ENEDED
I would like to clarify I am interested in XP-G3
Thanks!
Interested in the XP-G3
Nitecore TM26 holster surprises well.
Nitecore TM11 holster is slightly tight.
It is still copper if it is this brand :wink:
My nichia just arrived. Very nice tint and beam.
It’s pretty bright. I’m yet to test at night.
My first thoughts:
The box is really nice make it feel premium when opening.
The light feels heavy and but very solid built. Dedinerly heavier than a imalent Dt70 or niwalker mm15mb.
The battery carrier feels so well built and sturdy, heavy too.
Really liking it. Might even have to order another later on.
Now I’ll have to test a bit more at night and see if it all is working well. But we’ll with it.
Definitely feels like twice the price we paid.
Hopefully astrolux can keep up this quality from now on. Haven’t had much luck on the S41ss and S42.
Left / right 219C middle XP-G3
I have S42(XP-G3 or 219C).
S41(XP-G3 or 219B) imalent Dt70 was previously owned.
Here it seems that the reputation of S41 S42 is bad, why?
That picture shows the NW version of the dqg. I’ve got the CW version and it has a hint of yellow in it. So I’m trying to compare CW DQG 7X with CW MF-01. If anyone has this combination please let me know how they compare.
Thanks for the tip!
(Managed to find someone on eBay who sells the holsters separate and ordered one.)
The initial batch of S41 were, due to bad design, prone to shorts at the mounting screws for the LED board. Shorting a Li-Ion is no fun… Later batches have been quite OK.
The initial batch of S42 had a battery tube that was too short for basically all 18350:s on the market. The S42 is still plagued by a couple of bad design choices: like a horrible UI and a driver with cheap components that makes the light underperform badly.
And don’t forget the horrible beam profile and tint on the s42
Another option for keeping the light on your hip….7.99
https://www.amazon.com/COSCOD-Portable-Holster-Plastic-Release/dp/B01CCHCED4/ref=pd_lpo_vtph_421_bs_lp_t_1?_encoding=UTF8&psc=1&refRID=87Y9A41PXZG9YTHCCEPW&dpID=519njRmurDL&preST=SY300_QL70&dpSrc=detail
Just got POUCH #3 from your link in the mail today. Fits the Q8 perfectly, the head of the MF01 is a bit of a tighter squeeze, but still gets through. I think the pouch is a perfect size for both lights.
Just to follow up, I removed all 4 plastic rings off the + ends and re-soldered the brass button tops. All is good now, discharge is even on the 4 30Qs. My ceiling bounce test also registered a 15% increase in output.
Thank you :+1: I understood it well.
S41 is a countermeasure lot as though operation itself is no problem,XP-G 219B is both released with fever.
S42 I got battery damage :confounded: I got a countermeasure item from BG.
The UI is for sure.
I do not understand this well :frowning:
S42 (219C) likes low fever.
I took some thermal images of this light. I don’t know how to post photos here but I posted on my Thermal gallery on Instagram.
I ran the light for 2 mins to see how hot it gets. Its about 56 Degrees C before it steps down. But the handle is never very hot, only the head of the light gets hot.
There are a few photos, so flick to the left to see the other shots.
https://www.instagram.com/p/BZVAUEildGZ/?taken-by=thermalshots
The video
why are there a new interest list? sorry i haven’t been following the thread.
If instagram gives you Web page links to the images, you can click the little orangish sunset button along the top of where you type. A window pops up. Paste the image address in there. Maybe choose 95% size, then OK. It will add the photo to your message.
As far as I can tell, this 2nd wave is for folks like me that got a code for the first round but by the time I got it and tried to use it, the first batch of lights was sold out and the light was on back order. Just waiting for the 2nd wave code (via PM) so I can buy one this time around
They haven’t really pushing this light to the limit yet.
It should handle 65 degrees ok
My convoy L6 get up to 70 degrees without and issues and it does get warm :slight_smile: my hand have thick skin :smiley:
