Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
PLEASE do not ail Banggood, you will be “helped” by the normal customer support. a stressful experience that will only bring frustration and only solid thing that will come from it about shipping is, “please wait two more weeks and contact your local post office” you know this now, so don’t bother yourself or them :slight_smile:
I have just received my Q8.It is OK.I see that the green light blinks for 2sec,and then it is stable.I have put 4pcs of 30Qs button top.The last ones from BG,because after that,they changed policy and don’t deliver to Greece. :frowning:
Sorry to contradict. But demanding extra money for trackable and fast delivery and not fulfilling the paid service is not ok. It’s also a bad idea to use Hermes for local delivery since they currently need an extra week for delivery in my place. If I (and others) don’t tell Banggood they don’t know where to improve.
OP updated with:
teacher DOA, solution, DO NOT OPEN OR TRY TO FIX, swap with a good Q8 of Tom, so Tom can investigate and report back in depth. Tom is a true “professional guy” :wink:
Flashy Mike, in the case of the Q8 t is best to let us collect all questions so we can give it to people at Banggood who are at a level that something is actually can be done with it. Using the normal customer support is just one ticket that gets answered by a non caring person and that is it. Add a Question for Banggoog, I will put it in OP so others can see it is on the to be reported list and we will make sure it gets to management level of people who do care.
Up to you of course, spend a minute and make 1 post and know it reaches somebody who can and most likely will do something with it stress and frustration 0-1, or start a tedious customer support communication taking a lot of time and knowing the chances of it being really cared about being zero to none and chances of frustration are close to 100 :wink:
I have a 4 times experience with the Priority mail shipping option of BG,and it is very good.Also,I pay for insurance whenever it is offered.So far,there is not any item lost,although I see that a parcel with 4pcs of 30Qs is delayed and unknown from 08/30,ordered at 08/23 by Priority mail.
Almost forgot to react to this.
Alignment is hard, a reason we go for a single long tube for the GT.
That ding, auch, looks like a worker dropped it before packaging on a sharp metal table edge or something.
No other dings and scratches? Glass clean?
In this version of Narsil the moon setting does not configure the ramp floor. It basically treats moon as a separate mode from the rest of the ramp.
So, you can configure the brightness of long-press-from-off, but it does not have a way to make the ramp start at a higher or lower level.
For the record … received my Q8 day before yesterday. Switch beacon seemed to work correctly for a few cycles and is now deceased. I hope a fix can be provided with return and repair. Thanks and good luck with the remedy.
Maybe set pin high > off
Tristate pin with high value external pulldown resistor > low brightness
Set pin low > LED full brightness
(Or the other way round, if not switching the LED on the low side)
In the off state there would still be the drain through the external (high value) pulldown, but that wouldn’t be a problem for this torch.
I’d quite like to have a really bright “beacon” option, enough for a gentle nightlight.
Yes i hope the same, fixed shipping switch boards or something not much difficult to do
Auch
Will add you to the OP later
Please can you take pictures?
Since you seem to know the problem and the fix, can we BLF members enjoy the details of what is wrong with your Q8 :weary: ? By stating that your copy is DOA and then staying extremely vague, spreading panic is exactly what you seem to intend.
As requested …
I show pictures of mine too.
Thanks
And haha I see the question for pictures may sound like customer support asking for pictures when a product is not arrived :wink:
If you have the tools some pics of the switch assembly could be of great help :slight_smile:
I believe my light is “A” typical. The wizards in production should be able to dissect and resolve the issue with a sample already in hand. I for one am not prepared to open up my semi functional beauty. I will leave that surgery to the pros.
People with not properly functional switch LEDs, can you check if fully charged cells brings the back on?
Couple of Q8 pictures. Little bit bad quality, my cam is only 2MP,
2mp are enough to prove what Q8 is capable of …
Thanks RL !
I installed freshly charged 30Q’s with no change in non functional switch beacon leds.
