Hmm he did the current testing without the battery carrier actually. The driver spring would definitely yield the largest gain. I wish I could test differences, but I don’t have the equipment.
No, he used the carrier. He just modded it so that all the power went through an additional loop of wire so he could use his Uni-T UT210E amp meter. It’s the same model lots of blf’ers use, including myself. It’s only about $25 to $30. Having one really helps you to understand current flow and how it relates to output. If you like doing mods and stuff, you should consider getting one. It’s also a DMM in case you don’t already have one.
Thanks for sharing Bruno28. One question, how come it doesn’t capture its SS bezel temperature?
[quote]
You’re welcome.
Metal surfaces that are shiny can’t get the proper thermal reading. Infra red is reflected from other objects around and then the camera captures this.
The same happens with glass and mirrors.
As some have pointed out, the best way to get accurate reading on shinny surfaces is to use a black electrical tape, so the heat from the source will heat the tape and be able to read the temperature correctly.
The red hot areas on the bezel is actually a reflection of myself.
Maybe they could extend the height of the head by adding one more fin. That should add about 6mm which could be added to the shelf thickness. The extra mass would help reduce led temps, at least for a while.
not sure what you are getting at, is there something wrong with sharing my own finding here?
MT03 is known not making true 9K lumens, i am just giving a reference here as to how bright the light is. I think the MF01 Nichia is not making 11K lumens from the figure i got. I does look brighter to the eyes though.
btw. Did the test again now i only get only 15% (650 vs 750 Lux) with slightly used batteries (4.09v) Currently charging the battery to see if my initial reading was an error or the full battery did gave higher result
i think the MF01 nichia is making more than 7000 Lumens but i have no way of measuring the exact figure myself it looks brighter than my MT03 and the Lux support this.
If I’m not mistaken, there is only one person reporting about 7000 lumens for the Nichia version. So I hope rizky’s measurement is more representative.
I did the ceiling bounce again MT03(650Lux) and MF01(808Lux) both on freshly charged 30Q so 25% difference compared to MT03. If my MT03 is making 8000L the MF01 in theory should be making 10K Lumens. Now if my MT03 is making true 9K lumens then the MF01 Nichia is making 11250Lumens the later seems more comparable to the given specs. But the lumens is droping rapidly on MF01 and can be as low as 15% gain over the MT03 in the first minutes or two.
this is not true, the springs on the review light are from bronze alloy and are fully compressed with brass button soldered to unprotected cells
so the windings short each other, no need for a bypass
on the production light the spacing is larger in the carrier so it fits as well high drain cells with PCB like Klarus and some other brands have
if you use unprotected cells in the production light a spring bypass should gain a little longer runtime as well as turbo longer availiable
if its done right nothing to loose by a proper spring bypass
I’ve only had a chance to try it out once, but to my eyes, my MF-01 Nichia has to be putting out at least 10k lumens at startup (maybe more). It’s plenty bright, although it is a little warmer than I expected for some reason. Overall, it’s a very nice light.
Yeah, that’s the post I remember. It’s the only actual number I remember hearing about. So you guys are thinking the Nichia version is doing closer to 10k or 11k?
No one knows if his light is working properly or how accurately his light meter reads neutral white lights.
I just received my nichia light and have only used it a little with protected cells. Compared to my 4000+ lumen mountain bike setup and my MT07 there’s no way its only making 7000 lumens. Judging by how slowly it’s heating up in turbo switching to good unprotected cells will bump up the output even more.
My light’s completely awesome, smaller and brighter than I was expecting.
