Pulsar, that’s right! Why spend a lot of money now for a so called Premium bulb when in a year or two higher CRI bulbs will be cheap and common.
With hitech, my motto is “Buy cheap and upgrade often”
It looks like my Dollar Tree got their act together and restocked and tidied up the shelves is house wares. Before and after pics.
And they restocked the 3 packs of FEIT’s
But the most impressive thing was realizing that $1 LED bulbs are so ho-hum these days that my DT now stocks 4 kinds.
Look closely, on the bottom shelf, left to right. Green light single pack, FEIT 3 pack, Sunbeam single pack and LED-Life double pack!
Take your pick
The Dollar Tree near me FINALLY has the $1 Sunbeam led bulbs. It would be nice to see more than one option to choose from butit’s nice to see them offering an alternative to incandescents.
I was back in my Dollar Tree tonight and found that they now carry 7 different choices of LED bulbs
Remember now, EVERYTHING in the store sells for $1
Left to Right in the picture
2 pack of LED Life 800 Lumen bulbs
1 pack of GreenLite 800 Lumen
1 pack GE 280 Lumen “Designer” bulb
3 pack of FEIT 800 Lumen bulbs
1 pack of Sylvania 250 Lumen clear dome bulb
1 pack of Sunbeam 1600 Lumen bulb
1 pack of Sunbeam 800 Lumen bulb
In the forground, resting against my knee is an empty tray of a 650 Lumen BR30 flood light.
What the shelf looked like while I was there.
It looks like they are getting to restock the shelves, here are cases of the FEIT 3 packs!
dchomak, I hate you. Since this thread and others about DollarTree, General, etc have started, I’ve yet to find the first LED bulb OF ANY TYPE in my local store…EVER !!
Guess it’s just an up-North thing.
Nawwww….Don’t really hate you…lol just my local store…
I found the sunbeam 60w equivalent a while back and bought 7 then went back for 7 more. Still haven’t seen any of the others.
@ dchomak
My Dollar Tree put in those same linoleum tiles a month or two ago.
Like Streamer, I haven’t seen any LED bulbs at my local store.
Streamer you being from Texas, maybe nothing can be done at this time.
BUT, xCentrino you’re in California!
Maybe it’s time to get proactive. Park yourself outside this address and next time there’s a shipment………………………
Well, I’ll leave that up to your imagination
I’m jealous of some of y’alls DT bulb selection
Here in Jamestown NY I finally saw the 1-pack of sunbeam 9W/800lm/3000k (60W equiv.) green packaged bulb (non-dimmable, can be used in an enclosed fixture) today - so I picked up 1 to try out. I’m surprised at how lightweight the bulb is, at least compared to my 2-3 year old LED bulbs (also 9W) made by “Brighton Professional” (sold by Staples at the time) and some 1 yr old 9W bulbs that I received for free from the utility company branded “Simply conserve” - made (or imported?) by AM Conservation group out of Charleston, SC. Both bulbs are significantly heaver. Just threw the “simply conserve” bulb on the scale and it weighs 114g, and the sunbeam bulb (dollar tree) only weighs 32g!!! It feels like a toy. It makes me wonder about the heatsinking and components inside. It claims to be UL listed and RoHS compliant.
I’ll probably put it in a high use fixture and see how it does over the next couple years. I guess time will tell. I’ll be on the lookout for 2 and 3 packs of higher quality LED bulbs, and probably even hit a couple DT stores when I travel. I imagine many of the 2 and 3 packs are a mix of subsidized bulbs by local power companies and closeouts/leftovers from big box stores, so highly regional.
I still have not had or heard of the 3pk Feit bulbs failing. I have them almost everywhere now and ditched the old unreliable Cree.
I only have one of the Sunbeam 65W equivalent floods and am tempted to use outside as a test. See how long it survives if its acceptable brightness.
My last and only old style Cree bulb failed yesterday. It was the $20+ 3-Way 30-60-100W with the large Fins. Checked online at the orange store and these darn things are still $20…
Got it apart without breaking glass but broke 3 plastic retaining clips. Found the boost driver was still good and the LED array failed. Had another single mode 18W in working condition and took that one apart the same way. Tested it with the 3 way driver and Joy, Joy. Back in business. Glued it back together and good to go.
This is the 3rd failure of this Lamp. First 2 times it was still stocked and had replacements done “creatively”. I guess this is the Last time it will get revived or replaced.
It is a stained glass pedestal, I like the lamp and have matching table lamp. want to keep it.
Will start looking into other options, maybe a dimmer control in this light? Its a single socket, 3 way. Plugs into a switched wall socket by the entry door but the switch on the light is used more often for on/off changing brightness. Suggestions? Is there a variable socket out there? No more $20 bulbs…
The online prices for the 3-way bulbs have dropped to half what you paid but they are still going to be way more expensive since it is 3 bulbs in one. A single bulb just requires a driver and the LEDs so is cheap to make but a 3 way bulb has 3 separate sets of LEDs and the wiring to go with it.
I’m surprised a California dweller hasn’t discovered that the 99-cent-only store (a large southwestern chain of “dollar” stores) is now stocking LED bulbs. I’m not a fan of the A19 bulb with the E27 base because almost all of them are designed with a circular plate with the LEDs mounted on the plate. This one looks like it uses an IC driver in the center of the plate.
Space limits the number of LEDs so most of these bulbs were rated 3W or 5W which didn’t give off enough light for my uses. I bought a couple of them several years ago for $2 each but finally gave them away and replaced them with “corn bulbs” bought online from China. There is also a great difference in the type of LED. They go from SMD 2835, 5050, 5630, and 5730 which refer to the dimensions of the chip. It also goes from dimmest to brightest and least efficient to most efficient in the same order. A corn bulb is shaped like an ear of corn with the LEDs around a cylinder and at the top so you get about 270 degree coverage and can use a clear envelope for the bulb for maximum useful light. This 10W bulb is $2.25 with free shipping. Zero failures for these lights in 3 years.
Newbie here,
Thanks for all the info on Dollar Tree. I went to 6 stores in my area and found the Globe 2 pack of 800 Lum. 9.5w at 4 of them, the Sunbeam 800Lum. 9W at all 6 and a 800Lum. 8W that has not been mentioned her yet at 4 of them. It is distributed by Greenbrier International . All 3 are rated at 3000K. So far I only have the Phillips “lollipop” type bulbs to compare as I found them on sale at HD for under 2 bucks each a year ago.
Quick stats are
Phillips 800Lum 10.5W 2700K. 984g. dimmable not for enclosed fixtures no direct exposure to water/ damp locations ok. Got them for my ceiling fan as it has a built in dimmer and these were the cheapest dimmable I could find.
Globe LED for life 800Lum 9.5W 3000K 746g. non dim. ok for enclosed fixtures ans damp locations. ( this bulb has a much taller profile than a standard A19 and could be a problem in tight fixtures )
Sunbeam 800Lum 9W 3000K. 506g. non dim, ok for enclosed fixtures and damp locations. ( lightest bulb by far. not likely to have much heat sink)
Greenbrier Int. 800Lum 8W 3000K 658g. non dim. ok for enclosed fixtures and damp locations ( lowest power use. The bulb itself is marked with a fs inside a G logo and the word BRICHIPS next to it, JX-QP08-30)
All carry the UL mark. The Globe is the whitest by far and is at least 3000K, IMO. The other 3 are more yellow and closer to the 2700K of the Phillips, IMO. They all seem to put out equal light.
Cost wise the Greenbrier at 1.00 will still come in cheaper than the Globe at 50 cents if both last at least 3 years of average use due to lower power usage of the Greenbrier.( .96 per year vs 1.14 per year)
The Greenbrier is packaged almost identical to the Sunbeam in a pasteboard box with a pasteboard socket holder in the bottom. I will try to upload a photo once I figure out what way is required on this site.
I still have over 10 Dollar Tree and Family Dollar stores in my area to try ( both are now owned by same company and are stocked the same) and am hoping to find the FEIT 800LUM. 3 packs and the Sunbeam 1600LUM. bulbs in my area.
Anyone know of a good source for 60W and 100W equivalent dimmable bulbs? I have one ceiling fan that uses one large bulb instead of several smaller wattage ones and a couple with exposed bulbs where the “lollipop” type look odd.
Now on to my search for 4 foot fluorescent tube replacements. I need to swap out several fixtures and the lowest price for a complete LED fixture is 28.00 at SAMS CLUB. (4500 LUM) so far I have found a couple od tube replacements in the 2500 to 2700 LUM. range that will run about 20 bucks per fixture but the fixture needs to be modified. 4500LUM quick and easy or 5400Lum with some rewiring. Any thoughts? (maybe I should start a new thread for this.)
I would swap out the 3 way socket for a 1 way standard type and put a dimmer instead of the wall switch. A wall dimmer is about the same cost as a new 3 way LED and then all you need is a 100W equiv. dimmable bulb for the lamp. For a few dollars more, they have remote control dimmer switches so you could change brightness from the lamp location.
something like this might do the trick.
VWPIECES, here is a replacement lamp socket that has a built in LED compatible dimmer. It replaces the 3 way socket of your lamp and is about the same size. reported to work with most dimmable LEDs that work with electronic dimmers. It is not a simple rheostat type that only works with incandescent bulbs. It is a name brand Leviton product and rated at 150Watts max so you could even put a 150 watt equivalent bulb in it since that would only draw about 20 watts. Its 17.00 on Amazon but likely can be found for less at other sites.
https://www.amazon.com/Leviton-805-6151-Dimmer-Socket/dp/B00004YULD
Thanks wastric,
I have seen those but too much…
Ended up with a Philips 3 way 50/100/150 in WW. Much nicer than the Older Cree I had.
I should pay better attention when I am weighing something. My digital scale was set for grains, not grams when I did my bulb weigh in. ( gn should have been my 1st clue…)
the correct weights in grams is as follows:
Sunbeam 800 is 32.8g
Greenbriar 800 is 42.5g
Globe 800 is 48.4g
Phillips 800 is 63.7g
I have all 4 types now in high use locations to evaluate them and will post any failures or other info.
My local “99cent only store” had 800 lumen and 1000 lumen flood lights today. The package said CR>90. Price was $.9999 (so they always get the extra penny) per bulb. Of course the package also said “Not for sale outside of California. Subsidized by California utilities.” It’s not the first time I saw this. Another dollar store in town had humongous CFLs on sale for a dollar and with the same type of notice that they were subsidized by a CA utility. The guy behind me had 6 of them in his cart. He said the 1000 lumen floods would not fit in a regular size outdoor flood holder. They also have a lot of the regular LED bulbs for a dollar each.
If you really like LED bulbs, give a try to the corn bulbs or better yet, the chip-on-board bulbs fashioned like CFLs. I think they did the COBs shaped like CFLs because US consumers get freaked out by anything radically different from the familiar round bulb or the CFL shape.
Here are a couple of images of the 800 Lumen 8 watt bulb we have at most of our Dollar Trees. I listed its specs above: ( I can’t get the photos to link for some reason so I just put the url )
Question about how to insert an image. on my post above, I loaded the image up to imgur.com and then tried to insert the url as a image but it did not display as a photo. Any ideas on what I am doing wrong?
Also an update on the 800 lumen bulbs I bought at Dollar Tree. one of the Globe LED for life bulbs has started flickering randomly a couple of minutes after its turned on. The other 2 brands seem to be holding up ok so far.
Still searching for the 1600 lumen ones that a couple of you have found. For now I think I will get a few more of the 8 watt Greenbrier bulb as its the lowest power one I have found and gives of just as much light as the 9 or 9.5 watt ones.
I have been to 12 Dollar Tree stores so far and will be hitting another 6 to 8 this weekend on a trip down south. I hope to find the Sunbeam 100 or 75 watt equivalent ones or something like those, Also hoping to find some dimmable ones but not holding my breath. I was told by an employee that they just started getting the 800 lumen Sunbeam bulbs a couple weeks ago. Has anyone else seen bulbs larger than 800 lumens lately at Dollar Tree?
