Emisar D1
210 posts / 0 new
Agro
Agro's picture
Last seen: 2 min 58 sec ago
Emisar D1
So far we’ve been talking about this light in the D4 review thread.
Let’s make a separate topic.
Agro
Agro's picture
Who’s going to be the first to swap a dedomed SST40 in there? Should do 60+ kcd….
JIGHEADWORM
Last seen: 5 months 13 hours ago
Here is beamshot of D1 compared with an d4 xpl-hi and a L2 with xhp35.
JIGHEADWORM
Is that better? L2 top left.D4 top right,D1 bottom left.It’s my first time trying images on here.
ven
ven's picture
Nice pics JHW Thumbs Up
Will throw a couple in as well
D4 xp-g2 4000k
D1 xpl HI 5000k
Not had change to get any decent pics, need to get out rain/time permitting where i can stretch its legs(so to speak)
ven
ven's picture
If i could i would!! Sounds a beast, however i do like the 5000k HI as is, so i would need another Big Smile
khas
Last seen: 1 month 1 week ago
Sorry no beamshots yet, maybe I will make some later tonight if I can find time
ven
ven's picture
Cool
Few random pics
ven
ven's picture
Predator V’s D1…………….D1 wins!
Flying Luminosity
Flying Luminosity's picture
Last seen: 2 years 3 weeks ago
Thanks Agro, I’ve been waiting for this thread! Just ordered the green one with XPL Hi NW yesterday, so I’ve got something to play with until the D4 is back in stock.
BeardedRaleigh
BeardedRaleigh's picture
Last seen: 3 days 9 hours ago
Ok I’ll bite, kinda bummed i didnt get to start the D1 thread Sad
Some random shots from tonight with iPhone 7. As we all know, its brighter in person.
D1
UT02
D1
UT02
D1
UT02
Slow is smooth, smooth is fast.
BeardedRaleigh
and some beauty shots Wink
ven
ven's picture
Great pics Cool
Old Mate
Last seen: 2 years 1 day ago
Can anyone with the D1 and D4 to compare-
Which has the lowest moonlight level ??
Old Mate
treoneo
Will this need a high drain battery?
ven
ven's picture
Hard for me to compare, the D1 obviously has a tight hot spot still, lot more intense than the D4’s large hot spot. Both have different beam types.
ven
ven's picture
Yes, the performance will be better when the voltage gets lower through use. You will get less sag for example if at 3.6v and hit the 100% outptut.
I use 30Q in my D1. Ideally any cell of 10a and over would work well . Not tested the amps, i might have read around 6a but not sure.
rubatone
rubatone's picture
Last seen: 2 years 5 months ago
Finally a thread for the D1!
Whats the throw and lumens on the D1?
I love the D4 but I use it mostly as an extra light, srt-9 as primary. Thinking about getting the D1.
JIGHEADWORM
I got 6.03 amps on a 4.18v vtc6.
ven
ven's picture
Thanks for the info Smile
Big throw, little throw
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
Just ordered one from Mountain Electronics in green along with the 18350 short tube. They should have them in by the end of the month.
Boycott Nike
treoneo
The list of recommended batteries seems a direct copy and paste from the D4 which has a much higher output (almost three times) which is why I asked.
hIKARInoob
hIKARInoob's picture
Last seen: 19 hours 12 min ago
In terms of power this is true. The reason you have the same recommended batteries is because the D1 and D4 are both FET driven. This means that you get maximum output with batteries that have least voltage sag, so batteries that are (most) high drain. So with both the D1 and D4 you have maximum output with cells like the VTC6 and 30Q, and you have less output with something like a NCR18650GA (but more runtime on lower output due to higher capacity).
treoneo
Ohhh thanks for the explanation.
So will getting a battery that goes above 10A really matter for this particular light? Doesn’t this light top out around 6A?
hIKARInoob
Absolutely. Check out HKJ’s comparator here: http://lygte-info.dk/review/batteries2012/Common18650comparator.php
Punch in Sony VTC6 and Sanyo NCR18650GA. Then mark 5 or 7 amps. You then see that the VTC6 has a higher voltage (less sag) than with the GA. The led is sensitive to minor differences in voltage, so with the VTC6 you get a higher output.
So this means that even if you have less than 10A current, there is still a difference in output depending on cell.
treoneo
So I should just get the efest 18650 (max discharge of 35A) which would provide highest output and be done with it!
Approximately how much less runtime than the Sanyo 3500mah battery?
RollerBoySE
RollerBoySE's picture
Sony VTC5A will probably give you the highest output (check it out in HKJ’s comparator), but you sacrifice a bit of runtime.
hIKARInoob
Efest does not manufacture cells, they just put a wrapping on them. Efest often (always?) puts higher current ratings than that of the original manufacturer, so I don’t like Efest. You also pay more just for the Efest branding. Regarding runtime, I don’t know the capacity of the Efest you mentioned, but it’s perhaps 3000 mAh? In that case you get about 10% more runtime with GA.
Flying Luminosity
Yes, I accidentally ordered the efest for my MF-01, before I read HKJ’s review. Good to know though that the VTC6 are recommended for this light – that was another accidental purchase I made, thinking they were the button top version. Now I’ll be able to put them to a good use, and have some spares! Smile
treoneo
Thanks for the info!
hIKARInoob
It’s a great light, and you can’t go wrong with any of the cells discussed. Just don’t put UltraFire or protected NCR18650B in it or something like that. Cheers man! Party
