse corundum belt then 400 grit wet or dry on a piece of 3/16” a2. Stand the tube on the paper covered steel and sand while maintaining the angle. Take a few passes while gradually turning the tube to evenly sand the un-anodized end and test assembly and repeat as necessary. When close to aligned repeat with fine paper to smooth the end and do final adjustment. It’s the method I used to align two tubes to the head assembly on my Chimera. Of course, alteration like this would void the warranty.
I’m in Florida where Hurricane Irma just ripped through. Afterwards, no lights, no communication, no commerce, no gas, nothing open. Toilet paper isn’t too far behind water on one’s list of desirables! LOL
My flashlights sure got used. All of a sudden, the whacko with 50-plus flashlights was everyone’s best friend!
Hank I was responding to your flippant “don’t get bent out of shape” comment. I just feel that maybe you should off commenting to members who have now coughed up multiples of 40$ for a flashlight that we now have no idea when it will be produced. Each issue during development led to a month or more each time. Sorry but I would take one with asymmetrical indicator leds over an open ended whenever any day. And most of the other 1600 would too. I am going to wait but I don’t need a lecture on quality control. In fact it seems a few post up that one of the problem q8s now seem fine. I will abide my time as will most other members.
What part of Florida? I’m in contact with someone from high school in Ft Myers and my younger brother in Tampa (busy with construction work doing repairs). Ft Myers got hit hard whereas much of Tampa had power within 48 hours.
Dunno why, but ThorFire has been in a big rush to get these going as of late. I have no doubt it's gonna move quick. Last word from TF was they seem to know what's going on. Not sure I posted these, but these pics were sent to TF:
Last Prototype (round 3): Production:
Clearly they changed the LED's - gold tracing to silver tracing is one sure sign, also a different layout of the traces. The resistors are the same value, 15K, which I recommended from the round #2 prototype after experimenting with them. The prototypes are definitely not as bright. Round #1 had only one LED, so was a different PCB.
I was watching the nhc site and others for days before it turned north and following the movement of pressure systems and spaghetti as Irma moved. I know you saw some rough conditions but were fortunate as were millions of others that early forecasts predicting a direct path through Miami as a Category 5 were wrong and Irma lost a good bit of power following the coast of Cuba. I’m not minimizing the severity, just thankful it wasn’t worse.
After using it heavily for over 1 hour, maybe 30% of the time on max, and then max for 3 min, temp was only 42 Cel in 2 Cel ambient temp. I will not care if the switch Led stops shining, it isn’t that important, will possible disable that Led. Walking in the dark forest with this flashlight gives me complete peace of mind.
Had no switch problem. I will enable Thermal Temperature stepdown and want the switch light to be permanently on to easier locate it in the dark, except when in lock mode.
Variation between production runs? Maybe lights exhibiting this got leds from two different spools as the board made its way down the assembly line. Still waiting for mine - expected delivery friday according to the tracking number.
edit: this situation is why I’m surprised how codes were issued. As I said previously, as an early ‘I’m in’ I was ready and willing to accept the possibility of flaws and take steps to help resolve them before a mass production run as I imagine others were. I’m not criticizing The Miller for his distribution of codes but in future special production runs an early test production run to buyers with the ability and willingness to help resolve problems avoiding putting items in the hands of individuals who just want it to work right would avoid bad feelings and negative press. The individuals involved in the development were alpha testers. Recipients of the first production run are beta testers. I’ve done both with software so it’s not a big deal to me.
Come on man… Production has been halted less than 24 hours. I know everyone wants their light but Thorfire doesn’t want to send out lights with issues. Their name is also on the line here. They have something like 1500 units ready to be assembled that are now just sitting doing nothing. They want this fixed more than any of us. This hurts their bottom line.
Your ship date on banggood likely says 10/7 or around there. I doubt it will take that long to get this fixed. Just give them some time. Don’t get mad at everyone on the forum and Thorfire. Things could be much worse.
They see the problem and WANT to fix it. Before anyone else gets their light. This is a good thing.
If you are in ramping mode, go into the menu by holding the button 8 seconds. This is shown in my video. You get 2 fast then 1 slow blink, wait, then 2 fast and 2 slow. Now you can press the button once or twice and look for the light to blink on each button press. Now just wait for it to exit and you see 4 fast blinks.
The 2 fast then 2 slower blinks means setting #2 which sets moonlight level. You have 1 to 7 different levels to chose from. Default is 3. Do if you want to go lower you can choose 1 or 2. Keep in mind that going lower might work or it might make some of thd leds not light up.
That's pretty much it. See the posts by Tom Tom for details, but there are two issues:
The LEDs are in parallel, without individual resistors. In this configuration, the LEDs really should be matched -- ideally, same manufacturer, same production run, and same wafer if possible. Once you start mixing LEDs from different manufacturers/batches, all bets are off, and cases like bright/dim LEDs can certainly occur.
They're operating at very low currents, which is an unspecified area ("off the datasheet" as Tom Tom puts it). It's possible that some batches of LEDs require a higher voltage than what can be supplied by the 15K resistor, which could be the cause of flickering/off LEDs. What works for a few prototypes might not work in production. This is further exacerbated by the previous item. It's also possible that Thorfire got a batch of poor quality/counterfeit LEDs (ensuring parts quality is a big issue these days).
