My thought was two workers were tasked with placing the emitters and working from two different spools. It seems possible to me but I could be wrong but the best possibility of balanced output is sequential emitters from the spool followed by testing with a calibrated voltage/current source. In a mass test groups could be wired to power in a manner that split voltage and current and uses photos to isolate extreme variation between emitter pairs. When doing calibrations I sometimes did ‘gang’ cal of groups of low accuracy (±3% or +) voltmeters where the combined uncertainty was less than the certified accuracy of the standard. Not endorced procedure but after testing groups of meters and following up with individual tests not one failed. A superior kind of freaked out seeing me do it but every meter I passed was within tolerance when re-checked.
Thanks tekwyzrd.
Hurray for BOINC, by the way.
So with 2 LEDs in parallel, the risk over time down the line would be if one of them dies or its connection
fails, all the current goes through the other one and fries that one? That would explain a cautious approach.
Hearing that your 3rd one is DOA
Who are you referring to?
What do you mean by doa? The switch led or the flashlight?
Nah, if one burned out it would be like a 7.5k resistor on the other led. It would be a bit brighter, but not burn out. I think Amplificus shorted the resistor and the leds did not blow. They just drew way too much power so the battery drain is much higher.
Don’t be this guy/gal
Be these guys/gals
Or you could just be me
who says lighten up people.
Cheers David
Switch leds measure 2.246v each with batteries at 4.008v. In case it matters.
If you have a hot air station you can easily remove the old leds. If you only have one soldering iron you have to rip the old leds off. Break them in two pieces then you can unsolder each end.
You need to then clean the solder pads. Verify the direction of the new leds. Add some flux to the solder pads. Then hold the led down with tweezers. Just quickly touch each end and that should solder it in place. Verify it works before soldering and after soldering as it’s easy to get the leds turned around.
I’ve swapped leds on the switches of both lights in my sig. They are different pcb, but the basic concept is the same. There are several pictures. Hopefully that will help.
It’s been many years since I did this, but I have had luck in the past using two irons - one in each hand, with the tips on each pad. Use the tips of the irons like tweezers or pliers by pushing them each towards the other and lift the part off the board.
I’ve been playing with the UI and have a question since you asked JasonWW.
I am back in ramping mode, and have configured Moon mode for the lowest level.
Click and hold starts the light from a low and ramps up - as expected.
Ramping it back down, I get a switch blink at a fairly low level. - as expected.
I can select a level, turn the light off and with a single click I get the remembered mode. - as expected.
However - from off, with a medium click - I get this crazy dim moonlight level (I like it - it just does not seem to be in the cheat sheet or the doc on post 2.) This seems to be the only way to get into this level. I can’t ramp to it at all.
My eyes are a little whacked right now - mostly from the Q8, but also staring at a monitor. So I’m going to go sit in a very dark room for a while and see what this level looks like.
I’m just wondering if this is a know feature or an easter egg?
Just want to pass it along that ThorFire is sorry for the delay, and they think they can work out the SW LED issue quickly. Don't know, or am sure, of all the details, but sounds like they will go with a 2 resistor design, and go back to the LED's they used on the prototypes. They are also looking at some of the screw issues - no promises there though.
I was actually about to comment on that Lazy-R-us. So what is happening is that via ramping down the lowest level is ALWAYS the “default” level. The only way to get to the user specified level 1-7 is to hold from off and it turns on in that mode, then you let go immediately. Also something that bugged me… I set the moonlight level to 7 because I dislike moonlight and always ramp up for a moment before using my lights, but if you long press to get my default value of 7, then keep holding in, the ramping dips back down to the default of 3 before ramping up. Essentially ramping doesn’t reference the user specified moonlight level as where to start ramping and always starts at 3.
The screw issues barely bother me, but I’m glad Thorfire is working expediently to get things shipping out again. There is light glue on the tail cap spring board but it wasn’t like a loctite, just kind of sticky. It was also between the board and where it contacts the body tube. I cleaned it off on mine, but it wasn’t an issue, just something I noticed while being nosy. All of my screws are in good shape.
I was expecting this light to get hot, but even after 8 minutes of turbo it’s barely breaking a sweat. I really like that, turbo is a practical mode.
The Miller:Nr.Scott, can you run your program again? Ought to be the last time but getting us to 1250 people
The Q8 list (from post #1) sorted alphabetically .
UPDATED AFTER CLOSING POST 10767 page 359
1249 names
1723 lights
2 DOGS
186
264
641
2Ace
165
1119
2auroras
1698
5ar
697
7pot
982
a12luke
932
a_idiot
740
Aardvark Spleen
253
402
403
aaronchen
1510
1511
Abe87
876
Abqjohnny
51
1169
abril
50
acml
1455
acruzangels
1429
ada_potato
1379
1411
adirondackdestroyer
545
adrianlights
255
adsum
1477
AEDe
923
Ag76
1345
aggillator
458
aginthelaw
278
Agiri
110
Agro
1488
aim120
430
AirBreaker
155
akhyar
387
akoposilester
56
1111
1112
akovia
937
alberto7
1492
1594
albertopnp
365
Alcius
105
alejandrov
523
alex64
1159
AlexGT
495
alifpb98
1681
Alkpwn77
204
allthumbs
218
alphazeta
335
1638
alternety
564
565
Alux
702
amplificus
904
983
984
Andmiller
1064
1065
andrewmac
407
Andybibbville
147
Andyman
13
Angel Martínez
128
ant0
1195
Antenne
801
Anthon
568
antilop65
1448
antiparanoico
32
AntLion13
1454
aors10
1487
AppA
1208
aprendiz
1160
1261
apt323
47
544
archi
1157
archimedes
67
arditty
1577
arekm
1605
aremihc
910
Arikuzo
1715
ARMS.AARON
1089
ARsee
1228
1229
Arufonsi
921
aslpg
398
asnidi2
1327
asot
690
Astromanic
424
AsylumSweep
863
ataleoffiction
1630
atbglenn
567
Atom00
358
359
Aurora
1587
Autistic
1532
1533
Autoclave
1099
autodidact
1503
Awdtsi
1221
Awkward Stretch
619
AwkwardPause
464
b1i1l1l1y1
1052
B42
685
686
1019
1020
BackpackNY
571
1084
bakalakos
202
balazs1956
1341
baldo21
260
261
Bam35
1039
1592
bamawthu
599
banker
1013
basslovin808
446
Bastarrdo
117
Batch1
293
344
battletross
809
bawilson2
500
501
Bc412
5
bd52
399
BDM
1018
Bdubelyew
1542
1543
1664
BDWrabbit
1244
beam0
1424
BeardedRaleigh
662
1612
1687
BeaverNutz
1602
bella-headlight
49
411
877
Bernard
232
Bevo
1086
bf125
1675
1676
bhuge00
1049
bickle
1463
biczownia
1648
1649
bigpix
84
bigrick
754
bikedave99
1174
bikenber73
14
Bill 63
752
1296
1725
1726
Bill_tong
896
Billcheese5
949
BingoThink
1537
bionictony
1338
bkling
1067
BlackList
1350
bladesmith3
607
BLFD80
933
BLightSam
1443
BlindingL5s
312
blinker
1306
1353
blinky
1209
blueb8llz
70
553
1120
1121
1122
1123
bluecheesbob
1557
Bluzie
785
bmaddison
248
Boaz
391
BobbyMK
462
bobdotorg
1271
1272
1427
1428
bobofire
1313
Bogdan
370
371
1711
bogdanr
466
Bohemian
775
bonfire
412
Bong lick
763
1075
Bonham
262
boostedsubie
1699
borealis
1098
BorisBar
575
1238
Boro
360
361
bossf350
803
Box
671
boxuvrox
1559
Brettg4215
864
brewskVT
1449
Brian Metcalfe
318
319
374
brianch
1450
BrianK
447
560
1356
BrianTheJay
950
Bribo
1582
brightlights
243
brittnell
1523
brjones
504
brno602
913
brted
249
brujeria
1578
Bruno28
513
BT100
1087
1138
Bungle88
610
Buzzy243
1179
bwl123
870
cabfrank
443
1728
caffeine_addict
1624
Caleb
203
547
Caleb-v
444
Calmaja
35
Candil
1397
1418
Cano
661
1151
Captainvideo
1302
caramba
748
carmantl
345
346
casi29061965
467
490
1409
Catul
1441
cavesprings
1406
1708
cavorite
1028
Cawi
1276
cbrake10
749
cccpull
1496
1497
1498
cclight
897
cdjaney
825
Chadvone
63
693
Charga
124
Charledflash
1608
charles lin
1124
CheapThrills
469
cheesecheeks
816
ChibiM
1310
1321
Chicken Drumstick
131
chinooker
1260
chooma
210
351
chrisc
741
742
churchilllafemme
1230
CircaM
894
Cirnyan
1445
CJ Avlis
1459
Cjlee89
951
cjoe7
146
CJW
367
clagged
991
clange50
479
480
ClaudeMBallz
1431
clinicdoc
1226
Cliwilnew
795
cloggy
404
cmflippen
83
cnrffl1
577
1113
cocoschnauzer
363
commercialcatfish
1631
compression
1410
ConcreteTurtle
1678
contigo
1351
Coolerness
664
coolriku
517
Corzy
308
Couchmaster
245
551
552
cpd800t
406
CrashOne
372
377
craziplaya21
1695
Crazyeddie
98
137
487
Creepo
909
cristhemuso
388
crx88ia
683
cujo255
1191
cwb
134
cypher1024
973
cypherz
250
Cythras
956
D10ten
608
Dadpool
1161
dafarui
1339
Dakotan2
1549
1550
Dan-G
1679
daninho
468
DarkerInSol
615
616
617
618
darkpenguin
718
719
735
736
737
738
739
860
861
862
darol
798
darrenm
1054
1055
1719
1720
darrylo
507
DarthTader
830
datiLED
761
dave101
1041
DavidEF
7
davidkappelt
1026
davidvns
1128
davos
1062
DB Custom
713
722
997
dbesselt
1156
DBSAR
136
169
1281
DBSS
516
779
deathless
518
Deep skull
977
DeJaVu
669
dekozn
800
Denka
1710
Dennis
934
dentillozie
488
Dep668
687
688
derfyled
1237
derpilgerer
630
Desmo
805
devdvr
486
Dewalt101
1552
dezoe
1186
dglb99
1553
dhsvcs
265
1336
1337
dicksog
559
digitalMessiah
1566
digitaltc
1323
1401
Dikkedikk
1663
Dimking
425
Dirt
815
Dirty_Pierre
1045
DiscoJoe
1254
djburkes
188
878
Djozz
3
1115
1286
Dman7777
1685
dmbaty
1294
Dobtruckers
1058
DOCFAR
595
Docp723
347
433
434
Doctawho
440
dodo
88
274
dogany
813
Dogsrule
508
donpachi
1252
dotBLF
968
doubleone44
887
downlinx
74
316
doxerino
1304
1697
Dr Forinor
873
Dradge
1248
Dralf
1015
Dregs
172
DrHook59
883
driveX
659
drjamesfox
1671
DrJones
75
DrMcNinja17
1507
1508
DT101
152
dudunphy
389
duhduhduhdiabeetus
1461
Duke
381
dukeface13
1460
dumbbutt
1618
dumptruck
971
Dusty
327
328
Dutcheee
68
322
duvallite
889
dw911
478
Dwantink
135
dzagow@yahoo.pl
1700
e10sno
405
1318
1319
Easyrr
6
eb1888
837
838
839
ebosh
777
eddamoo
1574
ediaz
906
eebowler
774
Eggun
1104
1312
egrep
594
Eivwer
171
electricjelly
237
256
ElginAgain
1204
1362
1394
1395
1643
1644
emarkd
109
embee
511
Enelooper
417
engber
947
ERDOS
1150
Erethryn
1259
erikbuch
1634
1635
erikk365
648
Esskay
995
Etex
829
etienne440
1516
euphxenos
408
everydaysurvivalgear
103
Evilc
65
Evo1986
1554
1555
ExtrabrightExtracheap
1432
Eyao
1529
EyeballFryer
189
Fadetoblack
1295
fantomR
636
Far Thrower
148
197
Farmboy24
1234
Farns
277
Fatlight
663
fatsteve0
1361
FBsLights
790
fcrespi
1262
fed893
307
fedcas
902
feralcomprehension
1194
1311
ferthur
1458
Festizio
1515
FindThisHumerus
1466
finges
561
fireblade893
209
firedome
324
711
Firelight2
397
fischju
1462
fishlite5
1046
fixed it
78
1097
fixvid
1264
Flash Voyager
652
Flash-O-Maniac
1414
flashination
87
FlashMax
1225
Flashy Mike
239
410
448
449
flasky
1597
flatbear
1451
Flifish48
806
1096
Flintrock
629
Flomotion
1696
fluffman86
958
FmC
1182
fonfan
234
1023
1024
fonLED
725
Ford Prefect
1068
Foston Pete
453
454
644
foton
1030
fourtogaraffia
1446
Fozzy-SP
317
Fractal147
1665
Frank A.
1172
Frankie Baby
342
Franz
788
Freddy61069
282
Fredylee
223
1329
FreeMagenta
1050
1609
1694
freeme
514
freethink
1484
Fritz t. Cat
484
Funzel67
990
fuzun
1074
fyesilova
535
g17jimmy
1440
g60
290
g_sintornillos
126
gamezawy
38
336
Gammel
1544
gangstead
53
922
garrybunk
254
gboss
832
gds95
1199
gearowl
1415
gedasd
1309
geepaw
1038
Geese
1575
gehrmo
289
geo1952
455
457
ger-slash
416
Gerrh
531
1163
1164
1285
Gerrit
106
getbully
609
1263
GF357
1509
Gilatabar
638
giorgoskok
306
493
1092
GIR
804
818
Giraffelight
1606
gisewhcs
384
Givememyhatback
1520
Gj
580
581
Gladimir_Gluten
1585
gleamer
432
GlinnDamar
1342
gnatx
588
824
goatfarmer
770
gokalpm
1393
GoldenBatt
383
589
590
gorb507
811
812
goshdogit
11
12
40
120
121
543
556
928
Goud
1468
gpapa693
79
gravelmonkey
1027
green_comet
601
GreenShrike
190
gregfortune
1576
gregor
215
Grieflar
1491
GTsuperheros
179
Gtt980
936
guerrilla154
1316
1422
Guggga
538
GulfCoast
880
gungoat
44
Gunnerboy
252
967
Guns712
1300
1301
1369
1370
1627
1628
h2o
181
476
Hairy_Steve
340
1367
hank
258
1385
Hardware
1071
1200
Hauwexis
845
846
847
848
haxquiz
226
927
headburger
592
heatwaves
994
1265
hein11ag
183
Herb Tarlek
931
Hestbech
994
995
hexcode
503
672
Hezekiah
286
759
hideehoo
859
HighCaliber
177
178
hmihaylov
502
Hobo
220
hunter1
116
720
721
hurleyy
993
I_like_lamb
915
Ian2381
150
igeigeige
890
IH8MYX
546
ii_pennies
481
ikaruz_500
989
ikkentobi
1423
Illumenated
426
illusioned
954
illusum
1667
Ilmatic
1253
1332
1493
ilovejesuschrist
294
295
ImA4Wheelr
19
ISO
705
734
929
930
Itsme
1495
1645
iwandutchy
1047
J-Dub74
461
J_R_J
675
jack-bkk
356
jacktheclipper
1108
Jailbrake
1034
1090
JakeDjanitor
46
Jalben
187
jama
635
jamaya
1604
1647
1703
1704
Jambo
912
james y
1043
1044
JaredP
1570
jarfield
1558
Jarms
1621
1622
JasonWW
1399
javipiloto
1154
Javsuzu
1593
jaynick
1048
JayT
62
JayWallis
1387
1388
Jayzed
1214
jb1
224
jbailey94
1586
jcconnell
1629
jctron
1489
jdh00
1723
jdunlap27284
164
jealous57
81
jeanlouis
1478
Jeffstanton
1380
1381
1382
Jensa41
731
732
Jerommel
637
jerrod
512
jescereal
228
Jesjes
153
154
jfalk1
918
jhalb
297
JHost13
1583
jhullin
159
751
JIGHEADWORM
1413
1420
jingleberry
1022
Jinx
93
jkbam
550
JLAu
1421
JM87
1470
jmoots
268
jmpaul320
95
299
jmwhite151
482
851
852
853
Joat
184
JockRobbins
717
Joe Darkness
620
joe1512
534
joeangi
756
1390
1391
1392
joechina
633
1437
Joey Adams
1021
1132
John-Galt
463
Johnhywash1
966
johnnydoe
1227
JohnnyMac
496
johnpc
955
johny723
1082
Jonandreadolan
1072
JonnyC
576
JordanZHP
1078
1196
JorisFRST
1404
1640
josephqool
1061
1417
jpaolosy88
1677
jpcuba
684
JPLight
23
646
JPM3
263
264
jrummer
1439
JS721
216
jsmn4vu
793
jtechl
1513
1514
Jtm94
1035
Juanesdan
118
juaquin
219
Juggeli
745
juhha
1540
JulioElGuapo
1526
Jump909
1569
jurasik1
1231
justanotherguy
541
712
1080
Jvrthp321
691
jycheang
1009
k-wong
542
1005
Kafar
9
kahvitahra
796
Kalchev
400
kali stupa
1217
Kalihi
836
kalkat
1373
KawiBoy1428
230
kaybi
1033
Kazik
1315
kbmeister
1589
kbro
168
keengeorge
309
310
KeepingItLight
992
Keepitsharp
175
1613
Keisari
1211
1212
keithd
753
kemosabi
1438
KenE
355
Kenjii
385
Kentuckywindage
797
872
Kepling
333
kevinfc
1426
KFulton
1331
khas
628
1661
Khuan
1148
KIKY
1340
Killforfood
272
379
Kindle
698
KingSmono
578
kiriba-ru
525
Kiukas
640
KiwiKane
174
Kkelleher
99
100
101
102
Kloepper Knife Works
194
195
196
knightstalker
1219
kntx
1073
1116
1189
knudsengj
1106
Koaksijalac
104
Kodachrome40
170
1282
KoekieMonster
161
kommessy
108
korpzgrinda
1029
1133
kotobuki
799
1143
1144
koyotee
276
Kozy
58
129
krisztianaMG
1709
krutone
1298
kubed_zero
1442
Kulumatic
914
Kurt_Norway
593
Kusie
8
17
KutKhemist
123
Kysumi
925
LAB
259
lachesis
673
lacrimosa
1683
lalomt
1167
Lamont56
808
lamper
727
1171
lanceb1b
884
laststance
972
lawallac
393
394
Lazy-R-us
25
900
1249
1250
Le_Zouave
71
leaftye
694
1103
1183
1184
1636
1637
LEDtec
823
leestrong
1688
1705
legan710
1088
1476
1682
Legolas Jr.
130
leroycp
236
266
450
451
Lexel
696
1287
Lfatman
707
Liber8
537
lichtpfadfinder
1292
Light of Earendil
700
Light Years
1680
lightbulb
281
lightknot
471
492
598
lightlight22
772
920
1040
1328
1479
LightMan541
1469
lightmog
72
lightx
757
Lilien
978
Lim_Wee_Huat
1721
Lion42
246
1408
lionheart_2281
33
litcrit
871
Litefighter
1320
1334
1335
litenutz
1371
LloydV
767
Loneman
510
903
1706
longmire
1256
Lopan
1069
1416
lovetheguitar
981
Lowtech
1042
1193
ludolf
348
luisgcan
1162
Lumenmaster17
1145
1146
1147
Lumens Industry
634
lumiere
231
Lund1660
64
439
luongshot
1525
luxlad
831
lyse99
1012
Lyubo Yanev
427
428
429
536
M4D M4X
350
M78
157
337
1007
MAC72HU
1718
maciex93
1713
MACS0647
313
MAD TM26
656
657
Magbrite
584
magnet
302
MagPap
794
Maiden666
92
maildroid
331
Majoroverkill
919
malamask
113
MaleNurse
1472
mandala
952
953
Manheim69
1518
1534
Manimok
1623
manithree
1255
Manulous
1270
ManWithoutShadow
1100
1299
Mapache
4
Marcello
1456
marcus_z
1375
markalike
602
Marothar
1236
marsalla
475
Martini
82
726
martook
48
martytown
976
Masejoer
842
Matchoo
905
matkovicha
1185
Matomoto
1324
mattlward
16
34
214
MauiSon
42
979
maukka
225
627
Maxxsounds
681
1641
1712
MBuitendorp
1210
mcfarlie6996
964
965
MCT
162
Mecallie
1051
MechEngVictor
275
Medvegy
660
Melven
167
meti
470
metz3006
843
Meyer
138
mezzmen7
1374
MG
353
mhanlen
77
mi bill
127
Micael
858
mightybonk
1535
Miguel_79
1114
1129
Miguelintegral
1175
Mike72
1403
mikey1299
1620
mikeyx
622
Mindaugass
769
1081
1490
1668
Minimoke
30
975
miraclenip
1547
miswas
760
Mitko
26
27
mitrhandir
1303
mizjif
714
Mkduffer
600
mlodyulek
1283
Moe_Suki
24
moemin
375
MontyPyfon
66
moridin
907
Morpheus
613
MorpheusT1
762
MortyDuck
764
MountainKing
438
445
MountainMan
786
787
mozart.f
314
Mr.Poppy
192
267
1247
1308
Mr.Scott
251
1077
mrheosuper
1110
mrkelvin
606
MRsDNF
325
326
mrstealyourgains
1014
msg1285
173
Mstevens113
114
Mt.B
392
MtnDon
158
498
mud_muncher
624
mudguts
680
716
muellihenry
1396
Muto
20
242
689
mutts13
1343
1348
muzzleblast?
89
mxlu
396
MyDangus
1181
Myers
1724
myflashguy
1619
myowin
213
1235
myst999
198
728
1266
1267
nanojack
1036
narin000
524
Nathan42
946
987
1365
Navin_R_Johnson
817
NavyHammer
1588
neckbear
935
needmorlts
911
Neilyboy
1307
nemo001
1674
netprince
176
378
Newlumen
1425
nexrace1
579
nfetterly
362
366
Nguyen
1277
1293
nickdude
591
Nickke
604
1652
Nicolaas
857
Nicolicous
270
Night Light
1093
NightLight
369
Nightshade
574
niktak11
782
Nil
959
960
1447
Nine9n1ne
1436
nishayume
1419
Nite Shadow
1001
Nitetime
163
nitrader0
1203
nnmnu1
1349
No Agenda
431
nodoubt
1591
1614
1615
noetik
1572
nofear87
382
Noki
573
noob
828
833
1025
1386
Nord
1170
1656
1657
1658
1659
1660
nordlicht
1541
Nortson
810
NotVeryBright
1642
novice1
338
nqcken
119
241
nskn71
1136
NuggetMcNugget
166
332
nvanlaar
1650
nydude
1646
ObiWan-Kenobi
422
423
octav
666
OdorlessCurves
529
530
Ohmypotatoes
1517
ohnonothimagain
1357
olivedrab
658
OrangePeel
1275
1288
orinjuse
835
Orionz23
1168
osb40000
193
OscarM
1290
Oswald3211
724
oto
888
Ozythemandias
625
Pablogy
441
PabloVerde
1037
pacbough
149
Paetrw
1519
1563
papaslightsaber
583
1125
1126
patchythepirate
704
1364
patman
1521
patmet
1347
patmurris
55
1355
Paul321
139
pawwright
151
PBWilson
557
558
peabody
207
Peetz
311
Pegaso
122
Peho
112
pelle470
1467
Penguin
1433
1434
pepe2017
1305
pepinfaxera
1158
perche
1155
Perdu
1571
peterlcole
924
peteybaby
549
petr9999
1137
Petroleum Lantern Guy
891
Phantom1
1372
Phoenix_FIN
395
PickleFuzz
1531
Pidro
465
pieman7
670
Pin8
1528
pipa
1722
pirate joe 22
678
679
783
784
pistol86
1378
piyoman
840
plntigrado
1153
pommie
54
pomokey
1670
pook
330
pooptoast
519
powerfultorches
569
praveendk
437
prdonut2k7
1579
prepro
1580
presterjohn
586
715
Presumptuous
653
654
655
Primal
364
prisma
401
Prodeje79
1481
Prometheus
1149
ProtaBLF
419
pscal
376
puccio1969
76
Pukachi
205
pukoid
868
Pulsar13
288
1412
qandeel
631
632
qBawl
1539
R.D.
974
radb
856
rag
283
298
Ragsy
499
1117
Rah_BE
1625
raiko
570
rajun50
651
ramius
1584
Randolph
212
RapidLux
1346
1360
raqin
1551
Rat_Racer
999
RaVeN
160
rayman007
1633
raynman
706
rdoc613
879
ReallyInToCheese
1568
red72vw
521
RedForest UK
1366
redrider706
1359
regaia
1008
1486
reliant_turbo
710
850
ReManG
320
reno
1118
retiro675
352
826
rexdog
442
515
rfd673
747
ricardon
300
Ricflair
323
Rick
199
rizky_p
1405
rjorge
708
rmkline
436
Rob_K
244
robbobus
233
Roberrt777
185
RobertB
140
rocketshipdog
1500
1632
RocketTomato
766
RockHugger
1173
RoloFresh
1524
Romey310
969
970
RonMuller
111
rossysarus
1465
Roter
649
RotorHead64
1284
rova2014
1473
Royo
1407
Rpdos
1180
Rska
650
Rsqweezy
814
rufrydr
765
Rufusbduck
60
Rxich
866
ryukin2000
1220
sac02
645
908
1215
1216
SachaTheHippo
1686
saf99
755
Saigon
247
saintsagan
1485
Sam3gX
1662
SamHaLeKe
485
samis
509
samnavy
73
san san
926
1130
1131
sandanbob
532
Sarge930
86
Savydude
1222
SawMaster
45
saypat
141
sb56637
191
scarnific
566
scdaf
271
296
Schkü
614
schlockproof
612
Schoki
1581
Sciencetists
257
SciFiFreak
31
Scooby
582
Scooter000
315
scootypuffjr
844
Scorpia
596
scotlarock
329
1085
Scottland
334
Scotty
746
scs
80
sebastiang
611
SebaZ74
1239
1240
SeenTheLight
301
819
SFB
1109
Sgtpev
206
Shadowcactus
916
1595
Shadowfax
341
1701
1702
Sharpie
354
shimano3000
409
shimey
211
shirnask
61
733
1384
Shoe
957
shogan
227
Shur
284
SIGShooter
368
1565
Silent_Star
1190
Silentcropduster
667
Simplelight
961
962
slackwolf
885
886
1000
slatzman
1560
Sledge
980
985
986
1326
Sledgestone
677
841
slickpenguin
643
854
slimkango
52
1207
slow2go
221
222
692
1139
1140
1141
1278
1279
1280
smed1275
494
Smittymojo
768
1142
SmokinH
855
sneakyfart007
1522
Snoballz
1031
snowe
1600
1601
SoCalTiger
1344
sochi111
1032
Sofa
834
sol
291
292
SolarLumen
776
solRNY
1291
1707
somnambulism
562
Sonpham
621
Sordoslux
1402
southland
142
143
144
145
sp5it
94
1201
spade413
1178
sparkyDK
1188
specialk
865
Speed4goal
413
Speedsix
1083
spinynorman
1400
spkzzz
474
526
Sprinkles
279
778
901
square74
1538
srs2000
1187
stanley-beamish
107
starcrazed
1330
stareye
540
staticx57
238
steel_1024
709
Steenbhg
701
1205
1206
1268
steepdrop
435
497
Stephen Elliott
1322
stephenk
269
steve-o
1376
steve42
1016
Stevejj
1218
SteveMidwest
1289
stevez32
822
StinkyTool
1480
Stittville Ed
85
998
Stoneface
758
1127
strango
96
strayz
505
Streamer
1246
strmix
676
strobed
1368
1598
Stud_nut
1504
SubSailorVet
1501
1527
Subterrestrial
1003
Sukoi
642
1010
Sullysat
418
Suncoaster
682
Swennie
895
swissbianco
1599
Syncmasterklop
867
syracuse
349
systemagnostic
1617
T-boon
304
T18
390
1257
t3rminal
1213
Tadashi
1471
Tally-ho
1573
1727
Tangra
1639
tapir
489
tarver
132
229
Tarvos
15
tas69
380
tatasal
506
teacher
321
1134
1654
1655
tebeve
893
techieman33
456
Tecmo
57
tekwyzrd
37
tenohfive
802
Terry White
1435
Tete
217
Texas_Ace
472
473
The Burgh
235
The Grand Pooh-Bah
1056
1057
The Imp
1242
The Jinx
522
699
The Last Katun
90
The Miller
1
2
The_crx
1672
1673
The_Driver
1352
thebaum
585
807
TheConsultant
1453
thecrc
1177
TheDude
415
TheHebrewHammer
820
821
TheJo
1053
Thekernels
1536
TheLonelyLumen
1444
themacman4
1505
TheMadcap
97
themagicconch
1464
1494
themaindude
343
1094
1095
TheManMKD
1546
Theodore41
520
theoldbill
59
TheOnlyDocc
1135
thslw8jg
1626
tigris99
603
tim_duncan
1545
timcodes
1004
1017
tindrum42
1059
1060
tinowrx
572
Tixx
371
Tjhosan
273
Tjohn
940
941
942
943
944
Tmik
287
tmxod
771
Toccata
1241
tocirahl
988
Tom E
28
29
874
875
1223
1224
Tom_182
695
780
tommydadog
1653
Tomogchi
1567
tomtaylor
201
tonylim
43
torchjunkie
483
597
totilde
1651
toxiccoccyx
1107
ToyKeeper
339
tracerfire
1317
Trashman531
285
Trasnodel
729
Treemo
1716
trevglas
200
trevize
1165
treysoucie
789
tristanxoxo
240
1070
troisanh
91
tronx
674
TRoPHeuS
1152
tru3s1lv3r
39
tucsonmike
1512
tugboatcar
1457
Tunerman
1002
tungkon
1011
TurboLion
917
turbopscl
892
turpulator
1066
1363
tux0beliver
1689
twoleftfeet
1666
1669
tzmxxhh
21
ubermoo
1561
1562
Ulric
1198
unit311
849
unknown00101
548
uqs1000
357
Uselesshippy
1616
Vagany
647
VaKo
208
Valdorg
1202
Van
491
Vanq86
1176
vas
133
vasa_visost
668
Vattern
18
velocraig
781
vex_zg
730
Viamede
948
vinte77
414
Virisenox_
1714
1506
Volks1973
743
vulpes
539
vwpieces
881
w4rkry
1548
Wackyvegan
156
walty
280
WarHawk-AVG
420
421
warzi1975
528
wattstar
791
WaylonJennings
1452
1499
wb
1556
1564
websterjody
996
1105
1502
weklund
460
Werner
10
WestBam
1333
westcoastwonders
639
what_are_birds
1377
whitecitadel
1354
Whitty05
1475
Wieselflinkpro
125
750
1079
1482
1483
Wildcat
827
945
1690
1691
1692
1693
wildmermaid
1091
1398
Wildthing
533
willmo
605
882
WillyD
303
wilwok
1076
1258
Wineslurper
554
555
winspiration
1607
wisefire
869
wishiwereaskibum
587
wkhchin81
477
Wojto
1325
WolfA
69
Wrathbringer27
41
wunderhe
115
WuTang
1717
Wyre
1269
X0R
1430
Xandre
527
xCentrino
1314
1358
xed888
305
xelario
773
xertian
1610
1611
xjsnake
36
xray291
1192
xsosx
1474
xtrosity
723
XXX-Man
1197
xzel87
665
yasenf
1006
1232
1233
1273
1274
yclongthrow
898
899
yelve
1603
YoFlash
744
Yokiamy
1245
1383
Yourrid
1101
1102
zachary6227
1297
zak.wilson
182
Zanders
792
zara
180
zelee
22
Zeratull
703
zeremefico
1590
zeroair
452
zeroflow
1684
zifzif
1243
zipelgas
386
zortan
1596
zoysiamo
1251
ZozzV6
626
Zteduh
1530
Zulumoose
1389
×73rmin8r
1063
Found one list, now saved for prosperity,
So with 2 LEDs in parallel, the risk over time down the line would be if one of them dies or its connection fails, all the current goes through the other one and fries that one?
No, there shouldn't be a danger of either one burning out. The current is just too tiny for that to happen. The issue is that one or both just won't work (or will work intermittently). The rest of the Q8 should be perfectly functional.
Yep, a little of both. Not sure why I didn't change/fix that before the release - I thought I found this early on and knew bout it. It might have been too late, not sure. So, if you set moon mode, only way to access it is press&hold from OFF. Can't ramp down to it. Not sure where now, but I know I fixed this - might be in the next version, might be in the D4 version maybe, not sure - I know I had ramping work to go down to moon mode at some point..
It kind of got orphaned - can't ramp down to it, can't save it as the "remembered" level, but, if you start ramping from OFF, it's always there first thing,and ramping pauses on moon mode so you can catch it easier.
Muto:Hearing that your 3rd one is DOA
DOA, dead on arrival.
Sorry, should have quoted but didn’t want to single out any particular member, doesn’t really matter, just having people comparing their 3rd light received not working properly while others have none, though ordered and paid for on the same day just pours salt in the wound.
These codes could have been handed out in an orderly manner and/or limits on purchases made.
If you need the post # it is 13250, again nothing against that member.
jack-bkk:the beacons are slow blinkers not real lacation beacons liek on a nitecore
Do you mean the LED stays on too long?
I’m not sure how people use beacon modes. I’ve seen them with an on-time anywhere between 1ms and 1000ms, and an off-time of anywhere from 1s to 10s. Brightness has been anything from moon to turbo. What kind of beacon is ideal?
On my most recent beacon I took a guess and made the on-time 500ms, with brightness and off-time both configurable. But I don’t know if that’s what people consider good.
TK, I use the beacon on the H17F on the lowest output setting for night stand duty. Only on lights without trits. I love the beacon mode on it!
Replaced the resistor on the faulty switch board with 10K and the LED is working fine at 0.155 mA. I’m thinking that for some combinations of high Vf LED’s and high-side of tolerance resistors it’s just not giving enough voltage to be stable.
I ordered 3 x Q8”s within minutes of the code being released & all 3 in the first 200 orders
1 was to a delivery address in the USA & 2 to my address in the UK.
The USA one arrived yesterday & appears to be fine :+1:
My 2 however have been showing this tracking information for the last 10 days “2017-09-11 03:33
Arrived In Hongkong, Waiting To Fly Away”
I am just wondering (I guess I know the answer) if my 2 will “fly away” to me as they are or is there any chance that Thorfire can/will recall them to fix the lighted switch issue then re-ship them ?
I guess as they are in Hong Kong, according to the tracking information, that they will just continue on to me eventually as they are ?
Hearing that your 3rd one is DOA is real comforting, considering some of us would settle for a single unit that maybe had a off bright switch led.
Waited a year + for squat. On a list that means squat.
And What happened to the order list near the top of the OP??
Pffffffff, vanished. Funny how that happens.
Disgusted.
Just to be clear it was the 2nd light “I” ordered, the 3rd one was a gift to me from someone. That was covered HERE
Nor did I post to brag about receiving Q8’s… I posted because we were asked to.
I have not ordered all I am on the list for ‘yet’. I did order the three I am giving away, .
I have not ordered one for myself yet… as I knew I was being gifted one.
I will however order it before the coupon code expires.
I understand you are upset & I am sorry…. but I had no control over how anything was done or handled. Nor the rest of the things you mention either.
Hopefully things will progress quickly.
This is dedicated to applying some ’mojo’ to your UK order’s that they will “FLY AWAY” to wherever is most benificial to you Sir Ian….
Same here. I got the message “Waiting to fly away” a few days after the “shipped” message, far before any light reached its destination and the switch led issue became known. Same message up to now.
I dug further into this and realized the site “dpdgroup.hk” (where 17track and other tracking sites get the information about this carriers tracking) has moved to a “domain parking” service about a week ago. For a while 17track displayed a notice telling their tracking information is only a cached one. This notice is currently not displayed but since “dpdgroup.hk” is still not in order I’m pretty sure the tracking information is still the cached one.
I can’t track my ordered lights anywhere else - neither international nor local - and am curious if they are still on there way to my place - or lost.
If you do it that way you run a big risk of overheating the led and ruining it. If your not going to reuse it, then that technique is fine. You could also probably lay the iron tip along side the led to heat up both pads at the same time.
However - from off, with a medium click - I get this crazy dim moonlight level (I like it - it just does not seem to be in the cheat sheet or the doc on post 2.) This seems to be the only way to get into this level. I can’t ramp to it at all.I’m just wondering if this is a know feature or an easter egg?
It’s a known feature. I remember Miller or Tom E talking about it. I left my moonlight level at the stock 3 as it’s fine to me.
I just checked and I can just barely see the difference. I never really noticed before.
