Thorfire will clean out the next 2000 yes, and most are clean, butnthere is a small chance it is there so when I read output below 5K lumens it reminds me of Tom who did a simple cleanup and got one back on par
It is conveyed and taken care of
I’m confused lol. Will cleaning the screws out actually help? The two screws near where the positive contact ring for the batteries is?
depends, the 4 screw holes at the TAIL CAP can benefit from cleaning in SOME cases
The driver holding screws (at the + side of the cells have nothing to do with it
Just wanted to update you. Unscrewed my PCB. One of the four contact pads on the battery tube had what looked to be thermal compound(or sandblast powder) adhered quite well to it. I had to scrape it off. Was easier when wet so it may have been sandblast powder. Was covering a good portion of the contact area, but my batteries were all at 4.05v so they seemed to have discharged evenly. Screws all had to be cleaned as well. Threads were dirty too but I wasn’t sure how to clean them. I tried rotating a piece of foam earplug material in them. Seems like it may be slightly brighter now but I can’t say for sure because I have no measurement equipment.
Love your work maukka. Thanks for taking the time to post it up.
No sandblast, but the screws weren’t tightened very well and there was some solder blobs on one of the pads contacting the body. Remeasured after fixing that and cleaning all the contacts with IPA.
Solder blobbed some VTC6’s and surprisingly they also performed worse than my 25R’s. Did the measurements two times to verify. This seems to indicate some sort of battery contact resistance problem, since naturally the VTC6 should perform better.
Pretty much no difference with the 25Rs (2% increase), but the 30Qs did a bit better this time with 4% improvement.
Also remember that my numbers are about 5-15% lower than most people’s and I would definitely consider this falling within specs.
Thanks for the update, strange indeed
Also checked the IR of the batteries at 5A, almost fully charged.
25R 23mohm
30Q 50mohm
VTC6 35mohm
So makes sense.
Why did a think the Q8 was a 6000 lumen light? Must have misread
Yep…my bad
With good cells and clean tail screw holes it is higher.
I do not recommend it (I already know a case of putting one battery in reversed and the springs nicely acting as a fuse ) , but bypassing the tailsprings will give at least a 500 lumen bump.
I received my Q8s today
I can definately say, that in the tube screw holes its not residue from sand blasting
it is white glue securing the screws
even worse on my sample this glue was not even in the holes it was on 2 screw mounts also on the surface between the PCB and body
furthermore there was some black dirt on the drivers brass ring which I cleaned off with steel whool
On mine the tail screw holes were perfectly clean, no glue.
This was the only thing I found to be amiss:
Oh well, guess Thorfire wont be the next group buy manufacturer.
I’m not in any other BLF-flashlight team other than the Q8, but despite that it was quite an adventure with Thorfire, especially the communication, they have succesfully finished the Q8 project. They have more or less followed our design demands, did the part of the design that we as Q8-team were not capable of doing in a satisfactory way, stayed within the initial cost goal, and finally produced a light of which the specs are quite a bit better than we hoped for. To mention the most saillant detail: we never thought beforehand that Thorfire was prepared to make the massive copper DTP-board (that is central to the performance) we asked for.
So I believe that this BLF Q8 project in coopereation with Thorfire is as succesful or better than any previous BLF custom light project. A new project with Thorfire will certainly be a challenge again as far as communication goes, and they will certainly again struggle to get the details on the level of premium brand lights, but I’m confident that a next project with Thorfire could be succesful, and expect that if the Q8 project turns out to be profitable for them, the communication thing will only become better.
I agree, I’m overall very content with the result, especially at this low price. This is the first batch and I’m confident they will improve the minor flaws we found.
This is still the BudgetLightForum
The BLF Q8 is by far the most quality value SRK sized light with exellent performance and a low price
there are always minor issues with lights produced in China,
even big brands like
- Nitecore had problems with their drivers break physically the piggyback bord breaking off, have cheap non DTP stars
- Klarus with the disatster from dying drivers in the XT11GTs
- you cant fix probems, because everything is glued
Most of us are expirience modders which are perfectionists that see small things that can be done better,
but in general this light works great even with those minor issues
and its easy to fix/clean the light center the reflector ect, nothing is glued or press fit
The light works out of the box and non specialists even do not recognize the minor QC issues the ligh has
If the side switch LEDs die its easy to replace them, many will insert another colored LEDs anyways
My first sample worked out the box, meets the specs, feels very well made and was cheap. What more could a BLFer want? As a hobbyist, the little QC things aren’t very serious and can be fixed easily, except for the switch light problem, but mine works fine.
