ENEDED
LG HG2 flat tops worked without removing those plastic rings but those HG2 are not absolute flat tops like my Samsung 25R which did not work. 25R worked after I removed the rings. HG2 has slightly elevated button on their flat tops and they work well in my Meteor too. My button top HG2 and button top Samsung 30Q worked also without removing the rings.
Forgot to mention I want the XPG3
I don’t know but I removed them in my batteries carrier. There is a raised ring on the outside of the plastic disc that catched the wrapper of one of my brand new sony VTC and I hated this. Slightly damaged wrapper but no big deal though.
freeme, I am also interested in another XP-G3 that I want to gift to someone.
Thanks.
I want XP-G 3 plz
Is it purple or “rose”
as long as its not green!
I would like to clarify I am interested in XP-G3
Thanks!
Interested in the XP-G3
Nitecore TM26 holster surprises well.
Nitecore TM11 holster is slightly tight.
It is still copper if it is this brand :wink:
My nichia just arrived. Very nice tint and beam.
It’s pretty bright. I’m yet to test at night.
My first thoughts:
The box is really nice make it feel premium when opening.
The light feels heavy and but very solid built. Dedinerly heavier than a imalent Dt70 or niwalker mm15mb.
The battery carrier feels so well built and sturdy, heavy too.
Really liking it. Might even have to order another later on.
Now I’ll have to test a bit more at night and see if it all is working well. But we’ll with it.
Definitely feels like twice the price we paid.
Hopefully astrolux can keep up this quality from now on. Haven’t had much luck on the S41ss and S42.
Left / right 219C middle XP-G3
I have S42(XP-G3 or 219C).
S41(XP-G3 or 219B) imalent Dt70 was previously owned.
Here it seems that the reputation of S41 S42 is bad, why?
That picture shows the NW version of the dqg. I’ve got the CW version and it has a hint of yellow in it. So I’m trying to compare CW DQG 7X with CW MF-01. If anyone has this combination please let me know how they compare.
Thanks for the tip!
(Managed to find someone on eBay who sells the holsters separate and ordered one.)
The initial batch of S41 were, due to bad design, prone to shorts at the mounting screws for the LED board. Shorting a Li-Ion is no fun… Later batches have been quite OK.
The initial batch of S42 had a battery tube that was too short for basically all 18350:s on the market. The S42 is still plagued by a couple of bad design choices: like a horrible UI and a driver with cheap components that makes the light underperform badly.
And don’t forget the horrible beam profile and tint on the s42
Another option for keeping the light on your hip….7.99
https://www.amazon.com/COSCOD-Portable-Holster-Plastic-Release/dp/B01CCHCED4/ref=pd_lpo_vtph_421_bs_lp_t_1?_encoding=UTF8&psc=1&refRID=87Y9A41PXZG9YTHCCEPW&dpID=519njRmurDL&preST=SY300_QL70&dpSrc=detail
Just got POUCH #3 from your link in the mail today. Fits the Q8 perfectly, the head of the MF01 is a bit of a tighter squeeze, but still gets through. I think the pouch is a perfect size for both lights.
Just to follow up, I removed all 4 plastic rings off the + ends and re-soldered the brass button tops. All is good now, discharge is even on the 4 30Qs. My ceiling bounce test also registered a 15% increase in output.
Thank you :+1: I understood it well.
S41 is a countermeasure lot as though operation itself is no problem,XP-G 219B is both released with fever.
S42 I got battery damage :confounded: I got a countermeasure item from BG.
The UI is for sure.
