If you are in ramping mode, go into the menu by holding the button 8 seconds. This is shown in my video. You get 2 fast then 1 slow blink, wait, then 2 fast and 2 slow. Now you can press the button once or twice and look for the light to blink on each button press. Now just wait for it to exit and you see 4 fast blinks.
The 2 fast then 2 slower blinks means setting #2 which sets moonlight level. You have 1 to 7 different levels to chose from. Default is 3. Do if you want to go lower you can choose 1 or 2. Keep in mind that going lower might work or it might make some of thd leds not light up.
That's pretty much it. See the posts by Tom Tom for details, but there are two issues:
The LEDs are in parallel, without individual resistors. In this configuration, the LEDs really should be matched -- ideally, same manufacturer, same production run, and same wafer if possible. Once you start mixing LEDs from different manufacturers/batches, all bets are off, and cases like bright/dim LEDs can certainly occur.
They're operating at very low currents, which is an unspecified area ("off the datasheet" as Tom Tom puts it). It's possible that some batches of LEDs require a higher voltage than what can be supplied by the 15K resistor, which could be the cause of flickering/off LEDs. What works for a few prototypes might not work in production. This is further exacerbated by the previous item. It's also possible that Thorfire got a batch of poor quality/counterfeit LEDs (ensuring parts quality is a big issue these days).
Yes, again, we well understand this. I took these pics back on Sunday:
Prototype: Production, unbalanced one:
You can clearly see on the right picture, the right LED is throwing out more light, lighting up the green PCB to the right of it. Isn't that right? We'll get this righted yet. Oh man...
This is tricky. You have to unscrew the switch cover ring, then use some tweezers to rotate the pcb. You might need a hook tool to lift the pcb up so you can twist it slightly with your fingers. Then push it back in, add the rubber cover and screw the ring back on. It’s possible the pcb can rotate while you screw the ring back on so you have to watch it carefully. It might take a couple tries to get the lights perfect.
This is why the leds are not perfectly aligned from the factory. Its way too fiddly. Lol
Are you forgetting that the Q8 ships from Thorfire and not from Banggood? I think they are in 2 different cities. No telling how far apart they are. Could be hundreds of miles apart.
If you have a hot air station you can easily remove the old leds. If you only have one soldering iron you have to rip the old leds off. Break them in two pieces then you can unsolder each end.
You need to then clean the solder pads. Verify the direction of the new leds. Add some flux to the solder pads. Then hold the led down with tweezers. Just quickly touch each end and that should solder it in place. Verify it works before soldering and after soldering as it’s easy to get the leds turned around.
I’ve swapped leds on the switches of both lights in my sig. They are different pcb, but the basic concept is the same. There are several pictures. Hopefully that will help.
I understand exactly what you are referring to now. :+1:
And while I really do not expect them to line up… I do find it refreshingly nice when the battery tube and head do line up in some discernible pattern.
Some people don’t have a preference, no problem there.
Some of us do have a preference, no problem there either.
There is no right or wrong to be understood. It simply boils down to personal preference.
In fact… the majority of the lights I own have a discernible pattern of symmetry between battery tube & head.
In fact… Nitecore either indexes them during manfacturing OR I have been extremely lucky. I cannot think right now of one Nitecore light I own that does not have the symmetry we are speaking of. I own a bunch of them too.
But back to the Q8…. just the luck of the draw on this one. You’ll either have to try one of the fixes mentioned or live with it I guess.
I got lucky… 2 of 3 so far have had the symmetry I like.
The third not at all…. But, it just also happens to be one that arrived DOA today.
If I had been looking for an omen I would have known it as soon as I opened the box & unwrapped it.
Mine arrived yesterday. Very satisfied!! Smoothest ramping ever. I wouldn’t use the Police strobe inside. Your eyeballs will let you know after. I have been carrying it for a day now. The comments from people I showed it to are all good. Switch LED’s are good but also bright. It does take getting used to the click timing. Everything works as supposed to. A couple sharp edges which I shaved down and “sharpied.” (Edge burrs fourth fin from bezel above 1/4” thread and same above switch) E lockout nice or slight turn for mechanical. I leave it powered on with switch glowing. Easy to find at night and no problems. I believe you will be VERY SATISFIED when yours arrives. I look forward to my next arrival. Throw is good as is tint. Great job on the printed cheat sheet! Best to all.
Once you get to the police strobe, you can easily cycle up and down the 5 blinky modes. Press and hold and the lights cycles backwards to regular strobe and you can then click normally to go back up to the bike strobe or beacon, etc…
Honestly, all I use is the ramping, double click to turbo and triple click for batt check. That’s all. No need to memorize anything else. Save the other stuff for reading in the manual.
I know y’all have it covered Tom. :+1: … I was just telling him the way he worded it painted a perfect picture with the switch cover on.
He nailed it creating a verbal image.
Mine arrived today. Switch lights appear to be working fine after a few hours. I do notice that one is slightly less bright than other, but only when looking up close.
The flats on the battery tube don’t exactly line up with the flats on the head, but that’s not a big deal to me.
Otherwise my only issue is my thumb not being used to the switch - I end up doing click-holds instead of double-clicks more often than not. At least I don’t need any of the double-click modes very often.
Hearing that your 3rd one is DOA is real comforting, considering some of us would settle for a single unit that maybe had a off bright switch led.
Waited a year + for squat. On a list that means squat.
And What happened to the order list near the top of the OP??
Pffffffff, vanished. Funny how that happens.
Disgusted.
My thought was two workers were tasked with placing the emitters and working from two different spools. It seems possible to me but I could be wrong but the best possibility of balanced output is sequential emitters from the spool followed by testing with a calibrated voltage/current source. In a mass test groups could be wired to power in a manner that split voltage and current and uses photos to isolate extreme variation between emitter pairs. When doing calibrations I sometimes did ‘gang’ cal of groups of low accuracy (±3% or +) voltmeters where the combined uncertainty was less than the certified accuracy of the standard. Not endorced procedure but after testing groups of meters and following up with individual tests not one failed. A superior kind of freaked out seeing me do it but every meter I passed was within tolerance when re-checked.
