We touched on MF-01 battery carrier issue and customers' feedback, HaikeLite production, and some other upcoming group buys today. Not in the hurry to roll out MF-02 yet.
I may have missed discussions about those upcoming groupbuys and HaikeLite production.
I was under impression that MF-02 GB was set to happen next month.
Based on Silicoon pics, i suspect MF-01 XP-G3 tint will be fairly close to S41S version. You are right, DQG is more yellow than green, i remembered wrongly.
interested XPG3
It’s probably already connected , seems to be the same trace… So , it seems to be alright.
Emisar D4 nichia // MF-01 nichia
My MF01 219C is clearly more warm than the S42 XPG3 :
I love so much the MTG2 it is really good for daily use the tint is perfect. MF01 is more warm than MT03 and others from left :
i can see a purple tint on MF01 spill….but my eye doesnt see it.
my EOS7D does
Indicate your LED choice (XPG3 / 219C) in you reply if possible.
Edit your previous post instead of creating a new request.
Notification List
Updated on Sep 20, 2017
- andrewmac
- danggitbai
- Kingjohn
- cheesecheeks
- Sergeantrecrut
- cyropro
- heatwaves
- Lou_Menn
- Robsva96 - XPG3
- Dralf
- Nicolicous
- Phantom1
- ramptosd
- laythaws
- BeardedRaleigh - 219C
- Sukoi
- Wieselflinkpro - XPG3
- gastonpatagonico -219C
- sammubara
- qandeel - 219C
- Ilmatic - 219C
- tantrik77 - 219C
- watamu - 219C
- rafalklis - 219C
- CJ Avlis - 219C
- jamaya - 219C
- Mr.Beam - 219C
- Mr.Beam - 219C
- maildroid - XPG3
- Wolpi - XPG3
- andrewmac XPG3
- southland - 219C
- xxx - XPG3
- mrheosuper - XPG3
- atbglenn
- Nicolicous - XPG3
- FG1 - 219C
- ersecu - XPG3
- xdouang - XPG3
- thommy - XPG3
- Itsme
- sammubara
- Lou_Menn
I’d like to change my selection to XPG3 please. Sorry for the inconvenience.
I actually did remove the screws to the brass ring and board, just to have a look. The wires to the board seemed secure. I could not tell if the wires were damaged at the center hole, without desoldering them from the board. I have almost no experience with soldering, especially on circuit boards, so I did not attempt anything and put everything back together.
Thank you for the update, Freeme! I’ll be looking for their response.
17track:
2017-09-12 15:22 Item is announced /bppost received the information
then it vanished as “not found”, after few days I got this:
2017-09-12 10:04 Item is announced /bppost received the information
now it vanished again…
PackageRadar:
September 18 14:03
Electronic shipment information received
Belgium Post
September 18 10:04
Belgium Post
Same here. Looks like plane flew over Bermuda triangle…
How does this work? You make a deal with banggood and we order it?
Just for info that TA Narsil board used in TLF was designed from me lately
that MF01 design is on sale in the 4. batch just I wait for 3 orders, then order 3 boards, as the PCB is not cheap ordered from Oshpark
Are most people on here taking off the plastic border on the positive end of the battery carrier?
And someone mentioned that LG HG2 flat tops work on in the carrier right?
I would like one with NarsilM for an MF01. edit: misread; probably wrong thread. “driver by Lexel”
LG HG2 flat tops worked without removing those plastic rings but those HG2 are not absolute flat tops like my Samsung 25R which did not work. 25R worked after I removed the rings. HG2 has slightly elevated button on their flat tops and they work well in my Meteor too. My button top HG2 and button top Samsung 30Q worked also without removing the rings.
Forgot to mention I want the XPG3
I don’t know but I removed them in my batteries carrier. There is a raised ring on the outside of the plastic disc that catched the wrapper of one of my brand new sony VTC and I hated this. Slightly damaged wrapper but no big deal though.
