Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
Tom Tom
Last seen: 2 years 10 months ago
ToyKeeper wrote:
Edit: I did find a potentially-relevant trick on my old Ferrero Rocher light though. I was able to get three brightness levels (high, low, off) from an indicator LED in sleep mode by messing with the pin mode. High and off were fully within spec, but for “low” mode I had to go off the data sheet and do things the MCU didn’t really support. I suspect it might not work on a Q8 though, because it probably relied on the voltage divider resistors which newer drivers don’t have any more.
Maybe set pin high > off
Tristate pin with high value external pulldown resistor > low brightness
Set pin low > LED full brightness
(Or the other way round, if not switching the LED on the low side)
In the off state there would still be the drain through the external (high value) pulldown, but that wouldn’t be a problem for this torch.
I’d quite like to have a really bright “beacon” option, enough for a gentle nightlight.
nishayume
Last seen: 2 months 1 day ago
Yes i hope the same, fixed shipping switch boards or something not much difficult to do
The Miller
The Miller's picture
Last seen: 2 years 1 month ago
weklund wrote:
For the record … received my Q8 day before yesterday. Switch beacon seemed to work correctly for a few cycles and is now deceased. I hope a fix can be provided with return and repair. Thanks and good luck with the remedy.
Auch
Will add you to the OP later
Please can you take pictures?
djozz
djozz's picture
Last seen: 13 min 18 sec ago
teacher wrote:
The Miller….. Received & answered your PM just now when I got up for work. Then I found THIS post & the one above.
All answered in PM…. BUT… just so no one will panic, this appears to be a very easy ““fix”“ & just an isolated case of stuff happens. Big Smile
Gotta get to work….. Wink
Since you seem to know the problem and the fix, can we BLF members enjoy the details of what is wrong with your Q8 Tired ? By stating that your copy is DOA and then staying extremely vague, spreading panic is exactly what you seem to intend.
weklund
weklund's picture
Last seen: 3 hours 47 min ago
The Miller wrote:
Auch Will add you to the OP later Please can you take pictures?
As requested …
... Happy Landings ...
nishayume
I show pictures of mine too.
The Miller
Thanks
And haha I see the question for pictures may sound like customer support asking for pictures when a product is not arrived Wink
If you have the tools some pics of the switch assembly could be of great help Smile
weklund
weklund's picture
The Miller wrote:
Thanks And haha I see the question for pictures may sound like customer support asking for pictures when a product is not arrived Wink If you have the tools some pics of the switch assembly could be of great help Smile
I believe my light is “A” typical. The wizards in production should be able to dissect and resolve the issue with a sample already in hand. I for one am not prepared to open up my semi functional beauty. I will leave that surgery to the pros.
The Miller
People with not properly functional switch LEDs, can you check if fully charged cells brings the back on?
RapidLux
Last seen: 1 hour 10 min ago
Couple of Q8 pictures. Little bit bad quality, my cam is only 2MP,
giorgoskok
giorgoskok's picture
Last seen: 1 month 5 days ago
2mp are enough to prove what Q8 is capable of …
Thanks RL !
weklund
weklund's picture
I installed freshly charged 30Q’s with no change in non functional switch beacon leds.
JorisFRST
Last seen: 11 months 5 days ago
2nd Q8 has one led brighter in the switch as the other, couldn’t care less to be honest Wink
(that’s with 4 Q30 that are pretty low in charge now)
Flintrock
Last seen: 4 years 3 weeks ago
mp isn't the issue; tiny phone cameras don't have the light collection to take good pics of low light.  They get better at faking it with long exposures and software motion compensation, but nothing beats actual lens area.  You can't take good photos without enough photons.  Still, they are nice shots.
Gentetaurus
Last seen: 4 years 4 months ago
Question for Banggood
Hey The Miller,
I actually bought the light through Aliexpress from Elfeland Outdoor Lighting Store. (Along with me about eleven other people placed an order through this site.)
I just read about the malfuncioning switch-led and the temporary halting of production.
Should I extend the Processing Time on my order on Aliexpress? Mine is at three days right now. If it reaches 0 my order wil automatically be cancelled and refunded.
As the customer I can extend the processing time for as long as I want, so the manufacturer has more time to ship to me.
With how many days should I extend the processing time, I’m not interested in a refund as I’m worried that the price will go up later.
I already bought 4pcs INR18650-30Q from Elfeland and the Liitokala Lii500 charger.
Thanks in advance for answering.
PS: I’m exited for this light, it’s actually my first real high lumen flashlight. Before I have only ever bought two Maglites (gave them to my parents) and a Trunite Ti3.
Greatings,
Gentletaurus
djozz
djozz's picture
Hey djozz… I’m at work & do not have timd to get into this BS with you right now. I am being vague about nothing.
We were asked to post any problems… I did.
The Miller & TomE know what I think the problem is. If you want it posted before tonight ask them to post it.
Thank you. ……
At work you have enough time to write 5 sentences with nothing in it except putting away my IMO justly concern as BS thank you very much, while you could spend 1 sentence on the problems that you had with your flashlight thereby putting my mind at ease concerning your intentions.
pommie
Nothing to see here folks, move along...
The Miller
Teacher said a non properly solder of a wire. Lucky for us he has not fixed it so we wait for either pictures and if he cannot make the pictures we cannot examine this strange issue, so I will pay for shipping of his to Tom and one of Tom to Teacher.
Gentetaurus I would extend till 10/10 this is after the coming achinese festival so they can send it out if not send before.
nishayume
Testing now with full 30q, the led no work. In my case no changes. Wink
The Miller
thanks!
joechina
leroycp wrote:
Great job on the printed cheat sheet! Best to all.
Thank you.
sparkyDK
According to flaky tracking # and with the grace of incompetent Danish customs and postal service ( in this case both handled by Danish postal )
Then i might take possession of my Q8 tomorrow Big Smile
So i have been busy with my soldering iron on cells and a BEC for my RC hobby that had to get a little attention too.
Funny thing, while solder blobbing the LG cells it was a fair bit slower for my soldering iron to get some heat into the battery for a good solder as opposed to the Sony cells.
For sure my soldering iron was at full tilt when i soldered the LG cells first, so i can only assume there may be a difference in the thickness of that end cap i am soldering on.
Anyways things are good, and i look forward to lighting up Randers where i live, and i have the police station firmly in my sights, cuz they so often flash other people so i think its only fair to return the favor on the 2-3 guys that’s there on the station at night.
whitecitadel
Last seen: 19 hours 19 min ago
So many posts.
Everyone who is not happy – you realise you can just go to a local store and get a Nitecore TMxx for $$$ right if you don’t want to wait? Of course your going to pay 6x as much and have 1/6th of the fun Big Smile
I can’t believe BLF members don’t have another light to use while they wait? Facepalm Wink
(most who are not in therapy probably ordered another 3 lights since page 439)
Miller – doing a great job there, I hope the referral thing is covering the bar bill for you and the rest of the team.
Its a $40 light from China that’s unique – it’s worth the wait – stopping to check if the switch assembly needs correction was the right idea IMHO – else BangGood is just going to get hit with PayPal claims then the whole thing turns bad for everyone. +1 for Thorfire for maintaining their reputation – they only have to look at Astrolux and the S42 to see how important this is in the long term.
I just hope Santa brings it – and any sooner is bonus Thumbs Up
The Miller
sparkyDK, that is some fancy charger you got there, wowsers
thanks for the kind words whitecitadel Smile
Agro
Agro's picture
Last seen: 1 min 34 sec ago
Phew, finally managed to get through the recent updates.
It’s said that what got shipped is different from the last prototypes. I hope we’ll be able to avoid such issues in the future lights.
I fully support the decision to stop production I’ll gladly wait to get a better light, even though this feature doesn’t matter much to me.
The Team, thank you for your work. Thumbs Up
Joey Adams
Last seen: 1 month 6 days ago
Gentetaurus, are you saying that elfeland actually has some q8’s in stock. Or is it the same pay and wait and wait….zzzzzzz
Bc412
Last seen: 1 year 1 week ago
So I took my tracking # from bg’s website and plugged it directly into FedEx website and got a result.
Track17 did not work.
Mine was delivered to California on the 15th and is expected to get to me on the 27th. So in my case the delay doesn’t seem to be BG but rather with fedex.
Go figure. 8 days from. China to CA and 12 days from CA to NY. I’m expecting that it will arrive before the 27th as it is in Minnesota now.
vwpieces
vwpieces's picture
Last seen: 4 months 1 week ago
and from Local FedEx to USPS to your door will be 3 days.
BrianK
It doesn’t really matter greatly when I receive mine either Bc. When I paid for mine I understood that I was buying them as a pre-order.
FedEx is definitely responsible for the slow delivery to the east coast. My lights were in LA for 2-3 days before even being picked up by FedEx even after having had the labels put on them. Now they’re traveling cross country and will take 10 days to do so. That’s extremely slow delivery service. But I assume that’s what was paid for by the shipper. I took free shipping so I’m really not complaining, it’s just an observation. I didn’t know that FedEx had bicycle express delivery.
I’d like to thank the design team for doing a great job on the lights and everyone else connected with them. The Miller you have the patience of Job. What a shame that Thorfire changed the design from the prototype to the finished product and minor problems have resulted from that. One really DOA light out of hundreds in users hands is pretty good. But even so, including the switch LED problems the failure rate is still only near 1%. Of course we’ll know more after all of the 500 lights get into user hands. But I would expect it to be not higher than 2%. Higher than anyone would like, but still not terrible.
twodollarbill
Last seen: 15 min 57 sec ago
For what it’s worth, I too ordered the light through Aliexpress from the Elfeland Outdoor Lighting Store.
I placed my order on Sept. 15th, and late yesterday got a notice that my light has shipped. Tracking is showing that it has departed the sorting center.
