Yes Astrolux tend to use copper for the head of their flashlights but a MF-01 with a copper head will be much heavier and this will also increase the price significantly. Not worth the price if they don’t push the high and turbo modes to higher current (with higher gauge wires to the LED banks).
Hmm he did the current testing without the battery carrier actually. The driver spring would definitely yield the largest gain. I wish I could test differences, but I don’t have the equipment.
No, he used the carrier. He just modded it so that all the power went through an additional loop of wire so he could use his Uni-T UT210E amp meter. It’s the same model lots of blf’ers use, including myself. It’s only about $25 to $30. Having one really helps you to understand current flow and how it relates to output. If you like doing mods and stuff, you should consider getting one. It’s also a DMM in case you don’t already have one.
Thanks for sharing Bruno28. One question, how come it doesn’t capture its SS bezel temperature?
[quote]
You’re welcome.
Metal surfaces that are shiny can’t get the proper thermal reading. Infra red is reflected from other objects around and then the camera captures this.
The same happens with glass and mirrors.
As some have pointed out, the best way to get accurate reading on shinny surfaces is to use a black electrical tape, so the heat from the source will heat the tape and be able to read the temperature correctly.
The red hot areas on the bezel is actually a reflection of myself.
Maybe they could extend the height of the head by adding one more fin. That should add about 6mm which could be added to the shelf thickness. The extra mass would help reduce led temps, at least for a while.
not sure what you are getting at, is there something wrong with sharing my own finding here?
MT03 is known not making true 9K lumens, i am just giving a reference here as to how bright the light is. I think the MF01 Nichia is not making 11K lumens from the figure i got. I does look brighter to the eyes though.
btw. Did the test again now i only get only 15% (650 vs 750 Lux) with slightly used batteries (4.09v) Currently charging the battery to see if my initial reading was an error or the full battery did gave higher result
i think the MF01 nichia is making more than 7000 Lumens but i have no way of measuring the exact figure myself it looks brighter than my MT03 and the Lux support this.
